How to make SL1 mode dial stiffer?
Started Mar 22, 2019 | Questions
EOS GUY
EOS GUY Senior Member • Posts: 5,342
So I have the perfect set up for my needs my sl1 and little f2.8 pancake lens.
BUT sometimes the mode dial - which is not lockable on the SL1 - gets knocked from what I'm meant to be in and onto another which can be a real pain when I'm using auto ISO and in A mode to get the best low light performance and then like today am in a museum, see a great shot and take it only to later find it is blurry and wrongly exposed to to being shot at the wrong s/speed, ISO and aperture....
Gah.  I was thinking get an 80d or M5 and 22m F2 -  as both have lockable dials - but I LOVE my SL1 and want to keep it.
Under the mode dial I can fit my finger nail in a little groove all around it....
I wonder if gluing it or some other method would be an idea to make the dial stiffer?
I'd be happy with it only stuck on A mode tbh, so would superglue if that was the only option, but if there is a less destructive solution I am all ears....
I like the tiny SL1 as it is like carrying a small m/less camera but I get fast start up and an OVF so I prefer it over M/less cameras I have had and also loved (just not quite as much)
Cheers
What the superior man seeks is in himself; what the small man seeks is in others.
Confucius
 EOS GUY's gear list:EOS GUY's gear list
Panasonic LX100 Canon EOS Rebel SL1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF-S 24mm F2.8 STM +6 more
Canon EOS 80D Canon EOS Rebel SL1 (EOS 100D)
rochester21 Senior Member • Posts: 1,212
Clear nail polish?
Worked on my dial. Just don't use too much of it.
AlbertTheLazy
AlbertTheLazy Veteran Member • Posts: 8,683
Re: How to make SL1 mode dial stiffer?
Experiment with an elastic band twisted round that groove. If it works but looks bad then look for a suitable O-ring
Albert the lazy photographer
Having fun with my cameras in Scotland
 AlbertTheLazy's gear list:AlbertTheLazy's gear list
Canon PowerShot G15 Fujifilm X-T1 Fujifilm X-T3 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R +6 more
EOS GUY
OP EOS GUY Senior Member • Posts: 5,342
Ooh. now that IS a good idea!
I have some O rings for vape tanks, should do the trick.
Cheers Albert
Confucius
Ray UK Contributing Member • Posts: 977
Definitely do NOT use super glue, that substance should be kept away from cameras completely. It is much too runny and is more likely to cause permanent damage.
EOS GUY
Okay.  Thanks for the tip
Confucius
guinness2
guinness2 Veteran Member • Posts: 4,617
Good advice. Same problem here. Shifted in my bag, it spoiled my Venice pics. I give it s try, thanks
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
