A6000, what else do I need to start?
Started Mar 19, 2019 | Discussions
kelpdiver Veteran Member • Posts: 5,564
Re: A6000, what else do I need to start?
16mm on a crop sensor is in a bit of no mans land.   It's not WA, letting you get within a couple feet of a broad coral, unless coupled to a wide angle wet port, and it's not close enough for small work.   Your 30 (45mm equil) is probably the shortest with potential for close work.
For large objects - mantas, sharks that won't come too close, it could work, but it's not the one I'd buy a port for.  If you go to backscatter, you can see a list of lenses it recommends for the A6000, and the corresponding port recommendations.
Mkfb8 Forum Member • Posts: 84
Well I dove with the SEL16mm pancake, back when the NEX 5n was new and you had the choice between the 16, 18-55, 50, 30macro, 55-210 and Zeiss 24mm plus Sigma 19 and 30mm.
For me 16mm felt too wide, but I didn't want to be limited by going full macro (always the chance to see a turtle or manta ray where I went diving ). My 30mm are a compromise I learned to live with and got some decent results for my purposes. Of course there are always better photos, but I currently don't feel like my gear is the problem.
Now kelp diving is something I really want to do when I get the chance.
 Mkfb8's gear list:Mkfb8's gear list
Olympus TG-860 Sony a6300 Sigma 105mm F2.8 EX DG OS HSM Sony E 30mm F3.5 Macro Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +2 more
OP DigiPainter Regular Member • Posts: 301
I thought the Sigma 16mm f1.4 would have been a good option to given its wide angle and lots of light via f1.4? I know guys shooting rx100s with no zoom underwater and thats 28mm.
So what is the problem with wide angle?
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Several:
1. small subjects (of which there are lots)
2. forced to deal with ambient lighting most of the time
3. corners, especially with flat ports.  (IQ)
4. corners again, except in relation to the size of dome ports you have to carry.
5. less than crystal clear water
Macro tends to have none of those issues, or to a much smaller degree.
Also, an F1.4 wide angle lens would not do you much good underwater as you typically stop down a lot to try to have decent corner and edge quality.  F8 is common starting point for my wide angle, and many stop down a few more f stops.   If exposing for ambient, you can see why ISO climbs rapidly as you descend.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
16mm on a crop isn't really wide angle.   16mm on a FF is.
