Source for strong split rings?
Started Mar 18, 2019 | Discussions
NeilMB Forum Member • Posts: 89
I've been using split rings to attach my homemade camera strap onto the lugs on my Canon 7D.
Yesterday, one of them "unwound" as I was pulling the camera around my body to take a shot. (Nothing fell since I was holding the camera.) Since they're playing a crucial role, I'd like to replace the random ones found around my house with some that are stronger.
Does anyone know where one can buy split-rings that are well built (but not too large to fit in the lugs)? Is there an easier solution in my situation that I'm not seeing?
Thanks in advance for any suggestions.
-Neil
 NeilMB's gear list:NeilMB's gear list
Canon EOS 7D Canon EF-S 18-55mm f/3.5-5.6 Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM
Canon EOS 7D
GreatWhiteWing Senior Member • Posts: 1,675
Re: Source for strong split rings?
-Neil
Might try local locksmith/retail store?
Home depot etc?
 GreatWhiteWing's gear list:GreatWhiteWing's gear list
Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Tamron SP 70-200 F2.8 G2 +2 more
MikeDixonPhoto
MikeDixonPhoto Regular Member • Posts: 121
Local fishing bait shop. Some of the lures have small diameter rings made to be quite strong. Also anywhere that makes keys normally has an assortment of different sized rings.
However, unless you put some heat shrink on there, you'll always risk it opening up because of the lever action it has when twisted.
If I were you, I would look into a better way of doing that. That carabiner is way overkill, I have one on my key ring.
 MikeDixonPhoto's gear list:MikeDixonPhoto's gear list
Canon EOS R5 Canon Extender EF 1.4x III Canon EF 24-70mm F4L IS USM Sigma 50mm F1.4 DG HSM | A Canon EF 100-400mm F4.5-5.6L IS II +1 more
TallTree Regular Member • Posts: 123
Lowes and I'm sure HD have gadgets display showing various styles. Split rings of several sizes, might require buying gadget to get size you want. Small carabiners make detaching from camera easy and quick.
 TallTree's gear list:TallTree's gear list
Canon EOS 77D Canon EF 100mm F2.8L Macro IS USM
engbert Veteran Member • Posts: 3,057
If you get the Peak Design anchors, which I like, I think they now come with some nice oval split rings.
(They no longer recommend putting their anchor cords directly through the lugs built into the cameras because they worry not all those are smooth enough.)
 engbert's gear list:engbert's gear list
Sony a1 Sony FE 50mm F1.8 Sony FE 100-400mm F4.5-5.6 Sony FE 24-105mm F4 Sony FE 200-600 F5.6-6.3
Gato Amarillo Veteran Member • Posts: 9,340
I've been using these adapters for a good many years now, then using a small snap clip on the strap:
https://www.bhphotovideo.com/c/product/542472-REG/OP_TECH_USA_1301322_System_Connectors_Adapt_Its.html
lately I've gone to small S-biners on some of my straps -- be sure to get the steel biners with lock. Note that these are too large to use directly on the camera.
https://www.ebay.com/itm/Nite-Ize-S-Biner-MicroLock-Black-2-Pack-Locking-Carabiners-for-Keychain-Pet-Tags/262904990870?epid=2255112362&hash=item3d365bcc96:g:aw4AAOSwqjhcMSjq
Works for me, but use at your own risk. I've had no problems with either product but my cameras and lenses are relative light m4/3 gear.
Gato
OP NeilMB Forum Member • Posts: 89
Thank you! Those op-tech adapters look like just what I was looking for. Glad that such a product exists and that this forum exists for finding it.
-Neil
