M5 II "Mini RP" concept
Started Mar 15, 2019 | Discussions
carpandean Forum Member • Posts: 66
6
The RP is roughly the same height as the M5 and M50, but has higher shoulders.  Even before it came out, I was thinking about doing the same thing to the M5 to give it a little more real estate and possibly even a better/taller grip (though, I do think it is very good for how small the overall body is.)
The RP also has a bigger grip and lens mount, both of which require it to be notably wider than the M5 and M50.  So, I thought about what Canon could do with an RP-type design, but utilizing the smaller EF-M lens mount and grip.  The latter being possible due to the smaller/lighter EF-M lenses.
Finally, I've said that I wanted a higher magnification viewfinder on the M5 (could differentiate future M50 series with the current one), but that it didn't need to be as high as on the X-T_ series or the R.  The RP came out with a perfect compromise.  It is the lower-end one in the R series, but it could be the perfect upper-end one for the M series.
This is what I came up with (not a perfect mock-up, but close enough.)  Thoughts?
 carpandean's gear list:carpandean's gear list
Canon EOS M5 Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 32mm F1.4
Canon EOS M5 Canon EOS M50 (EOS Kiss M) Canon EOS RP
fstopx2 Senior Member • Posts: 1,088
Re: M5 II "Mini RP" concept
You do nice work in Photoshop.
Canon will never let the M compete with the RP.
Peter_Birch
Peter_Birch Regular Member • Posts: 251
As I said in another post why not just put an M mount on the RP. Not a major job to re-tool for that run. An M5 ll with that body I would buy it.
He had a photographic memory that was never developed.
 Peter_Birch's gear list:Peter_Birch's gear list
Canon PowerShot G11 Canon PowerShot G1 X Canon EOS 300D Canon EOS 7D Canon EOS 5D Mark III +16 more
RLight Senior Member • Posts: 4,418
Canon doesn’t want to go bigger on the M, that’s it’s strength.
But, I suspect an optional grip could be offered.
That said Canon may borrow features like focus stacking, continuous eye-af, Fv and perhaps employ feedback on the manual focus rings on M lenses for control function like the R. That last part is up to Canon. They could do it, but may retain that feature for the R. If control ring functions come the the MF ring on EF-Ms, you can bet it’ll be a M5 / M6 II only affair.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
OP carpandean Forum Member • Posts: 66
Thanks.
It still wouldn't compete with the RP, since the RP is FF.  This is just borrowing some design cues (probably a little less literally than I did) from it.  The physical dimension of the same as the current M5.
To each their own, but I wouldn't be as happy with a body that wide.  The RF lens mount is so much bigger and the heavier lenses require a beefier grip, so you get a less ideal setup (for my purposes.)  It easier to swallow if you're getting the FF sensor with it.
It's not bigger, though.  The height, width and depth would all be exactly the same as the current M5.  In fact, the viewfinder on the RP actually sticks out less.  All I did was give the shoulders more height.  The viewfinder simply doesn't stick up as much.
sobrien
sobrien Senior Member • Posts: 1,756
I think it sounds like a very good idea. Why not. You’d get most of the size benefits plus a better grip.
One point, the RP viewfinder has the same specs as the M50 viewfinder, as far as I am aware, so that wouldn’t be a differentiating factor.
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
Ali Senior Member • Posts: 1,969
Nice mock-up!
To me the strength of the M series is the size; the M6 is the largest M I'd like to carry around. I'd enjoy having a built-in EVF, but not if it makes the camera any larger.  (The M100 is even smaller of course, but dearth of buttons irks me.)
With this in mind, RP and M5 are already way too big - when I played with one next to an R and M6 the RP felt much closer in size to the R than the M6.
It'd of course be fine if Canon did an M5 II like you propose as long as they also did an M6 II no larger than the current M6
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
Well, that's surprising and disappointing.  I thought that I had read that the M5's viewfinder was .6-something-x magnification, and comparing with the X-T1/R that have 0.77-0.78x magnification, there is a world of difference.  As such, I was thinking that the 0.70x on the RP had to be somewhere in between the two.  It does, indeed, look like the RP and M50 use the same screen.  Odd that the glass on the EVF opening on the RP is larger.  At least, it does stick out less from the back.
Ebrahim Saadawi
Ebrahim Saadawi Contributing Member • Posts: 561
carpandean wrote:
They might be similar on paper but the RP EVF is very different, much larger than the M50. It's very similar to the difference between APS-C DSLRs and a 6D, it feels like a FF EVF.
Egyptian 24 year old Dentist loves filmmaking/photos.
 Ebrahim Saadawi's gear list:Ebrahim Saadawi's gear list
Nikon D5500 Nikon Z5 Nikon AF-S Nikkor 50mm F1.8G Nikon AF-S DX Nikkor 18-140mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +1 more
bh69 New Member • Posts: 12
For me small size is weakness and one of most important reason I can't buy M5 or M50.
APS-C sensor in RP body would be great and simple to develop.
If Canon think it would be danger for RP I think they are wrong - FF and APS are different segments. Bigger problem is that without such camera many people will leave Canon for Fuji, Sony or maybe Nikon (if DX Z will be reality).
I don't understand todays call for smaller and even smaller cameras ... I prefer ergonomy - big grip and space for fingers with bigger lenses. If M5 should be semipro APS camera and if EF/EF-S lenses should be used without problems it's logical to make it the same size as RP. Look at 77d/80d - grip is much bigger and ergonomy is much better.
And small body size lead to demand for small lenses - such lenses ar slow, with significant vignetting and distorsion ... It's a way to hell, sorry.
wootpile Contributing Member • Posts: 747
Your mockup looks perfect. Since it has a true vari-angle screen, I'll take it.
Tell Sigma to make X-mount lenses
http://www.sigmaphoto.com/about-sigma/contact-us/
