R/RP ND Filter & Control Ring Mounts
Started Mar 8, 2019 | Discussions
cpharm86 Senior Member • Posts: 2,373
I'm getting my RP next week. I have not seen much on the use of the Variable ND filter and Control Ring Mounts. Has anyone purchased either one of these mounts?
$399 seems a bit steep but I guess less expensive then purchasing individual ND filters to give you 1.5-9 stops.
Drop-In Filter Mount with Variable ND Filter
Choice of Circular Polarizer Filter &/or Drop-in Circular Density Filter
https://www.bhphotovideo.com/c/product/1433719-REG/canon_mount_adapter_ef_rf_with.html
Control Ring Mount:
https://www.bhphotovideo.com/c/product/1433718-REG/canon_mount_adapter_ef_rf_with.html
OP cpharm86 Senior Member • Posts: 2,373
Re: R/RP ND Filter & Control Ring Mounts-Update
Control Ring Mount:
Sorry, I didn't see this thread on the Control Ring.
https://www.dpreview.com/forums/post/62400071
I guess I should ask if anyone purchased or will be purchasing the ND Filter Mount.
Kees Timmer Forum Member • Posts: 84
I have the Control Ring Mount Adapter EF-EOS R and Drop-in Filter Mount Adapter EF-EOS R + Variabel ND Filter.
The control ring mount is great. I use it to set the ISO. I use the variable ND filter mainly for video. It is certainly less expensive then purchasing individual ND filters of good quality. I also purchased the Clear Drop-in Filter A in case you don't want to use a filter.
Thank you Kees for your comments.
JerryriggedTECH
JerryriggedTECH Senior Member • Posts: 1,079
Control Ring Mount:
I just bought the vari ND adapter. Arrived last night, but I haven't opened / tried it out yet. I wanted to buy the clear filter at the same time, but is not available on B&H. When I don't need ND, not sure if it is better to just change to the basic adapter, or leave the filter adapter on with a clear filter.
 JerryriggedTECH's gear list:JerryriggedTECH's gear list
Canon EOS 5D Mark IV Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +5 more
Control Ring Mount:
I was talking to the Canon rep at WPPI last week and they suggested you keep the clear filter in. I don't own the mounts yet for my RP. My RP came with the grip and basic mount.
Pete Rissler Forum Member • Posts: 63
Looks like B&H sold out of the clear and polarizing drop in filters. I bought both from them along with the Neutral Density adapter but I also preordered them back in mid Feb. I'm scheduled to receive them next Monday.
 Pete Rissler's gear list:Pete Rissler's gear list
Nikon 1 AW1 Nikon 1 J5 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon MP-E 65mm f/2.5 1-5x Macro +13 more
EvilPersian
EvilPersian New Member • Posts: 11
Can you please clear something up for me? Does the adapter with ND filter also have a control ring? I know there is just a simple adapter with no control ring, but do the adapters with drop in filters not have the control ring either?
 EvilPersian's gear list:EvilPersian's gear list
Leica V-Lux 2 Canon EOS 77D Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM +2 more
Croomrider Regular Member • Posts: 478
It has one or the other, not both.
I purchased the variable ND filter to use on my RP. It is very nice for situations where it is bright out and you want to be able to use a slower shutter speed. However, it will do you no good on RF glass, since you can't use the adapter. I think it is great for some applications if you know you're going to be using EF glass but I wouldn't buy it just because it might be the only Canon adapter available right now. I also purchased a couple of off brand adapters when I couldn't get the $100 Canon ones, and they do just fine. I do think the price for the Vari-ND filter is ridiculous, as it's about 40% of the price of the complete RP body!
Oops! I just noticed how old this thread is!
Who dug this up?
Who dug this up?
No problem! I ended up buying the basic EF adapter only for $99
Since then I bought the R5
EvilPersian
Thanks. I figured as much, but it seems if I grabbed one, it would probably be the one with control ring, I can always screw on the filter.
SteveinLouisville
SteveinLouisville Regular Member • Posts: 485
I bought the adapter with the control ring, but I should have bought just the basic one.  I never use the control ring.
I haven’t even used the control ring with the RF lenses.
