Total winner. No-brainer RF lens
Started Mar 7, 2019 | User reviews
J A C S
J A C S Forum Pro • Posts: 20,521
Re: Total winner. No-brainer RF lens
LeicaBOSS wrote:
So, anyway - I'm glad this review posting went completely off the rails with intense, pro-level pixel peeping and theatrics.
Wrong, the PF and the smearing are well visible at lower resolutions.
More below - a few shots while running around with two toddlers in Central Park.
Understanding where a lens is at its worst is important because it allows you to make simple adjustments in the field to avoid trouble.
The bottom line on this lens is that you will not find a new lens under $500 that performs like this one. You will not find one at $1,000. Outside the 35L II, and perhaps some of the Zeiss offerings - this is a brilliant showing.
It is a winner in its class, consisting of one lens.
Below. If you need to take daylight landscapes like this at f/1.8 - which is usually stupid - here is the result. The lower right corner is the worst of it. You can also see the peripheral vignetting (software correction was turned off)
Takeaway: I'm very surprised how the edge detail held together. This is wide open, after all. I know my Leica 35/2 wouldn't fare better from a technical perspective.
Wide open landscape in broad daylight. Like a boss!
Below: Torture test. too much scene contrast to be reasonable. Wide open. Snips are at 100%. I'm not a corner peeper, but that's more detail than expected for a $400 at f/1.8
Takeaway. Surprisingly better than expected for such bad light. Corners resolved more detail than expected wide open in this circumstance.
Not bad for a downsized image, indeed. BTW, the focus is almost at infinity, and the PF in the other shots were in the OOF part. Even here, the small branches changed their color completely - they are purple now.
Here's an attempt at making the worst possible bokeh - mid-distance subject with a messy out of focus background - especially in the corners.
Takeaway: Only the best (read >4-8x more expensive) 35mm lenses would make this beautiful if you pixel peep the blur in the corners. It's far less nervous and unseemly than suggested. Having owned the Sigma ART - this is much easier to deal with.
Well, the Sigma lenses have busy bokeh as well.
Pixel peep the bokeh in the corners if you need to complain about something
Hard to pixel peep a downsized image but it was never about pixel peeping. I displayed your image full screen and the upper half ruins it for me.
A little more pixel peeping. I find that slightly-stopped-down blur tends to be the nastiest. Here's some at 100%.
Takeaway: If you must pixel peep backgrounds - this is not an epic world-class result. It's far better than the price tag, though.
Actually, the pixel peeping makes it look better. Even at this tiny resolution on the left, the bokeh looks really bad.
Wide open with a busy background, stopped down just a wee bit.
Below: You can peep this giant, stopped down image in ugly, hard sun. There's almost too much detail. I'd probably soften it up in post. But that's me.
It is a fine f/8 lens, indeed.
Peep my pixels.
forpetessake
forpetessake Veteran Member • Posts: 5,172
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
forpetessake wrote:
Looks a bit softer than the EF 35/2, but it also can be a strong AA filter.
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=1224&Camera=1221&Sample=0&FLI=0&API=1&LensComp=824&CameraComp=979&SampleComp=0&FLIComp=0&APIComp=0
Different camera resolutions. Try some of the other camera options with the f2.
Joe
LeicaBOSS
OP LeicaBOSS Regular Member • Posts: 447
Correct, not apples to apples.
Plus, I've had and used the 35/2. I hate to blanket a lens with a "softer" or "sharper" label - because more than resolution under flat lighting contributes to percieved sharpness. They ultimately aren't wildly different from a contrast and resolution standpoint, but I do have a bit more confidence in bad light with the RF and shooting wide open (or close to it).
From time to time, I point my camera at the right things. This is generally when I forget everything I've learned.
 LeicaBOSS's gear list:LeicaBOSS's gear list
Canon EOS R Canon EF 50mm F1.8 II Leica Summicron-M 35mm f/2 ASPH Leica Summilux-M 50mm f/1.4 ASPH Canon RF 35mm F1.8 IS STM Macro +11 more
David Hull
David Hull Veteran Member • Posts: 6,831
Oldwino wrote:
LeicaBOSS wrote:
Remember - I own that silly Leica Summicron M ASPH, which for many kinds of photography would be considered a complete joke from a technical standpoint. It also makes intensely beautiful images for me. Which point of view is correct?
Yup. This lens (Canon RF 35) reminds me very much of my old Leica Summaron 35/2.8. Has the same sort of smooth/sharp look to it, except the Canon has some aspherical elements in it, which makes the bokeh more nervous. To my eyes, it has 35mm-lens-bokeh, which is never that smooth anyway.
But overall, I like the lens. I've only has it for few days, but I like the way it renders. I like the way it makes my subjects look good. It's got a nice touch of distortion. It is interesting, rather than perfect and sterile and boring.
One day soon, I'll figure out which distances and apertures I like most. Same with any lens. I'll figure that out by shooting with the lens in a variety of conditions. I can promise you all, I won't be shooting any brick walls, and I won't be stressing out over the corners.
Everything in lens design is a trade off. If you (general "you", not you specifically LeicaBOSS) want small and light, you're going to have to put up with a few more aberrations. If you want "perfect", the lens is going to be big and heavy to hold all that glass needed to correct every last drop of CA, etc. But then you'll hate carrying around all that weight. At least I do. And the price, let's not forget the price!
I think here you are describing the RF 50mm which most seem to think is an excellent lens but is heavy and expensive.
I guess if your "photography" is all about numbers and statistics and corners, the weight penalty is a small price too pay. Me, I'll take some nice looking flaws over being a sherpa any day.
Recently retired with more time to fiddle with photography, I have been traveling with groups of travelers and have been putting together Blurb books at the end of each trip. I have discovered that you can do a lot with an EOS-M5 and the limited set of native lenses that are available for that platform.  I have now moved to the EOS-R for the next trip and have been considering this lens as somewhat equivalent to the 22mm I have for the "M5" (fast and small). I am looking for something that can do a good job yet be relatively small and light.
Non photographers are not nearly as demanding. That doesn't mean you can produce bad work but I can sacrifice some sharpness in the corners w/o loosing the impact of the photo as a documentary memory.
I hope we see a nice, compact 50/1.4 in the RF mount someday. Maybe it will remind me of my 1st generation Summilux, another lens of great beauty that's full of flaws. One can hope...
 David Hull's gear list:David Hull's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
David Hull
Hoka Hey wrote:
J A C S wrote:
Hoka Hey wrote:
1. Is there a significantly better 35mm AF FF lens at this size and price point?
Sure, the 35LII
Much larger and 3 times as much. Even so, the 35Lii doesn’t have much better bokeh for pines trees in the distance and similar OOF Objects. PF is better on 35Lii .
Joe
You have to stick the adapter on it so it will be larger and heavier still. If weight and size are your hot buttons, the 35/1.4's aren't going to be real attractive solutions IMO.  I own the 35 1.4 I and will probably sell it eventually.
J A C S
David Hull wrote:
Hoka Hey wrote:
J A C S wrote:
Sure, the 35LII
Joe
My phone is even smaller.
David Hull
J A C S wrote:
David Hull wrote:
Hoka Hey wrote:
J A C S wrote:
Sure, the 35LII
Joe
Yep, got one of those too, sometimes I use it as a phone even.
diness Veteran Member • Posts: 3,758
Re: Sounds Like You Never Tried the RF 35mm Personally
LensSodomist wrote:
LMOE wrote:
It's a 'meh' lens. Nice, but has its issues. No better, no worse than other similar primes. Priced right at $450-$500 USD. I think many are overly excited about this lens at is the only one that is small and a good "fit" with the current R series bodies. Shame there are no decent R bodies - yet.
What other non-L wide/mid prime has these attributes?:
  1. Fairly sharp wide open.
  2. IS
  3. Nearly as good as Canon 35L f1.4 Mark I
  4. Very good edge-to-edge sharpness across all f-stops
  5. L like rendition
  6. L like bokeh
  7. It's better than the EF 50L in most cases
I've owned all the EF non-L wide/mid primes and this one stands out head and shoulders.
I think you're right that this poster has never used the lens, but the other lens that stands out as having all the things you suggested is the EF 35mm f2 is.  Have you owned that one? Do you find the RF to be better?  I'm legitimately asking the question, no sarcasm.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
Rawpaul
Rawpaul Senior Member • Posts: 2,567
David Hull wrote:
J A C S wrote:
David Hull wrote:
Hoka Hey wrote:
J A C S wrote:
Sure, the 35LII
Joe
Oh, can you really do that… i have to try that sometime LoL
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
tdbmd Senior Member • Posts: 1,546
I have not had the RF 35mm f1.8 very long and have not really owned a lens with that focal length, with the exception of the EF-S 24mm, which I primarily used for team shots in sports.  That being said, I like this lens and focal length and am getting more comfortable using it.  Low light performance seems really good and the color rendition is good as well.
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
