[550D + EF 50mm F1.8] Back-lit Moth Orchid
Started Mar 6, 2019 | Photos
Wave forest Regular Member • Posts: 356
5
The moth orchid sit on the window sill. The narrow view angle of the 50mm @ 550D works fine.
 Wave forest's gear list:Wave forest's gear list
Sony RX100 Canon EOS 550D Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Sigma 35mm F1.4 DG HSM Art Canon EF-S 55-250mm f/4-5.6 IS STM +2 more
Comment & critique:
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4)
brightcolours Forum Pro • Posts: 15,885
try to...
Try to underexpose the flowers less (and of course, as a result, the sky more), easily achieved in M mode. The end result will be much nicer.
Digirame Forum Pro • Posts: 41,857
Re: [550D + EF 50mm F1.8] Back-lit Moth Orchid
Those are pretty flowers.  I like that the background helps the flowers stand out separately.
OP Wave forest Regular Member • Posts: 356
Thanks, Digirame.
Indeed, the neighbour's house and a birch tree were washed away. Also the back-light gave the moth orchid a kind of 3D effect.
Re: try to...
Thanks for your comments. Actually, it was indeed in M mode with spot metering to achieve an accurate exposure of the moth orchid.
If it were underexposed to get sky, then trees outside would show off and the whole frame would be very messy with an underexposed flower.
If you really want to get a clear background and the subject in back-light, flash is inevitable.
Re: try to...
The orchid still is seriously underexposed... The stem is an almost midtone green, but towards blck in your image, the orchid colour itself also way too dark. You appear to not have metered correctly.
Not talking about the sky.
No, i want the orchid to not look that underexposed.
Re: try to...
Nice examples! Thanks.
I think I misread your first reply - missed the word "less". My apology.
I should have indeed used the orchid stem or leaves to meter, instead the petals.
This is another try as you suggested.
Re: try to...
It was mostly my fault, as I left out a word ("and as a result overexpose the sky more"). Sorry for the confusion!
Very nice! I like this result better than your 1st image, the flowers now show their true beauty! The slight contrast issue with the lens I find less obtrusive than underexposure.
