Bag for multiple small primes?
Started Feb 28, 2019 | Questions
CBR1100XX Senior Member • Posts: 1,722
What I'm ideally looking for is a small bag that could fit on a belt which could hold small m4/3 primes.  The largest one currently would be the Sigma 60 f2.8, I also have the Panasonic 14, and Olympus 17, 25 and 45 f1.8's and might be getting a larger one like the 75 f1.8 in the future but that's a little ways off.
Right now I use a DSLR pouch but the issue is that I stack them in 2 layers and if I need those bottom ones I need to juggle a bunch of lenses which I'd rather not do.  So what I'd like is something long with a bunch of small dividers so I could have easy access to all of them.  Does anything like this exist?
Panasonic Lumix G 14mm F2.5 II ASPH
richj20 Forum Pro • Posts: 10,181
Re: Bag for multiple small primes?
CBR1100XX wrote:
...So what I'd like is something long with a bunch of small dividers so I could have easy access to all of them. Does anything like this exist?
If you can't find such a thing, consider getting a wide fanny pack or belt pack and making your own dividers.
I've done this with long, narrow photo bags.
You can purchase foam blocks and cut to your dimensions. Or packing padding. Or plastic bubble packing.
- Richard
JakeJY Veteran Member • Posts: 5,442
I don't know if they make them in holster style, but I know when I was looking for small bags, the ones designed for camcorders tend to be longer with a divider. Example, I bought a TBC-406 which is a DSLR holster, but the TBC-405 is a camcorder bag which is more horizontal (although only one divider).
Don't know how big of one you need. You can try laying out the lenses and measuring (I kind of did that with my camera and lenses before figuring what is the smallest bag that can fit).
B&H has a camcorder bag series in various sizes. You may have to buy separate inserts yourself or create a makeshift one.
https://www.bhphotovideo.com/c/product/981543-REG/ruggard_vsy_135b_onyx_35_camera_camcorder_shoulder.html
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Kiwisnap Senior Member • Posts: 1,557
Artisan & Artist do one intended for Leica Rangefinders that might work.
Here
Danielvr Veteran Member • Posts: 6,863
A different approach
There's a different solution where you take two rear lens caps and glue them together back-to-back (after sandng them flat), so they can firmly connect and protect two lenses.
When you want to use either lens, just lift both out of the bag and take the one you need -- no juggling required.
Apparently double rear lens caps can also be bought ready-made or be 3D-printed.
See also: https://www.youtube.com/watch?v=VzeKIvPb8hE
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
I use Think Tank Mirrorless Mover 20
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
TN Args
TN Args Forum Pro • Posts: 10,687
Re: A different approach
This ^^^^ is what I do. I simply glued pairs of rear lens caps back-to-back.
The tall pockets of my Domke ruggedwear thus hold two small lenses each, or one large lens.
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
OP CBR1100XX Senior Member • Posts: 1,722
Re: I use Think Tank Mirrorless Mover 20
Eric Nepean wrote:
https://www.thinktankphoto.com/collections/mirrorless/products/mirrorless-mover-20
That looks pretty nice but I have a shoulder bag already, and for next to no money I've actually been shocked at how well it works:
https://www.amazon.com/Medium-Altura-Photo-Mirrorless-Cameras/dp/B01LWIS76G
I can fit an E-M10 mkII and a full kit of lenses in there, or 2 E-M10's and enough lenses to get me through a night.
What I'm looking for now isn't so much for transporting them as having the lenses on me while I shoot and since I already have a second body over my shoulder so another strap/bag hanging wouldn't work.
Would something with a belt loop work for you? For example, here's a camcorder bag with a belt loop. You can also use a carabiner for quicker removal and attachment.
https://www.amazon.com/FOSOTO-Camcorder-HDR-CX405-Panasonic-HDV-5052STR/dp/B075C88K21/
A smaller one ( 6"x2.5"x2.25" inside dimensions according to Amazon):
https://www.adorama.com/solcsu5.html
A similar size but taller (6"w x 4"h x 2.5"d):
https://www.adorama.com/othpxl.html
Or are you looking for something with its own belt/strap for your waist? In which case fanny/hip packs, of which B&H has a big selection:
https://www.bhphotovideo.com/c/buy/Belt-Hip-Packs/ci/177/N/4075788793
https://www.bhphotovideo.com/c/buy/Belt-Hip-Packs/ci/4094/N/4028759489
Here's one designed especially for lenses (although longer ones):
https://www.bhphotovideo.com/c/product/966978-REG/porta_brace_hip_4lens_waist_belt_for_4.html
Most of these types of bags however would not be designed for really compact lenses like in MFT, but more for DSLRs (which is why I suggest camcorder cases as their dimensions are closer, you just have to make your own dividers).
magnesus3 Contributing Member • Posts: 642
Thanks,  this is brilliant.
rsmithgi Senior Member • Posts: 2,939
Peak Design Field Pouch with 17mm, 25mm, 12-32, 45mm, and 60mm macro:
Here is how it looks closed:
It has a belt loop in the back, can take Peak Design anchors for a strap, and has a spot for a capture clip in the front.
There are additional pockets to fit a cleaning cloth, or other small items. I find it to be a bag that can server multiple purposes. It you want to take just a small camera and a lens or two, all you need is this bag.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
Look for a padded insert and stick it into any bag you may already have.
https://www.google.com/search?q=padded+insert+for+lenses&rlz=1C9BKJA_enUS594US594&hl=en-US&prmd=sivn&source=lnms&tbm=shop&sa=X&ved=2ahUKEwiinMSbst7gAhXxUt8KHaelA2EQ_AUoAXoECA0QAQ&biw=1194&bih=721
Or, get small individual lens cases, like LowePro 7 x 8cm.
https://www.lowepro.com/us-en/lens-case-7-x-8cm-lp36977-0ww/
The beauty of either method is your ability to use pretty much any small bag to haul your lenses… lumbar, Fanny or sling pack. I often attach one lens case to the sling strap for quick swapping between 2 lenses. 17.5mm and 42.5mm or a telephoto and a macro lens.
Also, your logo encrusted photo gear bag doesn’t scream: $5000 of photo gear inside, steal me!
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
jeffharris
That’s not very nice. The lenses are all jammed together with no padding between them. A great way to rub the paint off them or just have them banging into each other.
That first one looks really promising, thanks!
Looks really interesting, if the cheaper Amazon solution falls through I'll be going with this.
That's my solution for my Nikon gear though I have some generic version of the individual lens cases. They work great but even my small one is pretty big and my m4/3 primes are swimming in it.
And I agree with you about having a plain looking photo bag. I bought an Amazon basics one about 7 years ago and the zipper finally failed a few months back which I think is a solid life for a bag so I grabbed another one for 30 bucks. It's great for a 2x D750 kit but unless you have 2 larger bodies and a ton of long zooms/1.2 lenses it would be hard to fill it:
https://www.amazon.com/AmazonBasics-DSLR-Laptop-Backpack-interior/dp/B00CF5OGP8/
The top can be snugged down enough to have little movement. I must be extra careful with how I handle bags because I sit lenses on top or side by side all the time with no issues.
I could also slide little pieces of foam sheets in between. I have a bunch of it from when I purchased sheets to make the "black foamy thing" for my flashes.
The good thing is the field pouch is versatile and can serve a variety of purposes.
I buy microfibers in bulk (30 pack pf MagicFiber brand is 19 bucks on Amazon) and just use them between lenses when I need to stack them like this.
jeffharris
Yep, Here's how I do it.
Patagonia Stealth Atom Sling 15L. 3 or 4 lenses in bag, 1 on camera.
L to R: Tarmac lens case for 7-14mm f4, Mountainsmith Zoom (small) for Voigtländer 17.5mm or 42.5mm and adapted Voigtländer 75mm f2.5 Color Heliar.
Patagonia Atom Sling 8L. 2 lenses in bag, 1 on camera.
Favorite street kit. GX8, Voigtländer 17.5mm, 42.5mm and 75mm.
Eric Nepean
Could you give a link to that please? Sounds usefuul but struggling to understand what exactly these are.
Cheers
Eric
