Panasonic 100-400mm List Of Maximum Aperture Value Video
Started Feb 27, 2019 | Discussions
Tim Love
Tim Love Regular Member • Posts: 176
This might help people wanting to compare the Panasonic 100-400mm aperture at each focal distance to their own MFT lenses. The Panasonic is only a F4.6 at 150mm vs the Olympus 150mm pro at F2.8  Panasonic 100-400mm List Of Maximum Aperture Value At Every Focal Distance
 Tim Love's gear list:Tim Love's gear list
Canon PowerShot SX50 HS Sony RX100 III Nikon D7100 Nikon D3300 Panasonic Lumix DMC-GX85 +28 more
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,214
Re: Panasonic 100-400mm List Of Maximum Aperture Value Video
Why do you need a video to get this information? A simple text table would be better.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
hindesite Veteran Member • Posts: 4,893
Terrible!
But what is the m.Zuiko like at 400mm?
SHood Veteran Member • Posts: 6,100
hindesite wrote:
Terrible!
Maybe we'll know later this year once it is officially released.
 SHood's gear list:SHood's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0 Olympus 17mm F1.2 Pro
Mark Ransom
hindesite wrote:
Terrible!
Expensive.
Bryan
Bryan Senior Member • Posts: 2,570
Why are you comparing apples against oranges. The subject lenses are totally different! How does your Olympus 150mm Pro 2,8 perform at 400mm?????? Sorry but your comparisons lack logic.
Bryan
Box-Brownie and other stuff.
Still looking for a digital back for my Box Brownie.
https://www.flickr.com/photos/bryang9/
 Bryan's gear list:Bryan's gear list
Panasonic Lumix DMC-ZS40 (TZ60) Sony RX10 IV Canon EOS D30 Canon EOS 7D Mark II Canon EF-S 18-135mm F3.5-5.6 IS USM +5 more
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Darn, I was going to post the very same thing but you beat me to it.
I think these idle, illogical pis***g contests are starting to wear me down and affect my usually lively and youthful (!) disposition...
How about a nice FF/Fuji vs µ4/3 debate for a change?
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
magnesus3 Contributing Member • Posts: 642
Here you are:
100mm f4
110mm f4.2
124mm f4.4
150mm f4.6
167mm f4.7
180mm f5.8
200mm f5
250mm f5.4
300mm f5.7
350mm f5.9
400mm f6.3
So quite linear and reasonable.
(Hope Olympus will show a similar lens since my PL100-400 broke  and I am afraid to buy a second one, especially because it had too many flaws even when it was working - stiff zoom, shaving off mount etc.).
AshleyMC Senior Member • Posts: 2,228
Here you are:
100mm f4
110mm f4.2
124mm f4.4
150mm f4.6
167mm f4.7
180mm f5.8
200mm f5
250mm f5.4
300mm f5.7
350mm f5.9
400mm f6.3
Thanks for taking the time to type the list above. Reasonable, as you said.
BTW, PL 12-60/2.8-4 is f/2.8 at 12mm ONLY. Get 12-35/2.8 of you want constant f/2.8.
Hmm feeling bad about your problems with PL 100-400. The zoom ring on mine is not stiff at all -- firmer than most zoom rings on other lenses, but not annoyingly stiff. It's the first time I heard of the mount shaving off -- perhaps I use the lens with Panasonic G9 and GX8, not with an Olympus OM-D body? Overall, though, I must say it is not an easy lens to master. (I have managed to get a few "wow" images at 400mm f/6.3 -- and given the smaller size and lighter weight of the body-lens combo compared to my previous DSLR setup, I am quite satisfied.)
AshleyMC wrote:
Here you are:
100mm f4
110mm f4.2
124mm f4.4
150mm f4.6
167mm f4.7
180mm f5.8
200mm f5
250mm f5.4
300mm f5.7
350mm f5.9
400mm f6.3
Yes, it happens only on Olympus, the mount is too tight. Not sure if it safe to continue using it (it still works but doesn't focus beyond around 275mm), hope the shavings won't happen again.
One thing to say from the pictures I have taken: you should use electronic shutter with it or at least anti-shock.
Joeb0b New Member • Posts: 17
Oh interesting 300mm is F5.7 that's only a tad slower than the 40-150 F2.8 with the MC-20 when it comes out.  Right?
 Joeb0b's gear list:Joeb0b's gear list
Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic 20mm F1.7 II Panasonic Leica 100-400mm F4.0-6.3 ASPH Sigma 30mm F1.4 for Micro Four Thirds
larsbc Forum Pro • Posts: 18,282
Possibly because they're very similar in size/weight...which is why I chose the Panasonic 35-100/2.8 for my main travel tele zoom.
But, of course, you are right.  Those lenses cater to totally different requirements.
The optical-quality-above-all-else mantra wasn't very effective for me when I had my Nikon system; I ended up with a "pro" lens set I only used locally and a consumer lens set for traveling.  When I moved to micro four thirds, I made sure that all my "pro" lenses were suited to my travel goal.
HRC2016 Veteran Member • Posts: 6,874
Metal shavings from the Pan 100-400
AshleyMC wrote:
Here you are:
100mm f4
110mm f4.2
124mm f4.4
150mm f4.6
167mm f4.7
180mm f5.8
200mm f5
250mm f5.4
300mm f5.7
350mm f5.9
400mm f6.3
There have been numerous reports of this lens not mounting well on the Oly EM1.2. Some people force it, resulting in metal shavings ending up inside the body.
I've bought/tried about 6 or 7. Most did not fit. In fact, in a visit to a camera store I tried the Panny 100-400 on my body (too tight) and a store demo. The salesman forced it and had to clean inside the body!
The lenses that did fit had a very stiff zoom (such that I had to hold the lens and twist the camera), and one had problems focusing consistently on stationary objects (plus the stiff zoom).
I know some people rave about this lens. I certainly went above and beyond to get a suitable copy.
I recommend trying the copy before purchase or make sure you can live with the return policy. It's about $35 to ship, which adds up if you have to send a copy or two back.
Panasonic's decision not to repair this lens has also generated negative reaction by others, who seem to feel it's disposable after the warranty runs out.
I'm awaiting the Oly 150-400.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
SHood wrote:
hindesite wrote:
Terrible!
Whoosh...
Gregm61 Forum Pro • Posts: 15,899
....but if you are looking to reach out to 400mm, the Panasonic Leica is the one to get. I can only get to 210mm using the 1.4x TC and slows me down a stop to f4. Add the upcoming 2X TC to the 40-150mm f2.8 and you've got  an f5.6 constant speed zoom and you're still 100mm short of the Panasonic Leica at the long end.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
WhiteBeard
Mark Ransom wrote:
hindesite wrote:
Terrible!
Expensive.
And non-existent... The OPl AFAIK, is talking about the 40-150 F2.8 Pro which will never go to 400 even with the help of a 2x TC. As for the upcoming 150-400 F4.5, yes it IS going to be expensive ... but is not F2.8.
It would be fun to see the size, weight and price of an eventual (!) 150-400 F2.8 though...
Tim Love
OP Tim Love Regular Member • Posts: 176
Well, I have been catching a lot of crap for posting this thread.  The video is not mine. I just saw it on youtube and remembered people asking about the f-stops on the 100-400mm so I thought it might help someone out.  As for why they didn't just put up the f-stops in text, well it's on youtube so how would you do that?
I posted the link to the video because they went to the trouble to make it and do all the work.  I had the respect for someone else to not just steal their work by coping and pasting the results on here like others have and then complain about them making a video that produced the info.
Mark Ransom
I hope you didn't think I was complaining about your original post when I complained about it being a video. You're right, it's useful information. Nor was I asking you or anyone else to plagiarize someone else's work.
It was just a more general comment on the state of the internet. Everything has to be a video these days, even things which are obviously better in another format.
Tim Love
No really what you said but from the next comment on down it turned into a Pana 100-400mm bashing thread. That's one of the reasons I don't start many threads on this forum anymore.
Sorry you missed the irony in my post, then.
cheers
