Hacking Pentax Debug mode
Started Feb 24, 2019 | Discussions
bootcoder New Member • Posts: 9
8
I have found how to enter Debug Mode on Pentax K-1 Mark II:
  1. Create on SD card file "00078400.597" with "[OPEN_DEBUG_MENU]" and LF char.
  2. Create on SD card file "DEVELOP.MOD" exact 10 bytes long with binary content:
    For Development Menu 1-6: 07 01 2C 1F 10 03 1E 16 05 2D
    For Development Menu 1-7: 07 1A 02 0A 19 18 1B 1C 05 11
    Use hexeditor to enter these bytes.
  3. Turn off camera, plugin this SD card. Leave card door open. Hold "menu" button and turn camera on.
I have also found how to enter Debug Mode on other Pentax cameras. I would like to discuss about what is possible in debug mode.
PLEASE: do not post messages "debug mode can't this or can't that". This topic is all what debug mode "can".
How can we use it for further hacking?
Pentax K-1 II
MightyMike Forum Pro • Posts: 41,691
Re: Hacking Pentax Debug mode
Looking forward to seeing where this might go, the only warning is fiddling with values in debug mode could potentially cripple the camera so be careful.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
DougOB
DougOB Veteran Member • Posts: 3,176
Do you mean "For Development Menu" twice?  Or should one be a different option.
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +36 more
OP bootcoder New Member • Posts: 9
There are 2 ways to get in there. One way you see only pages 1-6, another way you get to see one more page. Not sure why it is so.
dpreviewblog
dpreviewblog Contributing Member • Posts: 546
Please, can you create 00078400.597 and DEVELOP.MOD files for us and share these files to google disk or any ... ? Because I d't understand what you mean the exact 10 bytes long and what is the difference between For Development Menu 1-6 and For Development Menu 1-7
 dpreviewblog's gear list:dpreviewblog's gear list
Pentax smc FA 31mm F1.8 AL Limited Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro +13 more
Here we go
Should enable all pages (second way: 1-7)
dpreviewblog
bootcoder wrote:
Here we go
Thank you! Will try...
https://500px.com/my-shots and etc.
http://lightinspired.deviantart.com/ > Founder
http://lightinspired.deviantart.com/gallery/
DougOB
Do you have how to enter debug mode for a KP?
Doug
bclaff Forum Pro • Posts: 13,929
bootcoder wrote:
... I have also found how to enter Debug Mode on other Pentax cameras.
Can you prepare a list with the "recipe" for each one?
Sure. What items are on these pages of "developer" items?
Hard to know without knowing more.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Have a look at screenshots for K-1 here There also instructions for other Pentax cameras there.
Use files from dbmode.zip that I provided in another post, but rename file 00078400.597 to 00078380.581. Good luck!
DougOB
Thanks.  By any chance is the filename dependent on firmware version?
Doug
flektogon
flektogon Veteran Member • Posts: 6,226
Doug
Doug, what good is it for? I can't imagine what I would need to change in my camera(s). Maybe, if I had one of those lenses with failing SDM. But then I would prefer to disable the SDM "presence" in the lens itself, not in the camera.
Peter
DougOB
flektogon wrote:
Doug
Been there, done that.  To disable the SDM in the lens you must put the camera in debug mode so that you can download, modify then upload the lens bios info.   At the time I needed to borrow an older K-5 to do it since I couldn't get my newer cameras into debug mode.
I can't remember what else is there, but it might be worth a look.
Doug
flektogon
DougOB wrote:
flektogon wrote:
Doug
Doug
Oh, so I nailed it. And which lens did you need to "fix"? Have you succeeded?
Peter
DougOB
flektogon wrote:
DougOB wrote:
flektogon wrote:
Doug
Doug
My one and only SDM lens - the DA* 50-135 after its second SDM failure.  It works perfectly fine now.  It is one of those special lenses worth the effort!
Doug
siva-kumar Regular Member • Posts: 233
There was once, for my Bigma, even with AFA set to -10, there was some back (or front, I forget) focus issue. Through debug mode, I was able to set default of -5 and was able to get sharp focus at -12 (camera set to -7). I know, the correct way to fix is to send it to service but since this worked, I was using it like that
 siva-kumar's gear list:siva-kumar's gear list
Pentax K-3 Sony a7 IV Pentax HD DA 560mm F5.6 ED AW Sony FE 200-600 F5.6-6.3 Panasonic Lumix DC-G9 +3 more
Rod Herdman Veteran Member • Posts: 3,494
Interested if any extra function can be added to my K5ii-S . . .
All I want is a digital back for my trusty K1000 . . .
 Rod Herdman's gear list:Rod Herdman's gear list
Pentax *ist D Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 50-200mm F4-5.6 ED +12 more
KRG1953
KRG1953 Regular Member • Posts: 307
What is the debugcode for the K-S2 ?
 KRG1953's gear list:KRG1953's gear list
Pentax K-S2 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax FA 28-105mm F3.5-5.6 Pentax K-x +7 more
Pontoneer Veteran Member • Posts: 3,198
This is such a DANGEROUS thing to mess about with - real danger of turning your camera into a brick .
With kind regards
Derek.
 Pontoneer's gear list:Pontoneer's gear list
Pentax *ist D Pentax K-01 Pentax K-3 Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited +37 more
