How setting AF for canon g7x ii
Started Feb 25, 2019 | Questions
Bamboo20 New Member • Posts: 4
I just brough canon g7x ii and meikon housing. Could anybody advice me? When put the camera in housing, touch screen cannot workable. So how or what AF have to setting my camera? My problem is the small retangle AF frame is at the center of frame and I cannot move it, AF frame not automatic move to other point and cannot move by any button (I set single 1-point). so I can focus only at the center of frame. Thank you in advance for any advice.
Canon G7 X II Canon PowerShot G7 X Panasonic Lumix DMC-G7
kelpdiver Veteran Member • Posts: 5,564
Re: How setting AF for canon g7x ii
singe point should be setable using the menu buttons.  Just need to get to the right spot.
OP Bamboo20 New Member • Posts: 4
Thanks for your advise.
That 's mean I have only AF point that have setted before put camera into housing. So if I would like to focus on subject at the corner of frame, I have to lock AF then recomposition, right.
Barmaglot_07 Contributing Member • Posts: 633
Shooting through a flat port underwater, your corners are subject to significant pincushion distortion, so in general it's not a good idea to put your subject there in the first place.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
in default behavior, the Ring Func button (left of the video record red button on back) can be hit, which then allows you to use the directional keys to select a non center focusing spot.   This might make sense when doing a tricky macro composition, but focus and recompose is usually faster.
If your housing doesn't give you access to the ring func button, you can probably reassign one of those that is available.
I see. Thank you again.
I will try that button, Thanks.
