Do you use the Top LCD on the EOS R?
Started Feb 22, 2019 | Polls
analogue Regular Member • Posts: 238
YES!
It sure comes in handy from time to time.. like when the back lcd is flipped in or to quickly glance settings.
Becomes even more useful when camera is strapped around your neck (in which case i rarely use rear display) or when camera is set low on tripod or gimbal.
It is also useful when i set the flip LCD to no info or to the gyroscope.
And of course when turning camera on it is great to know what mode you are in since the mode dial is gone..
Overall i could do without but its a definite plus for me that it's there!
 analogue's gear list:analogue's gear list
Canon EOS 5D Leica M9-P Canon EOS 5D Mark III Canon EOS R6 Canon EF 35mm F1.4L USM +7 more
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
Re: Do you use the Top LCD on the EOS R?
wmlele wrote:
DeeNikon wrote:
Do you guys pull the battery out when you dont use the camera?
Do i have to fear screen burn in when display is always on?
I wish there was an option to turn off the screen when cam is off
I did the math to answer a similar question about the top lcd on the R.
That thing is designed to be left on years, and the R battery can power it for thousands years. The electronics that handle the soft on-off function and the battery self discharge are orders of magnitude more relevant than that LCD.
I think you're creating an issue when there's none.
Yes. DeeNikon is known for trying to create issues where there are none. I hope he/she is being well paid for his/her efforts.
Joe
quiquae Senior Member • Posts: 2,265
In the past, I’ve almost never looked at the top LCD on my 6D and 7D mark II, preferring to see the information on the rear panel instead. However, with the R my habit has changed, and I find myself using it often to set the aperture, SS, etc before bringing the camera to my eye.
This is probably because on the R top LCD is the only way to confirm the mode status without turning on the rear panel, whereas on the DSLRs the same function is fulfilled by the mechanical mode dial. Once I do start paying attention to the top LCD, I have a lot less mental resistance against checking and adjusting other settings via the top LCD.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
Shaun Gibbs
Shaun Gibbs Contributing Member • Posts: 560
Yes. It is very useful to see what mode you are in when customizing the C1-C3 modes and also when picking up the camera.
Also useful to see if the lock button is enabled or not which doesn't seem to show in either the viewfinder or display.
www.instagram.com/shaungibbsphotography
 Shaun Gibbs's gear list:Shaun Gibbs's gear list
Canon EOS R Canon EOS R5 Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon 70-300 F4-5.6 IS II +5 more
fotomotovfr Regular Member • Posts: 470
DelAPhoto wrote:
I have been using the 1D series for years where the top LCD is more Integral to changing and confirming settings etc.,
Same here.  I shoot a lot of events with two bodies so being able to glance down to the other body without touching it is great.  Plus it's lot more informative and useful than a PASM dial or a large ON/OFF dial.
 fotomotovfr's gear list:fotomotovfr's gear list
Olympus Stylus 1s Canon EOS 5D Mark II Canon EOS-1D X Canon EOS R
Larawanista
Larawanista Veteran Member • Posts: 4,736
Mr Marco wrote:
I find the the Top LCD on the Camera very practical. But I don't see why it is really necessary, as you have all the Information in the Viewfinder or on the flip-out screen.
What do you think? Do you often use it? If yes, in what scenario?
Several instances, one of which is during long exposure shoot, where I can see how much time is left. Same with time lapse.
In landscape photography sometimes, your camera will need to lean on the wall, say, of a cave, which means you adjust your settings using the top LCD.
"Photography is therapeutic."
http://www.pbase.com/joshcruzphotos
 Larawanista's gear list:Larawanista's gear list
Canon EOS M3 Canon EOS R Canon EOS RP Canon EOS R6 Canon EF 100-400mm f/4.5-5.6L IS USM +10 more
