Do you use the Top LCD on the EOS R?
Started Feb 22, 2019 | Polls
Mr Marco
Mr Marco Junior Member • Posts: 49
I find the the Top LCD on the Camera very practical. But I don't see why it is really necessary, as you have all the Information in the Viewfinder or on the flip-out screen.
What do you think? Do you often use it? If yes, in what scenario?
 Mr Marco's gear list:Mr Marco's gear list
Canon EOS R Canon EOS R5 Canon EOS R6 Canon EF 100-400mm F4.5-5.6L IS II Canon RF 35mm F1.8 IS STM Macro +3 more
POLL
Yes
63.4% 26  votes
No
36.6% 15  votes
  Show results
Wildabobalore Regular Member • Posts: 407
Re: Do you use the Top LCD on the EOS R?
So far no I haven't used it even once. Most of the time I forget its even there.
 Wildabobalore's gear list:Wildabobalore's gear list
Fujifilm X70 Fujifilm X100V Sony a6000 Canon EOS Rebel SL2 GoPro Hero9 Black +8 more
Ed Rizk Veteran Member • Posts: 3,898
I didn't even use it on my DSLRs.   The info on the rear screen is so much better.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 6D Canon EOS R Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +4 more
DelAPhoto New Member • Posts: 5
I have been using the 1D series for years where the top LCD is more Integral to changing and confirming settings etc., Once you get use to a certain way of shooting/navigating your camera you tend to stick with what works for you. I also use the EOSR more for quick confirmation of settings. moving between modes and changing a few settings etc.  I have a lot of more settings map to buttons with EOSR and I tend to use the back LCD/EVF a lot more so the top LCD is used less.
I like having the Top LCD option though so I would like for that to remain in future R cameras.
 DelAPhoto's gear list:DelAPhoto's gear list
Canon EOS-1D X Canon EOS M5 Canon EOS R Canon EF 135mm F2L USM Canon EF 24-70mm f/2.8L USM +4 more
MadScientistUK New Member • Posts: 9
It tells you which mode the R is in even when it’s switched off but that’s the only use I’ve found for it.
Graham C F Regular Member • Posts: 107
I find it useful when I first turn the camera on and am about to start shooting.  I can do a quick check of the settings, without the bother of looking through the viewfinder or at the LCD.
Occams Razor Senior Member • Posts: 1,252
I use the top LCD as quick check of settings and is a habit I developed from my 20D days and the other DSLR's I've owned.  I could live without it but since it's there I will continue to use.
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
coyoteincorrales
coyoteincorrales Junior Member • Posts: 31
I agree. It's helpful to have it there just for a quick visual looksee to see what the current setup is. I don't object to its being there--information is useful.
 coyoteincorrales's gear list:coyoteincorrales's gear list
Canon EOS 6D Canon EOS 70D Canon EOS R Canon EOS M6 II Canon EOS R5 +9 more
Rawpaul
Rawpaul Senior Member • Posts: 2,567
It could be very helpfull if you don't use the screen (folded in)
when working on a tripod
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
Astrophotographer 10 Forum Pro • Posts: 13,911
So far I have only used it to pick which mode I am in. But it is a matter of getting used to it and using it more often. I think its more handy when the camera is on a tripod and you are looking down onto the top of the camera.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony a7R III Canon EOS Ra +1 more
DeeNikon Regular Member • Posts: 461
Do you guys pull the battery out when you dont use the camera?
Do i have to fear screen burn in when display is always on?
I wish there was an option to turn off the screen when cam is off
 DeeNikon's gear list:DeeNikon's gear list
Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F4L IS USM
Rawpaul
I pull it out only when it's going to be off for quit a while.
as for burning in the screen..... does you digital watch do that ?
it's the same kind of screen as my Suunto outdoor watches
MikeSp Senior Member • Posts: 1,056
No since it is difficult for my aging eyes to read and its lighting in inadequate--two of only 4 niggles that I have found with my R (I don't shoot video where reviewers thought the world was ending).  FWIW,  I did use it on my 5DIV, but it was larger and better illuminated.  OTOH, I have all of the information in the EVF, so to be, there is no insurmountable issue here.
 MikeSp's gear list:MikeSp's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 24-105mm F4L IS USM Phase One Capture One Pro +1 more
Glassfish Regular Member • Posts: 478
I used to think this way with my DSLR however in practice I use top LCD on DSLR primarily. IMO, it uses less battery than the rear LCD screen.
I think on R, info. on EVF can provide richer info. or similar than what is on DSLR, the top LCD can be less important and perhaps is eliminated on RP.
A good point, as far as I know the organic LED (OLED) is the only one that has burned characteristic but not with pure electronic LCD/LED kind. So in this case, I think it is not the case to see the burned mark on R.
I don’t worry about battery consumption.  I always carry an extra one.   I don’t need the second battery often, but wouldn’t be without it.
I also shoot fewer pictures than many here.   If I did a lot of burst shooting for sports and wildlife, I would have to pay attention to battery life.
Ed Rizk
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
Great question.
I always use the top LCD to check the battery level when I pick up the camera to go shoot something.
Until a few weeks ago, I ignored the top LCD expect for battery checking. Then one day, I was shooting some long exposure bracketed images with a 10 stop ND filter that were about 4 minutes each using bulb. When using bulb, the back Live view screen goes black. I think that this reduces electronic noise for a cleaner exposure. Anyway, with the rear screen black, you don't know how long you have to wait for the exposure to finish. I also sometimes forget whether I turned on Bulb Timer, and wonder if the camera is just going to continue the exposure forever.
I had the camera on a tripod very low to the ground. I happened to look down at the top LCD during one of the exposures and noticed that there was a timer. Now, I can see how long the exposure has been if I'm concerned about whether I set the bulb timer.
It's just a little thing, but sometimes 4 minute exposures seem to last for days. 🙂 Now, I can check it by looking at the top LCD. Just another simple but nice feature that I have discovered with this camera.
As an aside, this is what I got in the end. Not going to win any prizes, but I like it and learned a lot in the process.
Joe
Rawpaul
Hoka Hey wrote:
Great question.
Joe
That is awesome , i didn't know that yet thanks for that Joe.
By the way nice image...
Mr Marco
OP Mr Marco Junior Member • Posts: 49
Hoka Hey wrote:
Great question.
Joe
Nice photo
Having the timer on the top lcd is indeed an awesome feature which makes it quite useful! Thanks for sharing.
wmlele Regular Member • Posts: 223
I did the math to answer a similar question about the top lcd on the R.
That thing is designed to be left on years, and the R battery can power it for thousands years. The electronics that handle the soft on-off function and the battery self discharge are orders of magnitude more relevant than that LCD.
I think you're creating an issue when there's none.
 wmlele's gear list:wmlele's gear list
Canon EOS 80D Canon EOS M5 Canon EOS R
