Photo Shoot question(s)
Started Feb 20, 2019 | Discussions
MikeF15
MikeF15 Regular Member • Posts: 340
I have a Panny GX7 and have been asked to shoot some scenarios for a local hospital. Their intention is to display these on a "banner",.. likely several feet across.
Is the resolution "good enough" on the GX7 to handle being blown up that large? ( I'm assuming each photo will be about 1.5 to3 feet across and lined up along the banner.
I will be bringing my 12-35 2.8, 35-100 2.8, 15 1.7, 25 1.7 and 42.5 1.7 lenses,. so I'm not too concerned about the available light,. just ability to have clear/well resolved photos.
Should I upgrade to the GX9 for better stabilization and the higher resolution??
(I may bring along my Fuji X100F as another camera to get a different look,..)
Any help is appreciated!!
Cheers
Mike F
 MikeF15's gear list:MikeF15's gear list
Fujifilm X70 Fujifilm X100F Panasonic Lumix DC-GX9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +3 more
Fujifilm X100F Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7 Panasonic Lumix G 42.5mm F1.7
Skeeterbytes Forum Pro • Posts: 23,182
Re: Photo Shoot question(s)
With careful craft your current lenses and camera can do the job. My main question would be what is the viewing distance? So long as folks viewing the images aren't close enough to touch them, 16MP should offer ample resolution. Banners tend to be viewed from a reasonable distance and there will perhaps be lettering, too?
Sounds fun!
Rick
MikeF15
OP MikeF15 Regular Member • Posts: 340
Thanks for the reply,. Yes I believe the banner would be viewed farther away than one could touch it,.. that being said it’s a great question to ask!
cheers!
Ab Latchin Senior Member • Posts: 2,229
6
Cheers
Mike F
Hey Mike,
The simple answer is yes. I run a design agency and produce banners all the time. What has to be remembered is almost every camera in use today doesn't have the native resolution for a pixel crisp banner print.
However here are a few things to remember, magnifying an image that large will make shallow DoF appear more shallow, so shoot a little deeper (stopped down) than you would otherwise (light permitting).
Shoot at a reasonably low ISO, and don't feel like a larger format will save you here, if you are stopped down to get more in focus, larger formats will simply have to stop down more and raise their ISO accordingly. But don;t be wasting light with 1/500 sec shutterspeeds at ISO 1600 when people posing can easily be shot at 1/100. That will keep more of the bite in the image.
Use your primes, they are simply sharper overall and will help that bite.
Production notes: Make sure you upres your image in an image editing software before placing it in artwork. This is a crucial step as many printers will simply scale in layout software which will dramatically reduce the final quality. Scale generally to the final output size at about 150-200 dpi (banner printers are not 300dpi photo printers and do not benefit from the resolution plus the materials they use also are not very high quality). Make sure you do your noise reduction step lightly in RAW, do a slight noise reduction during the upressing and a final sharpening step viewing your file at about 60% on screen until you see a tiny bit of "bite" in the detail you are trying to bring out.
Hope that helps, and remember to work with your subjects, direct them when needed.  Oh, one final note, shooting for print make sure you are framing well, if th ebanner is very wide use you 16:9 setting on the camera to make sure you are framing in a way that keeps your subjects in the final print, the same for a square print, take advantage of the 1:1 aspect ratio to ensure good framing.
Best of luck!
MikeF15
Hello Ab
Thank you very much for all of these tips! Excellent idea with shooting to print size (16:9, etc) never would have thought of that! Lol
also, yes they will be posed so I can afford slower SS and better ISO as well! I will definitely use the primes!
cheers to you! This is a great forum with excellent advice!
thanks again everyone!
regards
Mike F
Terrible Photographer
Terrible Photographer Senior Member • Posts: 1,454
Cheers
Mike F
Should be fine unless these are going to be viewed from somewhat close. You’re basically printing a 24x36 and then chopping it.
I would personally use a camera with a 3:2 ratio sensor to minimize resolution loss via cropping. This would be a good justification for using something like a D810/5DS/A7R3 type camera.
 Terrible Photographer's gear list:Terrible Photographer's gear list
Nikon Z6 Nikon Z9 Nikon Z30 Nikon PC-E Micro-Nikkor 85mm f/2.8D Nikon Z 50mm F1.8 +8 more
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,901
I enlarge some of my Olympus SH-1 pocket zoom (16 MP) pictures x3 for 33x23 inch prints. My visitors find no fault with them, standing two feet away. But my E-M10 Mark II (16 MP) pictures will tolerate scrutiny with a magnifier.
I don't think you have to worry about the suitability and quality of your gear.
In situ, you will have to work your gear on auto pilot, like - can you work it when surrounded by people whose last priority is blinking pictures?
I say this, because I have to regularly do rental pictures, with the out-going tenants, my business partner, and a handyman, messing around in my picture area.
For three months after I got the E-M10 Mark II, I was still using my pocket zoom in those situations, because I did not have to dive into the menu for every second shot. I could concentrate on getting my companions out of the picture, and looking out for domestic implements being moved away.
Henry
Henry Falkner - E-M10 Mark II, SH-1, SH-50, SP-570UZ
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
