Guess what... it was supermoon day :)
Started Feb 20, 2019 | Photos
(unknown member) Veteran Member • Posts: 3,098
17
From yesterday in Amsterdam:
Supermoon above the Basilica of St. Nicholas in Amsterdam
Supermoon just before it disappears behind the Amsterdam skyline.
A new supermoon rising again in the evening behind the Amsterdam Tower. Guess which city?
Starting to have fun shooting the moon!
Comment & critique:
Mark9473 Veteran Member • Posts: 6,428
Re: Guess what... it was supermoon day :)
Excellent! Especially the first two are really nice. Do you have one taken just a minute or so before the second image?
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
OP (unknown member) Veteran Member • Posts: 3,098
About 2 minutes before (I believe I have other ones as well, but not available right now on Flickr):
Is this what you were looking for?
Jrsilva00
Jrsilva00 Regular Member • Posts: 229
Well done!!
Beautiful compositions.
I like both, but the one with the reddish background is my favorite.
 Jrsilva00's gear list:Jrsilva00's gear list
Panasonic Lumix DMC-GX1 Olympus E-PL7 Olympus E-M5 II Olympus OM-D E-M10 II Sigma 30mm F1.4 for Micro Four Thirds +1 more
Yes, thanks, nice!
Mark
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
I like the first two! Any hint how are both moon and building in focus? Two different images stacked?
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Easy. Single image!
I used a DoF table. I focussed on the moon. Used the DoF table to figure out an aperture that allowed me a reasonable ISO, gave me a fast enough shutter speed for maximum zoom (210mm) for the moon to not display motion blur and gave me a distance to the skyline that more or less matched the distance from the point were I was planning to take my images from!
I have some DoF table apps but I believe I used this site this time: https://www.photopills.com/calculators/dof-table
Note then when you use a long tele, like the zoom factor I used or even longer, you can see the moon moving in your viewfinder... pretty fast... so the longer your lens... the faster shutter speed you need. To see the moon moving... a professional photographer was at the same spot shooting some real time video's... he posted them on instagram : https://www.instagram.com/albertdrosphotography/
He also has a some really great images from one day earlier at the same spot, with just some other weather circumstances... but his images are in another league!
Just a small follow up on the previous answer.
The third image, with the red tower, I do believe you can see that the tower in not as crisp as the skyline in the other pictures! That was because it was actually to close for the aperture I chose. In all images I choose f6.3. Larger would mean cranking up the ISO, but the DR and pushing shades/highlight recovery are not the strongpoints of m43 so I wanted to prevent that. I exposed for the moon in this image to retain some level of detail, but that meant the tower was underexposed and I new I had to bring it back a bit in post. So I needed the lowest ISO possible.
And of course I also wanted to prevent diffraction to play a big role. With this lens at max zoom (and teleconverter) it already kicks in at f5.6.
So... a lot to consider... but with a little prepwork, and figuring stuff out before hand... you can get more than decent results.
spike29 Senior Member • Posts: 2,471
now i kind of regret i didn't go out side monday..... (looked at the northside and it was clouded so i thought no clear image so back to dinner and the bench with a espresso....)
Nice and good framing first two,  was that a morning just after breakfast shot?
The angle is somewhere around those stairs (briks) acros the end of the single...
last one nice, would be funny if you got it just on top of the "Shell stick.."
knowledge is addictive, every time i get some i want more.....
(If i can remember 1/1000 of everything i learned/read in the past i will be happy as a monky with........)
 spike29's gear list:spike29's gear list
Fujifilm FinePix F70EXR Panasonic Lumix DMC-FZ200 Panasonic G85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
svein wilhelm kristiansen Regular Member • Posts: 184
Brilliant pictures!  Who said microfourthird is useless?
svein wilhelm
 svein wilhelm kristiansen's gear list:svein wilhelm kristiansen's gear list
Canon EOS 550D Pentax K-r Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GF7 +14 more
There was a pretty clear sky, it had been raining earlier in the night, but at the right moment, no clouds.
Did not have breakfast, was in position just past 6AM... way to soon as it turned out! It only got interesting more then an hour later!
I was standing next to Nemo on the Oosterdok. And I was moving around between the van der Veldebrug and the wooden jetty to reposition a couple of times.
Yes, tried it, but just misjudged it and there wasn't time anymore to move a bit and compose and focus again.
19 march a next chance... but I have not looked yet at the timeschedule and the location of the moon.
Good luck if you are able to give it a go next time!
This is the best effort to get the moon pinned on top of the tower.
Close... but no cigar...
Yeah... it is crap of course 😁
Joking aside, poeple who have a low noise tolerance probably don't like these shots, but would only have done marginally better with a larger sensor, because for the same DoF and shutterspeed, they would had to stop down more and increase the ISO. I do believe the results might have been cleaner, and note that I did not use any noise reduction in post for these images, and larger sensors would probably have marginally cleaner images and a little bit better DR which would be very helpfull in preserving detail in the darker areas and moon together!
But for me... it is good enough, these will print nicely, especially with some additional cleanup.
Ah exact on the other side.
yes thanks, it's a Tuesday , so hopefully not to early in the afternoon.
(your attempt was close!  indeed almost. i give you a nine. 😀
Sudaca Contributing Member • Posts: 819
I would have been out to take a few photos...
But it was -35C here in northern SK - Canada
maybe next time...
Nice shots though!!!
 Sudaca's gear list:Sudaca's gear list
Fujifilm X-T2 Panasonic GH5 Olympus M.Zuiko Digital ED 12mm 1:2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
