Small camera for viewfinder
Started Feb 17, 2019 | Discussions
msar Junior Member • Posts: 31
Hello,
I'm working on a hobby project and need to fit a tiny camera to the viewfinder on my camera for remote viewing. The camera needs to be placed fairly close to the viewfinder to save space. I have not bought it yet and I need to know if it will work optically.
The cameras focuses from 1 m to infinity and have a h fov of 62 degress and a v fov of 49 degrees. Basically can I get a sharp picture if placed closely to the viewfinder? Say, from 0cm to 5cm. The optics is much smaller than the viewfinder.
Thanks.
 msar's gear list:msar's gear list
Nikon D7200 Nikon Z6 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II Sigma 150-600mm F5-6.3 DG OS HSM | S Sigma 150-600mm F5-6.3 | C +2 more
Johannes Zander Regular Member • Posts: 467
Re: Small camera for viewfinder
Why don't you use the a/v port on the camera? Is much simpler.
 Johannes Zander's gear list:Johannes Zander's gear list
Nikon 1 V1 Nikon D4S Nikon Z6 II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24mm f/1.4G ED +21 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
msar wrote:
Hello,
I'm assuming you're talking about something like an old SLR that you want to remotely view through the viewfinder... if it has one, using the camera's video out makes much more sense.
Typical optical viewfinders are somewhat adjustable, but have the image appear to be about 25 feet away. If so, you need a camera that can focus that far away. A good cheap answer would be a $3 USB webcam -- pick one with a convenient form factor. Alternatively, there are USB Endoscope cameras that are tiny, but they tend to be designed for closer focus. Of course, USB is only good for up to about 10 feet.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
msar wrote:
Hello,
Thanks.
How about something like this:
http://argraph.com/Zigview/page1/Zigview_page1.htm
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
OP msar Junior Member • Posts: 31
ProfHankD wrote:
msar wrote:
Hello,
The problem with that approach is that the mirror has to be in up position. And the camera's sensor has to be on all the time and that takes more power than a small USB camera. Plus there will be a lag when you trigger the camera.
Heritage Cameras wrote:
msar wrote:
Hello,
Thanks.
Interesting, thanks for the link!
LeeP 416 New Member • Posts: 1
I tries something similar when I was doing a lot of macro shooting with a body that had no video out. Trying to look through the viewfinder frequently necessitated turning myself into a human pretzel and I'm not very flexible any more .
My solution was to mount the camera body to a piece of wood with a channel routed through the center to allow a small video camera to be shimmed to the height of the viewfinder. By varying the distance of the video camera to the viewfinder and trying different levels of zoom I was able to get a viewable  image which I then routed to a 12 volt monitor. I could also imagine using a wireless POV system designed for drone flights. Hope this gives you some ideas.
