how to connect and transfer m100 to mac over wifi raws?
Started Feb 15, 2019 | Discussions
Psxpetey Forum Member • Posts: 83
I've seen a few people saying they can send raws over wifi to their mac , I've downloaded image utility and a bunch of others and connected to canon image connect and I still cannot send raws does anyone have a really good guide?
Canon EOS M100
Anthony Milton Regular Member • Posts: 271
Re: how to connect and transfer m100 to mac over wifi raws?
Why bother when you can pop your SD card into the slot in the back of a Mac ,or if it doesn't have one, use a card reader.
 Anthony Milton's gear list:Anthony Milton's gear list
Canon EOS M50 Canon EF 24mm f/2.8 Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm F4L USM Canon EF 100mm F2.8L Macro IS USM +5 more
OP Psxpetey Forum Member • Posts: 83
cause I was in mexico and didnt have one? stupid answer tbh however I did find a solution that worked over wifi and it ws available on mac
mouzhik
mouzhik Regular Member • Posts: 404
Why don't you share your solution then?
 mouzhik's gear list:mouzhik's gear list
Canon G1 X III Ricoh GR III Canon EOS 5D Mark II Canon EOS Rebel SL1 Canon EOS M6 +13 more
canon image transfer utility 1.2.6.1 you can configure it to send directly to computer with the the m100. you click on image sync in your camera while you have it running. I just double checked it and it still sends raws directly to my Mac over wifi, slow though. its a set and forget kind of app. I downloaded about 300 images in Mexico to edit them took a couple hours. I wouldn't use it for my main way of doing things but its beast in a pinch
https://in.canon/en/support/0200576302/1
hopefully this comes up in google for other people who search it
canon m100 raws over wifi to pc and mac
nickolas84 Regular Member • Posts: 157
Bump!
Is this still valid?
Anything newer/better?
One needs to register to use the app mentioned and the webpage to register seems to be out of date since March 2020.
you can use the dmg you dont need to register for a website
