Pany Lenses on Oly EM-1 mk II
Started Feb 11, 2019 | Discussions
GDB Contributing Member • Posts: 984
I love my Pany G7 but I want to go back to BIF shots (like I used to with my old Canon 7D).  The G7 as most know, sucks really bad at BIFs.  I am drawn to the BIF-tested Oly EM-1 mark II but want to know if the following lenses will work with the OLY:
Pany 100-400
Oly 9-18
Pany 14-140 (ver 1)
Thanks.
Gary
 GDB's gear list:GDB's gear list
Sony RX10 IV Canon EOS 7D Canon EOS Rebel SL1 Panasonic Lumix DMC-G7 Canon EF-S 15-85mm f/3.5-5.6 IS USM +4 more
HRC2016 Veteran Member • Posts: 6,874
Re: Pany Lenses on Oly EM-1 mk II
Pany 100-400
Oly 9-18
Pany 14-140 (ver 1)
Thanks.
Gary
There have been many report's of the Panny 100-400 not fitting well  on the Oly EM1.2. I encountered five copies that did not work on my body and/or store demo bodies
By "not fitting well" I mean requiring more torque than usual and leaving metal shavings inside the body. Some users aren't bothered by this. If you're considering this lens I'd recommend buying in person, or at least having a favorable return policy.  This will also allow you to determine if the zoom ring is too tight (many reports of this, and I encountered it, too).
If you're looking for a long range, the Oly 75-300 is great. Nice and light for traveling, and plays well.
Oly 9-18 works fine.
I can't speak for the Panny 14-140 that you mentioned.
If you're looking for a great zoom the Oly 12-100 is phenomenal. It is worth its price.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
stateit
stateit Senior Member • Posts: 1,741
No Pro Capture Low with Panny lenses
ProCap Low is greyed out with non-Olympus lenses. But you can use Procap High.
ProCap Low frame rate is where it seeks focus each shot. Procap High frame rate is where the focus doesn't change from the first shot.
'Normal' high and low burst shots are of course available with non-Olympus lenses. But the ProCapture facility is simply astounding.
Foto4x4 Veteran Member • Posts: 4,062
Pany 100-400
Oly 9-18
Pany 14-140 (ver 1)
Thanks.
Gary
Gary, I have the PL100-400 and use with my EM1.2. It’s a great combination. I use the lens’ built in IS which is terrific. I have had no issue with the mount as mentioned above nor stiff zoom which may be due to some folks forcing the zoom when the lock ring is not fully disengaged.
Quote: “If your pictures aren’t good enough, you’re not close enough.”, Robert Capa
Kszchopstix Contributing Member • Posts: 527
I own the panasonic 100-400 and got it second hand when i was in Japan. it has a stiff barrel on cold days. On warm days its fine.
It works well on both my Pen F and even better on my em1 mkii in Autofocus capabilities and handling.
It has been noted that the weather sealing gasket on the PL 100-400 is not compatible with olympus bodies and this much is true. On a heavy rainy day I have seen some water intrusion onto the mount but this is during heavy rainfall. other than that its a stellar performer.
 Kszchopstix's gear list:Kszchopstix's gear list
Panasonic LX100 II Olympus E-M1 II Pentax KP Pentax smc DA 15mm F4 ED AL Limited Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II +12 more
