Best lens hood for 28mm 2.8 IS on APS-C?
Started Feb 9, 2019 | Discussions
Jim144 Regular Member • Posts: 213
Hi, I've just bought the 28mm f2.8 IS with a 58mm thread.
Oddly, the EW-63II hood that I use on the 28mm f1.8 doesn't work, even though they both have a 58mm thread. Have Canon changed the fitting?
Anyway, is there a better hood for the f2.8 when used on an APC-C body? Thanks for any suggestions!
msowsun
msowsun Contributing Member • Posts: 667
Re: Best lens hood for 28mm 2.8 IS on APS-C?
The EF 28mm f/2.8 IS USM uses a bayonet mount lens hood that has nothing to do with the 58mm size of the filter thread. The correct lens hood for that lens is the EW-65B.  (the bayonet mount is approx 65mm)
This hood also fits the EF 24mm f/2.8 IS USM. This hood is really optimized for Full Frame cameras. I don know of any hood that will fit these lenses that is optimized for APS-C cameras.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D Canon EF 100mm f/2.0 USM +24 more
Microprism Contributing Member • Posts: 646
I use this same lens as my normal lens on a M6. Since the field of view is about the same as a normal lens I use a 58mm screw in lens hood designed for a normal lens. It works fine other than the extra effort involved when changing filters.
As a compromise between size, weight, speed, IQ and IS I haven't found any lens I like better.
 Microprism's gear list:Microprism's gear list
Canon EOS 5D Canon EOS 7D Canon EOS M3 Canon EOS M6 Canon EF 50mm F1.4 USM +20 more
charlieY Regular Member • Posts: 419
 charlieY's gear list:charlieY's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM +4 more
J A C S
J A C S Forum Pro • Posts: 15,895
You may want to consider a collapsible rubber hood. Not much mechanical protection though.
Using a hard lens hood definitely extends the lifespan of my filters. They rarely get scratched with the hood as protection.
