Canon 4000D the camera made out of dirt
Started Feb 4, 2019 | Questions
simplyterrell New Member • Posts: 4
So here's my situation I see now the level of trash the canon 4000D is. Ive been tricked into buying but right now I'm going to go with it. Sorry for the rage sentences. My cannon eos 4000D when connected to my MacBook Pro from Mid 2012 wont show on my computer. What is the fix for this situation?
Canon EOS 4000D
Ray UK Contributing Member • Posts: 977
Re: Canon 4000D the camera made out of dirt
12
It would be much better if you made a post asking why your mac doesn't connect with your camera rather than just starting with an abusive statement.
Photography is meant to be a relaxing hobby, I'm not sure it will work for you in your present state of mind.
benjilafouine Veteran Member • Posts: 3,875
As I always say in these situations is to try it on a different computer (Windows of Mac). Just plug it at a neighbor's or friend's computer and you will know right away if there is a camera and/or wire problem. Can't you just use the wifi with you Mac?
Why make it simple when it can be complicated?
Benji
 benjilafouine's gear list:benjilafouine's gear list
Canon PowerShot S5 IS Canon PowerShot SX110 IS Panasonic Lumix DMC-FZ35 Canon PowerShot G16 Canon EOS 40D +12 more
OP simplyterrell New Member • Posts: 4
So here's the deal I'm looking for video which I know now this camera is not best for considering it doesn't even have a internal speaker. I tried to connect on a window computer via cable no connection. I now know that canon 4000D are not compatible with MacOS Mojave which is dumb since they both came out last year around the same time. Photography was born out of more than just peace. Thinking before the camera times like picasso he was was one Mad dude that's life right now for me. So I'm trying to now figure out what cameras are compatible with MacOs Mojave 10.14.3 after update now. Wifi won't work whens it's non compatible.
Misdirected the comments but camera is not compatible with mojave according to the operating system list
https://www.canon.co.uk/support/consumer_products/products/cameras/digital_slr/eos-4000d.aspx?type=drivers&language=&os=macOS%2010.14%20(Mojave)
Which is terrible so I need to get a new Canon that is I'm not downgrading because the 2012 macbook on high sierra is completely trash now so that's no way a option.
I need to know what Canon Cameras are compatible with mojave 10.14.3
Ive found the answer for this setup the only option is to use SD card and manually pick files out of image capture this is so very dumb that 5 years later still this is the option for "uncompatibility". But that's the answer I'm getting a 1300 eventually lesson learned.
The fact that you can't see the camera on a Windows computer with the cable is puzzling to say the least. That would be a show stopper for me. You do understand that the camera must turned on to be visible in Windows ("This PC") and from experience, if you don't use it quickly, your camera will turn itself off, cutting the link. If you all did that correctly, I would question the camera itself (like a defective USB port). And I have never seen a single Canon camera not working with Windows 10 with a directly attached USB cable.
Of course, as you said on your other post, connecting the card directly to your computer will work and by the way, this is still the fastest way to transfer images. I still use that method when I have a large number of pictures to transfer. But your USB connection must work.
Benji
Digirame Forum Pro • Posts: 41,857
You may want to get a Canon DSLR camera with dust sensor protection.  I don't take off my lenses, but occasionally I'll get these dust "bunnies".  But before I get a chance to consider cleaning the sensor, Canon's dust sensor protection removes them.
You might want to save up for something like a Canon SL2 (with dust sensor protection) instead of a Canon 1300D (assuming that is what you meant when you wrote 1300).  Read the reviews, before you decide.
rmexpress22 Senior Member • Posts: 2,304
I think this is more of a Mac error or user error rather than camera error.
If you have the wifi/NFC on, the USB connection will not work. Turn off wifi/NFC first, plug it in, and see if that works.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Stan in NH
Stan in NH Senior Member • Posts: 1,898
With a Mac, if you plug in an SD card you can import all the images on the card by simply selecting the “import all” option that is on the import window in Photos.  It's very simple and very fast.
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
RedFox88 Forum Pro • Posts: 30,738
use a card reader. No cable required
Card reader 🙄
IR1234 Senior Member • Posts: 1,891
EOS utility
No idea why you think it’s not compatible.
The connection is done through EOS Utility, and v3.8.x is compatible from 10.10.
It’s more likely that the canon.co.uk website isnt up to date, so try the canon US site.
 IR1234's gear list:IR1234's gear list
Canon EOS-1D Mark III Canon EOS-1Ds Canon EOS 400D Canon EOS 7D Canon EOS 550D +13 more
PMMG New Member • Posts: 2
Do you have your camera wifi turned on?
frst16 Regular Member • Posts: 181
i am sorry you feel disappointed in your purchase.
Firstly, as long as you haven’t taken loads of images some retailer will take back a camera which had under a certain shutter count and less than 14 days old (I have no idea where you are in the world or whether this even applies)
what do you want your camera for?  Why do you feel so cheated about your purchase?
All modern cameras are pretty capable, some are just suited to some things than others.
