Hockey with 135 f/2
Started Feb 3, 2019 | Photos
Dave
Dave Veteran Member • Posts: 6,231
Hockey with 135 f/2
My first time shooting hockey.  Through the glass from the stands.  Light was surprisingly good, though seams often got in the way.  Maybe a little underexposed?
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
Comment & critique:
BAK Forum Pro • Posts: 26,020
Re: Hockey with 135 f/2
You are not using your camera's exposure meter properly.
It is reading too much white, and then setting to camera so that white turns grey.
Manual exposure is your friend.
BAK
Macro guy
Macro guy Veteran Member • Posts: 6,069
I agree with BAK.  This is more or less what your pictures should look like:
 Macro guy's gear list:Macro guy's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.8 II Canon EF 70-200mm F4L IS USM +4 more
KiloHotelphoto Contributing Member • Posts: 770
I've tried shooting hockey a couple times and find it hard to shoot through the glass. None of the rinks around me have holes in the glass to shoot from and the glass is so dirty and scuffed up.
 KiloHotelphoto's gear list:KiloHotelphoto's gear list
Canon RF 600mm F4L Canon EOS R5 Canon EOS R3 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +4 more
Dave
OP Dave Veteran Member • Posts: 6,231
Thanks, Macro guy.  I see the improvement.  What tweaks did you make?  I shot in RAW and am using DPP.
Macro guy
All I did was played with the curves a bit.  I brought up the midtones and high mids and then I played with the highlights just a bit to keep the ice from completely washing out.  It took me all of 30 seconds to do it.  It wasn't anything special or difficult.
Dave
BAK
What about exposure compensation? I use that when shooting snow scenes and wish I'd thought of it Friday night.
Dave
Thanks.  I am still learning the curves and look forward to the point where using them is as instinctual for me as they have become for you.  I shot JPEG for years before finally making the leap to RAW, so at least they're now more readily available to me.
Macro guy
I think the point that BAK was making (with which I completely agree) is that your exposure compensation should have been done in camera. Whereas it's good to get comfortable with post processing and to be able to make at least rudimentary adjustments, I think it's a bad habit to rely on post processing to correct your mistakes. Post processing is there to enhance the image, not to correct it. If you use it to correct it, you'll find that you'll quickly run out of enhancement options.
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Yeah, looks about 1 stop underexposed. When I shoot sports under fixed lighting it is far better to shoot manual so the exposure doesn't drift all over the place. The meter will get fooled by the white ice, dark (or light) uniforms, illuminated advertising in the background, etc.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
OSP2017 Contributing Member • Posts: 542
Great points above on getting exposure right in camera. I shoot hockey in full manual and I expose for the faces. If you underexpose and try fixing things in post, there will be way too much noise.
Get a rubber hood similar to this one and shoot right against the glass to minimize reflections and glare:
https://www.bhphotovideo.com/c/product/11157-REG/B_W_65069613_72mm_Screw_In_Folding_Rubber.html
You also want to shoot from an angle where players are coming at you. There is barely any face visible in photo #1 and nothing in #4 (unless you were photographing #24). When Zamboni comes out, you can wash both sides of the door without getting on the ice; you can shoot from near the goal (more glass to wash) or from the goal line — depends on where the door is. Get some windshield washer fluid for this; Windex will freeze on the glass.
For post-processing, dehaze helps you bring photos closer to what they look like when shooting without the glass.
As you pan your lens, you get more ice or more dark seating in the shots, which makes the exposure comp less effective.
Once you set the camera manually, the players and ice will stay the same color / density.
BAK
BlueRay2 Forum Pro • Posts: 14,816
+1
indeed!
we are all one consciousness experiencing itself subjectively.
Dave
I agree with and appreciate everyone's advice. I'll find a face to use to set exposure for skin tone. A coach, official, or Zamboni driver may be my best option. Maybe create a chart in case I'd like to vary shutter speed? I'd like to hold ISO constant.
Unfortunately I don't have access to the glass or the ends. The arena where I shot (the only arena I'm likely to shoot in) has stands along one side of the ice - and not its full length. Not exactly an NHL venue (I leave my camera at home when I go to one of those).
The absence of faces was intentional; I don't publicly post pictures of people without their permission. I was sitting next to the parents of one of the players (who is a friend of my daughter's) and got some of her for them. I'll have the tools to do a better job next time.
Dave
While I too agree, I still want to learn to use the curves.  Such simple changes should be at my grasp to enhance properly-exposed images.  Does anyone have a book or website to recommend that will help me on my quest?
DPP Image Tone Curves
DPP Basic Adjustments
Macro guy
The curves are easy enough.  You can just play with them and look at the effect you're getting with various adjustments.  Eventually, you get a feel for it and it become second nature.
There was a site, that I thought was really good, but I don't remember its name.  It was retouching something.  Perhaps someone else could chime in.
photo_ion Regular Member • Posts: 165
Loved my 135 for junior hockey (used it on sony aps-c), I try to avoid shooting through glass, on most arenas easy task, blazing fast AF even in low light (used with adapter from sigma). For sure 70-200 is more versatile but twice the size and weight, used exclusively wide open and find it much sharper then 70-200 versions I tried
Dave
Is that outdoor/pond hockey? How did the 135 enjoy the cold?
What can I say, this particular arena tends to be pretty strict. Maybe I just haven't asked the right person yet.
Dave
Playtime it is, then.  Please share the site if you remember it (and if no one chimes in first).  Thanks for your help.
