Z6 Shutter Readout Speeds in Photo and Video
Started Feb 2, 2019 | Discussions
NAG3LT
NAG3LT Regular Member • Posts: 131
I've recently received my Z6 and decided to test how fast its shutter operates in different modes. I've used 24-70 f/4S lens, which was not optimal for the task, but I think the results are still close enough. I've used a signal generator generating sine wave at over 100 kHz and an analogue oscilloscope, based on method used by Jim Kasson.
Z6 readout times in photos
In photo modes across the whole FX frame I've measured:
  • Mechanical: 1/340 s
  • Silent 14-bit: 1/20 s
  • Silent 12-bit or JPEG only: 1/38 s
Using DX 1.5x or other crop modes increases speeds in accordance with smaller frame height. The values for electronic shutter readouts are similar to ones I've seen in Jim Kasson's testing and the ones mentioned in DPR's review .
Z6 readout times in video
In video modes:
  • 4K (FX): 1/45 s
  • 4K and 1080p (DX, 1.5x crop): 1/68 s
  • 1080p 100/120 FPS and slow-mo (FX): 1/190 s
  • 1080p 60/50/30/25/24 FPS (FX): 1/130 s
4K FX video result corresponds to reading 16:9 part of a whole sensor at 12-bit precision (1.185x vertical only crop). The readout time improvement going to 4K DX corresponds to extra 1.5x crop on top of that. 1080p DX on Z6 has the same readout performance as 4K DX.
On Z6, 1080p FX video seems to have the fastest readouts. 1080p 100+ FPS video is only available in FX mode.
 NAG3LT's gear list:NAG3LT's gear list
Nikon D750 Nikon D7200 Nikon Z6 Nikon Z6 II
Nikon Z6
beatboxa Veteran Member • Posts: 8,166
Re: Z6 Shutter Readout Speeds in Photo and Video
NAG3LT wrote:
In video modes:
  • 4K (FX): 1/45 s
Did you check all of the framerate modes individually? Readout is obviously different than lag, but here are the numbers I got for lag / latency times:
I may be wrong; but to me, this suggests they may also have different readout speeds in the different fps modes.
NAG3LT
OP NAG3LT Regular Member • Posts: 131
I have recorded individual measurements at different FPS and took a quick look at slopes. Based on that I've only did a full data analysis on one FPS value in each group that had same looking slopes.
When I get back to my PC, I'll check them again more precisely to check if I missed any tiny differences.
NAG3LT
I've checked my notes and looks like I skipped recording at 60p as it didn't look different on camera's LCD from 50p to me at the time. Your results are interesting, I might try doing display lag measurement as well, and hopefully will have time to do readout measurements of all FPS settings in the near future.
Thanks!  I'd be interested to see your results.
JimKasson
JimKasson Forum Pro • Posts: 37,017
Glad to see that approach is working for you.
Posted as a regular forum member.
https://blog.kasson.com
 JimKasson's gear list:JimKasson's gear list
Nikon Z7 Fujifilm GFX 100 Sony a7R IV Sony a9 II +1 more
