Anyone Use a Adaptor for Minolta MD lenses to K Mount body?
Started Jan 27, 2019 | Discussions
Sactojim Veteran Member • Posts: 9,105
I have a new (old stock) Quantaray 28-70 lens for Minolta and would like to use it on my K50. Do any of you have experience using the adaptor from either Fotodiox or K&F? Likes/dislikes and comments welcome. Thanks in advance.
Here's the Fotodiox adaptor: www.adorama.com/fdmdpkg.html?gclid=CjwKCAiAyrXiBRAjEiwATI95mdoE0GJRFjgtL1wLyDfafE_7Bp0-lu97YrUdzOwDEoe2GGVd0aEQjRoCYiAQAvD_BwE
Pentax K-50
wstruth
wstruth Regular Member • Posts: 336
Re: Anyone Use a Adaptor for Minolta MD lenses to K Mount body?
I have that EDIT - The Fotodiox adapter it works just fine and fits the lens and cameras well. Here are some shots with the Minolta MD 50 1.4. I really love the bokeh out of this lens. I do notice that I get a bit of a impressionistic glow on some images like the tulips shot below. i think it may have something to do with being wide open and the glass in the adapter creating the effect.  That one, like all of them, was processed in Lightroom with a few tweaks. But it can be very sharp. Here's a few images: some were on the K-1 and some on the KP :
Regards, Bill
 wstruth's gear list:wstruth's gear list
Ricoh GR II Canon G9 X Canon G7 X II Pentax K-1 Pentax KP +5 more
OP Sactojim Veteran Member • Posts: 9,105
Thanks Bill. THese look great and I like your creativity. I do use a Fotodiox adaptor ring with my Pentax Super Takumar 135mm on the K50 and it works great.
miles green
miles green Veteran Member • Posts: 7,827
Just stating the obvious, but this combo will have an equivalent focal length of 59-147mm. Handling will be awkard at best, and you haven't told us the aperture of the lens. The 40$ adaptor makes it not so interesting financially
It could be fun to play with these oldies, but i'd recommend you have a standard zoom for your K50 first.
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
Re: Pics of the Quantaray 28-70mm lens
Thanks Miles. I have some Pentax and Sigma modern lenses and enjoy them, but it's always fun to play with the older vintage lenses. My favorite has to be the Pentax Super Takumar 135mm..love the image quality rendition.
Yes, if I need to spend $40. (more than I paid for the lens) to make it work, I'll reconsider.
Pics of the lens
KentG Veteran Member • Posts: 4,825
I mean its possible to like the effects but most of these images would be called bad bokeh by the original definition of the term. Good bokeh is a smooth OOF background with no highlights to disturb the view of the subject. This is more like the view thru a mirror lens which is pretty much the definition of bad bokeh itself.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-3 II Pentax K-1 Canon EOS 80D Pentax smc DA 16-45mm F4 ED AL Sigma 120-300mm F2.8 EX DG HSM +7 more
wstruth
You should be fine B&H has the Fotodiox adapter for just under 40 bucks.
Regards, Bill
