Metz 58 AF-1 flash goes out with a BANG! [Take 2]
Started Jan 19, 2019 | Discussions
Bobolink
Bobolink Regular Member • Posts: 155
[This is my 2nd attempt at this post.  You may have noticed a previous post with the same title and no message body.  Somehow I posted before I got a chance to write my message; then I clicked "Edit Post", wrote my message, clicked "Post" and the message vanished into thin air.  Argh!  This time I got smart and re-wrote the whole thing in my favorite text editor.]
Has this ever happened to any of you?
I was doing a shoot of a music event with my K-3 and my trusty Metz 58 AF-1 flash.  I was standing on a chair shooting down at the people dancing, with my flash pointed at the ceiling for bounce, and suddenly - BANG!  It literally sounded like a firecracker.  RIP Metz 58 AF-1!
Well, my beloved Metz flash served me well for over 9 years, but now I can see what's new in the world of flashes for Pentax.  I'll be catching up on what the new top of the line Metz and Pentax flash models are.  Are there other flashes I should be checking out?  Also any other related opinions are welcome, including Metz vs Pentax, but of course I'm sure there are already plenty of threads on this, in this forum and elsewhere - and I'll be be doing my searches.
Cheers!
-Bob
 Bobolink's gear list:Bobolink's gear list
Pentax K-01 Pentax K-5 II Pentax K-5 IIs Pentax K-3 Pentax K-1 II +1 more
Pentax K-3
Oiche Senior Member • Posts: 2,045
Re: Metz 58 AF-1 flash goes out with a BANG! [Take 2]
What you heard is a popping capacitor, someone with electronics skills may be able to replace it but may have blown the circuit board to bits in the process. This happens with hi-fi components too where a re-cap can fix units.
If you were happy with the Metz and familiar with it why not just get another one? The Pentax flashes are more expensive but look at the used market.
 Oiche's gear list:Oiche's gear list
Pentax K-70 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 40mm F2.8 Limited Samyang 14mm F2.8 ED AS IF UMC HD Pentax DA 15mm F4 ED AL Limited +1 more
KPM2 Senior Member • Posts: 2,202
Hello Bobolink
First, sorry for my spelling, English is not my mother language.
two points:
1.) I use the same flash and my flash dropped
- the flash tube was cracked
- the zoom head was cracked
I thought that's it. Now I live in Germany, did called Metz and up's....a repair did cost my only 80 EUR...now the flash works great again.
2.) When you will replace it, you was in a way spoilt with this flash :
- it is a manual flash
- it's a TTL flash
-it's a P-TTL flash
- it's a P-TTL Master/Slave/Controller flash
-it's a P-TTL HSS flash
-it's a Auto flash, where it read out your setting of the cameras about aperture
- it's a strobe flash
- it's a flash with a second flash tube for fill flash when you bounce the main flash (BTW, I use a ND filter foil on the second flash tube, because for me personally, it's additional illumination was a little too strong for my taste, so that I reduced it via the ND filter-foil)
ok, when you use all this functions...it's hard to find an other non Metz flash, which can do that. Therefor, get an other Metz, maybe the AF 58-2 (when you can find one) or the momentary model, the 64 AF-1 digital. When you do not need all this functions, the new Pentax flashes are WR-flashes !
best regards KPM2
Pontoneer Veteran Member • Posts: 3,202
I agree with the others - stay with Metz .
I have been using Metz for close to 50 years : my first ever flash was a used Mecablitz 500 , which I used with my Rolleiflex TLR .
Later , I bought a new 45 CT5 , and had two of these which I used with my LX bodies for many years ; I just gave them away last year , still working , to a friend as I now have more flashes than I need .
I had two 58 AF1 in my Nikon kit at work - they were great flashes .
In my own Pentax kit , I have four 54 MZ-4 flashes , which I use wirelessly with my Cactus V6ii transceivers , both with my K-3 and my K-1 ; or I can just mount one straight on the camera - these are older and a little less powerful than the 58 series , but they still work for me .
The reason I gave away my two 45 CT-5 flashes is because I now have four 45 CL-4 Digital flashes - the great thing about them , compared to the smaller shoe mounted flashes is the bigger battery packs with six cells , allowing faster recycling , and if you are doing a lot of rapid fire shots ( I sometimes photograph events like dinners where you have to photograph all the guests arriving at the door - and you have to be quick . I usually have a space set out , with a couple of flashes set up on lighting stands , and using my Cactus transceivers , then get each couple or group of guests to step in , two shots and next please .
The 45 series can keep going without overheating , and have a battery pack which can be swapped over in a couple of seconds , rather than having to faff around with AA cells . I have something like 14 of the NiMh battery packs for my 45's and this has never left me short of power ( although I do also have four holders for each flash which can use standard AA cells ) and I have a lot of Duracell high capacity 'stay charged' rechargeable AA cells , which I feel are the best AA cells available .
I do have a number of Quantum Turbo external batteries , but you can end up with too much equipment and cables at a shoot sometimes , and just the flashes with their own batteries can be simpler .
I also have one Metz 70 MZ-5 , which is a fantastic , powerful flash , it's big , but it will also keep going through rapid fire sessions .
I have killed a few Metz 45 flashes , as have my colleagues - we work for the fire service and often have to photograph fire scenes , sometimes firefighting operations where there is a lot of water spraying about , and often going into buildings after the fire has been extinguished - again there is water dripping , high humidity and steam in the atmosphere - this can be in the winter when it is at the same time freezing cold , a very harsh environment for photo kit , and I've had my kit soaked on many occasions as well as steamed up , frozen etc : one of the things I like about my Pentax kit is that it withstands this treatment , my Nikon shooting colleagues have not been so fortunate .
I like Metz flashes - they're great .
With kind regards
Derek.
 Pontoneer's gear list:Pontoneer's gear list
Canon PowerShot G11 Pentax *ist D Pentax K-01 Pentax K-3 Pentax K-1 +42 more
TomWret
TomWret Veteran Member • Posts: 4,757
I would stay with Metz also. I have tried many, couldn't afford to pay much so I found the 44AF-2 digital and it has worked great on my K-3lls and my K1.
Tom W.
...a bad picture is like a missed putt, it's never your fault: My new site fineartamerica.com/profiles/3-thomas-whitehurst
 TomWret's gear list:TomWret's gear list
Epson Stylus Photo R3000 +6 more
Bobolink
OP Bobolink Regular Member • Posts: 155
Unfortunately, the capacitor took a few things with it.  If I look into it I see what looks like broken glass; and I hear it when I shake it.  So I'm pretty sure this flash is DOA.  Although I seriously doubt it, is there any chance that I'm wrong?
Not sure about glass, usually glass is only used for transparent fuses in electronics so you can see if the fuse has blown. Capacitors usually pop the tops off their cylindrical bodies but very high voltage ones used in flashes can 'explode'.
Ask Metz and see what they say, they might be able to do something.
EDIT: I googled glass capacitors and they do exist, I've just never used them in high-fi electronics. So could be the case!
Bobolink
Thanks to everyone who has replied so far.  I really appreciate your input!
I was already leaning towards getting another Metz flash, as I was quite happy overall with my 58 AF-1. You all seem to reinforce my feeling.  I think I'll probably get the Metz 64 AF-1; with even more power (sometimes I need it when I'm shooting fairly long distances with ceiling bounce).
I read all the reviews of the Metz 64 (as well as the Pentax AF540FGZ II) on B&H and Amazon.  A couple reviews did give me pause with the Metz 64.
Like this one on the B&H site:
"Known issues with light, 6 months to repair! UNACCEPTABLE! By Sebastian B.
VERIFIED BUYER Huge disappointment!  After reading reviews that the secondary light has a tendency to noisily explode, rendering the whole unit useless I thought I would be one of the ones that it won't happen to but boy was I wrong! ..."
Any of you ever heard of this issue?
Another more minor issue mentioned in several reviews, is complaints about the new touch screen interface, summed up well in the following quote:
"I don't like this touch screen for these reasons: 1. Uses battery power 2. Too many clicks to make changes 3. Keeps going back to home screen if you halt for 2-3 seconds during setup - very annoying..."
The 3rd complaint, about going back to the home screen if you pause too long, sounds very annoying - even maddening.  Anyway, I will search this forum for more posts in the Metz 64, but if any of you would like comment on the points I've raised here, please feel free!
Thanks!
-Bob
Hello Bobolink
OK, I did search in the German forums and did find nothing about it ! Also, my repair was done in a week (ok, I live in Germany). I really wonder about what he did wrote.
Thanks!
-Bob
I do not have this 64 - AF-1, I use the 58 AF-1, so, can't comment about the handling.
The handling of my 58 AF-1 is very good. Sometimes you can find the 58 AF-2 still in the shops. It's nearly the same flash as the AF-1 version. The 58 AF flashes has nearly the same power as the 64, but the 64 has a longer zoom head, therefore a higher guide number. At the same zoom head positions, the guide number is ca. the same.
BTW: Pontoneer wrote about the hammerhead series from Metz. I also have this flashes, the last one I bought was the 45 CL4 digital. This 45 CL-xx flashes are not built anymore. But when you like flash pictures and you need a powerful flash for wide angle lens....it's the best flash you can use then. I love my 45 CL4 digital. So when you look at used ones, and the prize is ok....maybe add them to your flashes. On the other hand, this 45 CL4 digital is a SCA-system flash and this SCA system do not get an update for the K1.
best regards  KPM2
Bobolink
Thanks KPM2 for your reply,
OK, I won't worry about the one report of the Metz 64 AF-1 blowing up; it seems that if you read reviews on just about anything you'll always find a few horror stories.
My biggest concern is the menu interface that resets to the home screen after 3 seconds of inactivity. This seems like something that could drive me crazy.
I'm also concerned about several reports of the battery compartment being poorly designed; including a report of batteries falling out, rendering the unit inoperable (with batteries).
I'll start a new thread on these concerns so more people will see what I'm currently asking.
Cheers!
-Bob
MNBob Regular Member • Posts: 283
I have the 64 AF-1, no problems with it, the batteries do not fall out (at least the ones I use). Yes, the display times out in a short time, but even with occasional frustration about that, changing the settings (not done often), is no doubt faster than other systems, so no real complaint. It works very well with my K-1 and I am quite happy with it
Bob
