GX80 but with Phase detect af?
Started Jan 17, 2019 | Discussions
Ru55 Junior Member • Posts: 40
Hopefully I can get someone’s advice here.
My current gear is as follows:
gx80
Panasonic 20mm 1.7
Olympus 45mm 1.8
Panasonic 14-42 first gen kit lens
I really enjoy my current setup. I like using prime lens for low light - being able to get a high FPS without needing a flash. I also like them for shallow dof sometimes.
However sometimes I just don’t get focus quick enough with moving subjects (young children) - because of the contrast detection system and end up losing out on a moment that I’d love to capture.
what I’d love to know is, what is the cheapest way to move to a phase detect camera with two equivalent prime lenses to what I already have.
I say cheap as the kits above cost approx £750 (not including the old kit lens). I’m looking for similar budget.
I shoot a mix of photo and video.
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 II ASPH
Skeeterbytes Forum Pro • Posts: 23,186
Re: GX80 but with Phase detect af?
Clean copy E-M1 and keep your current lenses, you're there.
Good luck!
Rick
JakeJY Veteran Member • Posts: 5,442
7
I don't know about the other lenses, but the 20mm is known for its slow focusing, so I doubt you will see much improvement if moving to a PDAF camera.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
AccursedSpermaceti Contributing Member • Posts: 554
5
gx80
Panasonic 20mm 1.7
Olympus 45mm 1.8
How do you know it's the lack of phase detection pixels?
You won't get a faster focussing camera in low light unless it's a g9. My gx80 focuses faster than my d750 in AFS. Tracking in AFC is where it is weak, but you don't need that for your use case.
Most likely it's your 20mm holding you back as it is the slowest focusing micro 4/3 lens. 15mm 1.7 works better for indoor candid family photos. Also your shutter speed is probably low - use a flash too.
Stick the 45mm on, put it in touch shutter release mode with the flash up and hit the screen when you want to grab a shot and it will capture it essentially instantly.
SkiHound Veteran Member • Posts: 3,939
I was basically going to suggest the same things. In SAF the GX85 is pretty dang fast. I own an E-M1i and think my GX9 is probably faster and more accurate in SAF. And frankly I don't find the E-M1i to much better in CAF. I've never noticed that the Olympus 45mm f/1.8 focuses slower than other lenses on my GX9 but Panasonic lenses that support DFD are kind of optimized for focusing with Panasonic bodies. The 20 is among the slowest, perhaps the slowest, focusing native m43 lenses and I don't believe it even supports SAF.  Short of an E-M1ii or G9 I don't think any m43 camera is going to be much or any better. A body with really good CAF tracking might help. But a lot of times this comes down to user error, experience, and unrealistic expectations.
s_grins
s_grins Forum Pro • Posts: 14,011
Phase detect AF? Not from Panasonic. Panasonic implements CDAF with added DFD technology.
Olympus does some high end bodies with PDAF for folks with legacy evolt lenses
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Your GX80 focuses better in low light than the EM1.1. I know, I tried. That's even one of the reasons why I replaced the EM1.1 with a G80. But you need a faster lens. I recently got the 15mm f1.7 and it's miles ahead of the 20mm. The kit lens might focus fast but it's slow so the camera focusing system gathers less light.
I can't talk about the EM1.2 but the mkI is not great in low light with C-af. Also live view becomes stuttery when light levels drop. Phase detection is not the be all and end all technology some seem to believe.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
steppenwolfer Senior Member • Posts: 1,153
As others already mentioned, lenses could be part of the problem. I used to have GX80 and even in AF-C it was not that bad - I did some testing photographing my dog with 14-140 mk2 lens and results were not that far behind Nikon D800 with 80-200 AFD lens.
(old thread here https://www.dpreview.com/forums/post/57916097)
For AFS Panasonic is way better than Nikon was, especially precision of focus. Main reason that I let go Nikon camera was inconsistency of AF - one photo was in focus and next just slightly off - never happens with Panasonics I have.
You could consider some other lens, such as Panasonic 15 1.7 or Olympus 25 1.8 (I am happy with Panasonic 25 1.4, but it is older generation and not that fast focusing lens).
Another possible solution (not sure what kind of photos are you trying to take) is using face detection focus set to AF-C. GX80 is quiet good for that also. I can get usable photos of my son even with older GM1 if camera is set that way (AF-C and face detection on). But keeper rate of G9 is naturally higher.
If you need phase AF you could also consider one of newer Sony RX10/RX100V + cameras. Their AF is very capable, also offer EYE AF option which works very good. But my RX100 v still does miss some photos. So, nothing is perfect.
 steppenwolfer's gear list:steppenwolfer's gear list
Sony RX100 V Nikon Z7 Nikon Z fc Nikon AP-F 70-300mm F4.5-5.6E Nikon Z 24-70mm F4 +8 more
OP Ru55 Junior Member • Posts: 40
Thanks for the reply.
How does em1 compare to gx80 for video?
how would the 20mm perform on the em1. I’m guessing gx80 and 20mm use dfd which I would then lose on the em1?
Thanks for reply. Yes the 20mm can be slow to focus. Strictly speaking i don’t think it’s always that it’s slow to focus, it’s just it’s slow to actually move the lens elements to get to focus.
the issue I have is more when the contrast system just can’t cope or keep up with moving subjects, especially when they are moving towards the camera. I think phase detect would cope better. I don’t have experience of current phase detect cameras though to compare. I used to have a Sony APS-C phase detect so I have a bit of a reference point.
gx80
Panasonic 20mm 1.7
Olympus 45mm 1.8
Hi Sion,
thanks for for the reply. I’m guessing it’s the contrast detection. Let me give you a scenario. I have focus, then the subject (young child) moves closer to the camera (more sort of back and forth movement) . I half press to lock focus and the lens will move through the full range and not lock. I sort of feel it’s not getting a constant amount of contrast in the scene to decide what to do - if that makes sense.
yes I have to use a slow-ish shutter speed because when I do lock focus I like to take a high amount of quickly successive photos due to the “action” and expressions that are rapidly changing!
Has anyone moved to an em1 and noticed a significant difference in focus of moving subjects, particularly subjects moving towards the camera?
Thanks for the reply. From what your saying the em1 wouldn’t give me any advantage but maybe a 15mm would. Any reason to keep the 20mm if I was to purchase a 15mm?
maybe this is the wrong forum but what about if I sold everything and started with a new system, body plus two primes in similar focal length. Does another system offer far superior focus speeds of subjects with the movement I describe?
Thanks for the reply. Is that the main advantage then of the pdaf in Olympus em1 for legacy lenses?
Yes it might be my experience and expectations. In the situation I describe I normally set the aperture to 1.7/1.8, iso to 800, single small box focus area in the middle of the screen, no flash. Normally this gives a shutter in the region of 120/160+.
Any advice on this?
s_grins
The other advantage was - E-M1 was the very first M43 from Oly with built-in EVF
To be honest I'm not enthused with the E-M1 video AF, which tends to "breathe" rather than locking and following a moving subject. The M1ii is much better, plus 4k, but even used will be at least 2x what the original model cost.
The 20 is my slowest-focusing m4/3 lens on every body I own and there's no miraculous transformation with the E-M1. I have not used it on a DfD body but that can't improve the time required to rack focus, only the time to lock. (The 45/1.8 you mentioned is very fast by comparison, with little wandering.)
It's worth exploring how Oly uses PDAF with m4/3 lenses, which is in tandem with CDAF but only in C-AF mode. And E-M1 C-AF has user settings for AF lock sensitivity, which is hugely useful for tricky settings and fast or irregular subject movement. (There are myriad other relevant settings.) IMHO the level of customizability makes the camera a potent option even after five years, but it takes time and experimentation to wring out the best performance.
(I found this article very helpful in comparing AF systems of the two E-M1 models.)
Rick
Even with m43 those apertures are not giving you much depth of field so if you're off just a little you'll probably see softness. I'd crank the iso to at least 1600 and perhaps 3200. Yes, more noise but I once heard an instructional video in which Jay Maisel said "a little noise never hurt a good photograph." I'd also try using a custom focus box rather than a single focal point. Maybe a 9x9 or something like that. I might also try CAF; might fail miserably in that light but... I'd also consider using a strobe. I'd highly recommend looking at Neil Van Niekirk's (SP? stuff). He shows how to bounce light and he tries to keep all direct flash light off the subject. He uses a really expensive flash modifier called a "black foamy thing" held onto his strobe by one of his daughters hair thingies. I use gaffers tab. You can get some really nice light with a strobe if used with just a little skill. I saw below that in a later post you asked about other systems. I have no experience. The Nikon D500 seems to be very highly regarded with respect to CAF and tracking. That's going to be considerably heavier and it's not cheap, though the price is not out of line for what that camera can seem to do. The AF system in some of the Sonys such as the A6300/6500 seem to have good reputations. Not recommending any of the above, just suggesting that if you want to start looking at other systems those might be some things to look at. I'd also suggest renting for a while. I'm just not sure that any technology is going to provide an infallible solution here. Capturing moving subjects in low light is just not that easy. And the more you try things and practice technique, the more success you'll often have. I can't buy the technology to ski like Mikaela Shiffrin and no matter what camera I'm using I probably will never capture the moment like Henri Cartier-Bressen.  Have fun and good luck.
alcelc
alcelc Forum Pro • Posts: 19,004
Lens issue?
20 is well known on its slow AF.
14~42 Mk-I is the worst kit lens IMHO.
For what you described your issue, use a 45 portrait lens to shoot moving kid might not always the best...
Albert
Profbx Forum Member • Posts: 57
Ru55 wrote:
gx80
Panasonic 20mm 1.7
Olympus 45mm 1.8
Hi Sion,
The em1.1 isn’t faster than the gx80 at all, so you would have to go to the em1.2. The em1.1 was great for the time but feels kinda slow now. That said, phase detect only helps out on certain subjects such as birds in flight and other situations that are different than your use. You have some great lenses, but they are not great choices for fast focus. My 14mm isn’t blazing fast but it kills the 20mm as far as focus speed, as well as my cheap 25mm. The 14-42 also isn’t a speed demon, and my little 12-32 is much faster.
if you got the em1.2 it would be better for fast moving subjects because of its other features such as it’s unreal burst shooting, etc, but, having lived with phase detect cameras for quite a while (was a Sony shooter for years, including the nex6 and the a77ii which both had phase detect and were the fastest for their time), the gx80’s focus is pretty darn quick and it’s issues aren’t based on its contrast system. The limitations you are facing are from the number of focus points, generation of DFD and the lenses you have. The g9 has the latest generation of focus and will be much faster even with contrast detect only. Otherwise, your only other option would be the Olympus em1.2, as the 1.1 won’t be as fast as your gx80, even with phase detect.
 Profbx's gear list:Profbx's gear list
Canon G1 X II Panasonic LX100 Canon G9 X Panasonic Lumix DMC-GX85 YI M1
alcelc
Generally on CAF (AF tracking) the traditional pdaf of dslr could do a better job at a lower cost. A mid range dslr (heard that those low end dslrs like D3XXX of Nikon or Rebels of Canon indeed not much better than CDAF of M43) might be the easiest solution. But you will have to start over again (body and lens) as used M43 gear might worth not much money... YMMV.
Albert
