Largely a waste of money
Started Jan 17, 2019 | User reviews
quadrox Senior Member • Posts: 1,382
6
I have owned this lens since around 2010. I read so much good about it I just had to get it over the 18-55 kit lens.
I used it on a 7D, and after getting this lens I took it out on a test shoot several times together with my brother 18-55 kit lens. I was not able to see any appreciable advantage on this lens in any way whatsoever.
AF performance was near identical, image quality too. True, at the long end and wide open you can get a bit of background separation for portraits and the like, but the effect is still quite minimal and not worth a lot on its own. Other than that, I found absolutely nothing that made me feel I had gotten my moneys worth compared to the kit lens. And then there is the dust issue too. My first copy even came pre-dusted, there was a lot of dust inside the lens - of course I returned it for a clean copy.
Compared to my 24-105* on my 5D2 the 17-55 seemed neither worse nor better, but the 5D II was full-frame with more resolution, so I ended up using it a lot more. I haven't used the 17-55 in ages.
So I cannot recommend this lens to anyone unless you really really need the f 2.8.
*Incidentally, the 24-105 was another purchase made in error, I should have gone straight for the 24-70 2.8, which I have now (the mark 2 that is).
 quadrox's gear list:quadrox's gear list
Canon EOS 5DS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +2 more
Canon EF-S 17-55mm f/2.8 IS USM
Zoom lens • Canon EF-S • 1242B002
Announced: Feb 21, 2006
quadrox's score
2.5
Average community score
3.6
Canon EF-S 17-55mm f/2.8 IS USM Canon EOS 5D Mark II Canon EOS 7D
mkphoto79 Regular Member • Posts: 450
Re: Largely a waste of money
13
That's surprising, mine is a night and day difference when compared to my 18-55 kit lens.  Much sharper, better colors, etc......at least in my opinion.
-Mike
 mkphoto79's gear list:mkphoto79's gear list
Canon PowerShot A590 IS Canon EOS 1200D Canon EF 300mm f/4.0L IS USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +5 more
J A C S
J A C S Forum Pro • Posts: 20,544
25
… which is the whole point...
Kaso Veteran Member • Posts: 4,488
And you have had plenty of time and opportunity to sell it.
Even money sitting in a box under the bed instead of sitting in the bank earning minimal interests is a waste of money.
(Personally, I prefer the Sigma 17-50mm f/2.8 and 17-70mm f/2.8-4 Contemporary to the Canon 17-55mm f/2.8.)
fishy wishy
fishy wishy Veteran Member • Posts: 9,358
There are a lot of 18-55 lenses, you need to state which generation it is. Even its year would help.
Dale Garman Senior Member • Posts: 1,025
In my experience the IQ was substantially better than the 17-40 L lens, especially sharpness.  Don't have the other lens you mention for comparison, but did find the 17-55 quite a nice lens for crop.
 Dale Garman's gear list:Dale Garman's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
BlueRay2 Forum Pro • Posts: 14,816
i have had very good experience with my 17-40 (on aps-c camera) and 24-105, just like my other "L" lenses but i stayed away from ef-s and 3rd party lenses (with exception of my zeiss lenses) like plague AND I DON'T REGRET IT
we are all one consciousness experiencing itself subjectively.
OP quadrox Senior Member • Posts: 1,382
That would have been the 18-55 that came with the 550D, from 2010 I think - I don't remember more details than that
And the point was not to say that the 17-55 has bad mage quality per see, although it did not entirely live up to my (very high) standards. The point is more that for the extra money over the 18-55 kit lens, you get very little in return. Most people will be far better off with the 18-55.
True, but I couldn't justify losing a backup lens for the very modest resale price it would bring. And now I probably wouldn't get much at all for it.
Rock and Rollei Senior Member • Posts: 2,916
I've never owned the 17-55, but I did borrow one for a couple of months some years ago. And I agree with you. Sure, if you pixel peep it's better. If you're shooting wide open, it's better. But if you're shooting at f8, you'll be hard pushed to spot any real world difference in the end product between this and any but the very first 18-55 (which was a dog).
In the end, I bought the 15-85 for crop, as it has a much more usable focal length range and to me was at least as sharp as the 17-55.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Duh...?!
Of course one buys a faster lens to get a faster lens. What I am saying is, that in this case a faster lens doesn't get you what you would usually expect from a faster lens.
I'm an extreme pixel peeper, and I shot with both this lens and the 18-55 in various conditions, and I could not for the life of me detect a difference in the image quality. And I never felt limited by the kit zoom in any way. I even once forgot to put the 17-55 in my bag, but still had the kit zoom. I was quite anxious about it actually, but at the end of the day I hadn't missed the 17-55 one bit and the images were fine.
So yes, that f 2.8 is going to allow you to keep shooting in slightly darker conditions if you are going to shoot wide open, that is undeniable, but it's not much of a difference really. And at the long end you get a (tiny) bit of background separation wide open. But if you expect really improved image quality, handling, build quality, or anything else for that money, your'e going to be extremely disappointed.
fishy wishy
8
Maybe not for a hobbyist who diddles about in daylight.
If you're an indoor event shooter, having two stops more light can make the world of difference, bringing you from horrible high isos into a usable range.
Two stops is a massive difference to get from a lens. Particularly if you achieve it for only a few hundred.
Your perspective is completely off. Fast apertures are not just about stylistic subtleties for the bored hobbyists.
Fair enough, I was understating the difference two stops can make in this post.
I was trying to highlight how little you get for your money, but I should have focussed on the following point instead of denying the light gathering capabilities:
I had expected a lot more than "just" sheer light gathering capability. We are talking a lens that is priced like L-glass, but without most of the traditional L-glass benefits, such as impressive resolution and build quality,
Not that many indoor event shooters shoot crop. I certainly don't. Those that do are probably shooting primes in most cases anyway.But regardless, that's not "most people".
The OP's contention is that for the majority of people, this lens doesn't make sense. I agree. That certainly doesn't mean that there aren't people for whom this is the perfect lens; clearly there are. Anyone who has to - or wants to - work at f2.8 or even f4 within this focal range will be well served by it. But buy it because you need it, not because everyone tells you it's the best choice on crop - for many, it isn't.
andrewsf Contributing Member • Posts: 618
Well I guess everyone is entitled to their opinion but I've always loved my 17-55 F/2.8, so much so I dropped about AUD$400 on it to get it fixed when the focus started playing up.
Obviously the 2.8 is great, combined with IS you can get shots in very dim light without a tripod. Very handy.
It's super sharp by F/4.0, comparable with my 70-200 F/2.8 IS II which is also decent.
The 7D is not the sharpest sensor in the world. I say that because pixel peeping the 17-55 on my 400D looked way sharper than pixel peeping on the 7D. The 7D seems to require a bit of extra sharpening to have that 1:1 sharpness.
But anyway, fair review, I just have my own perspective.
 andrewsf's gear list:andrewsf's gear list
Canon EOS 400D Canon EOS 7D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM +4 more
Yes, that expresses very well what I meant to say, thank you!
I created this review mostly to give potential buyers the chance to see another perspective. Also I am not saying that the 17-55 is bad per se, only that for much less money you can get almost as good with the kit zoom.
Your comments about the comparison with the legendary 70-200 and your remarks about sharpness on 7D have made me curious. I am going to perform some tests when I get the chance, though it won't be this week.
Thanks for your response, it has made me think
J A C S
quadrox wrote:
Duh...?!
How is your 18-55 at 55/2.8?
This is OK. Most people are not limited by their phones either.
Yep, just two stops at, say, 55mm. Like the difference between 200/4 and 200/2. Or 40/1.4 vs. the pancake 40/2.8.
You get improved IQ vs. something the kit cannot even do.
Those kit lenses are sharp, indeed but they are very very slow. It is not a big achievement to have sharp f/5.6-f/9 eq. lens. What more do you expect there? It is an achievement to get more light.
I owned those lenses, BTW. The kit lenses I owned had low contrast compared to the 17-55. It was very obvious.
Of course the kit zoom can't do f2.8, the question is what you get out of being able to do so. My verdict was: not enough, not for that kind of money.
Possibly, though ultimately I am unable to judge value for money on phones and what other reasons there might be to buy a more expensive phone.
When it comes to lenses however, I can clearly say from experience that the 17-55 does not give enough value for money (IMHO of course).
Really poor comparison. At longer focal lengths, more light for faster shutter speeds is much more critical, and the effect for background separation is more pronounced. Similarly, the range from 1.4 and 2.8 at 40mm is exactly where you begin to get useful background separation, whereas 2.8 might be better than 5.6, but just not enough.
A 2.8 lens should have greater IQ, and for the price, better build quality.
Well, maybe you had one of the worse kit lenses, my brothers copy had no issues keeping up with the 17-55.
J A C S
1-2 stops is huge.
So we can just stay with our phones then? I went FF precisely because getting better IQ or shallower DOF was not enough with crop - but one of my most used lenses is the 24-105/4 on FF. So you are saying that since it is not really f/2.8 or f/1.4, why not just have a f/5.6-f/9 zoom?
The 17-55 is not terribly sharp, this is true.
I had a few. It is very unlikely to have a few copies with worse contrast (overall one, like a veil over the image). When you shoot night images, they just fall apart. The 17-55 is basically an L lens aside from build quality. So is the 10-22, BTW.
The dust problem is a non-issue. You need the right screwdriver, take the front element off, blow the dust away and put it back (mark the position of the screws before that). It takes a few minutes.
