Fuji 56mm f1.2 or 16-55mm f2.8?
Started Jan 16, 2019 | Questions
charley5 Senior Member • Posts: 1,832
Hi Everyone:
I am new to Fuji cameras and lenses and I am having difficulty deciding between these two lenses. Mostly it will be used for travel photography. I take posed street shots. In my last photo excursion I took pictures of children at a slum in New Delhi and previous to that I took pictures of gypsy road workers in an encampment in a small Himalayan town. As I say, all were posed. I am less interested in spontaneous street shots.
My considerations:
The 16-55mm gives me a flexible focal range, is very sharp relative to other zoom lenses, and I can use it for the occasional landscape shots as well. Unfortunately it is heavy and thus less attractive as a travel lens.
The 56mm is a superb lens that is a little less heavy than the aforementioned zoom, and delivers excellent and natural quality. Downside is that in some situations I would like to have the flexibility of a zoom lens, particularly in my location relative to the subject, and in terms of the amount of background I wish to include.
Any thoughts? I am sure there are people who use these lenses and have opinions regarding the above.
Thanks!
-Charles
 charley5's gear list:charley5's gear list
Fujifilm X-H1 Zeiss Otus 55mm F1.4 Fujifilm 16-55mm F2.8R LM WR
Vic Chapman Forum Pro • Posts: 10,694
Re: Fuji 56mm f1.2 or 16-55mm f2.8?
As a travel lens 16-55mm f2.8.
Which body do you use?
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
markusw Senior Member • Posts: 1,705
The zoom gives you more flexibility, of course. But I am wondering why you do not consider a 35 f1.4 or a 23 f1.4?
..... Or a used 18-55mm + 56mm f1.2. When you get home, you can resell the 18-55 is necessary at little cost to you.
Vic
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 15,015
charley5 wrote:
Hi Everyone:
My considerations:
Thanks!
-Charles
If you are almost exclusively taking people shots in situations where subject isolation would be either helpful or a major requirement, then the 56/1.2 would be sort of a no-brainer.  However, for travel — particularly if you plan any other sorts of travel related photography as well — then the 16-55 would give you far more flexibility.  Unless all of your shots are staged, where you have control over subject distance, background, etc., travel photography often requires a range of different focal length, depending on the situation.  A fast zoom like the 16-55 is almost perfect for those situations.
Both lenses have some substance to them, with the 16-55 being about 50% heavier at 655g vs. 405g.  Having used both, I’m not sure I found the difference to be all that noticeable, but that’s an individual preference thing and something you’d have to judge for yourself by handling both lenses.  As primarily a zoom shooter, particularly for travel, the 16-55 would clearly be (and is) my choice for its versatility, but that doesn’t necessarily apply to your own preferences and needs.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-H1 Carl Zeiss Touit 2.8/12 Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
OP charley5 Senior Member • Posts: 1,832
I just got the X-T2.
I actually never thought about these. Hmm.
Yes, I am beginning to lean that way. Given that its quality is a notch above the kit lens, I think that is an added draw. Perhaps I shall buy the 56mm at a later date in case I do portrait work closer to home.
Bob Tullis
Bob Tullis Forum Pro • Posts: 38,265
As if you have a choice. . .
You buy one because you don't want to carry the other.
But you buy the other because sometimes it's more necessary, and you'll put up with the mass - but only if and when you have to.
It's just a matter of time until you, like the rest of us, realize that, save up, concoct a rationale that enables the indulgence, and gives in.
...Bob, NYC
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bob Tullis's gear list:Bob Tullis's gear list
Fujifilm X-H1 Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2
Re: As if you have a choice. . .
Yes, but the price for each is hefty, particularly for a Canadian that deals with a 33% exchange. That is why I need to give this some thought. Both would work well, but for different reasons.
Erik Baumgartner Senior Member • Posts: 1,515
If I was going to do what you describe, I’d go with the 16-55 or the 35 1.4 if was limited to a prime.
Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +1 more
Bob Tullis
Of course.
Anyways, it's a nice problem to have to flesh out.   I was going to suggest to get the zoom, because that's the practical first choice.
I don't care for hefting the 16-55 if I can help it, but that's not because it's not an awesome lens.    If I could only have one. . . it would be the 16-55, as much as I favor primes over zooms.
...Bob, NYC
yokken
yokken Regular Member • Posts: 199
The 56 isn't exactly a light lens. The 16-55 is heavier but not twice as heavy or anything. It is more versatile and you also get weather sealing. They're pretty close in price. The 16-55 is a good choice if you know you won't need the extra fast aperture.
 yokken's gear list:yokken's gear list
Fujifilm X100V Fujifilm X-E2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Bob, you sound very ambivalent, which is my state of mind right now.
Erik, that is the conclusion I am coming to as well.
Bob Tullis
heh. I'm that transparent, eh? The difference is - I've had more time to rationalize, save, and give in. Now it's a more immediate dilemma, a choice to be made every time I look at those lenses getting ready to go out.
May you too one day be so conflicted (or is it, afflicted?) [g]
...Bob, NYC
I will be going to a photo store to check out the weight of these lenses. I think that will help me decide!
-Charles
10sj03 Regular Member • Posts: 431
I have both. For your usage, 16-55mm.
Thanks. That seems to be the consensus.
Fazal Majid
Fazal Majid Senior Member • Posts: 1,876
I have both, and love both. If you are financially constrained, get the excellent 18-55 kit lens and the 56mm f/1.2. You will also appreciate the weight savings.
Fazal Majid (www.majid.info)
 Fazal Majid's gear list:Fazal Majid's gear list
Ricoh GR III Leica M10 Nikon Z7 Leica APO-Summicron-M 50mm f/2 ASPH Nikkor AF-S 300mm f/4E PF ED VR +29 more
