X-E3 Arca-Swiss compatible plate with battery access
Started Jan 14, 2019 | Discussions
k1ckdapro New Member • Posts: 9
Hi,
I finally went with an X-E3 as a second body to my X-T3. I don’t have it yet, but I was wondering if there is an Arca-Swiss compatible plate which leaves access to the battery / sd door. On my X-T3, I always leave my tripod plate attached and would like to know if this is also possible with the X-E3. I don’t think, however, that my Peak Design Standard Plate will fit without obstructing the batterydoor.
Many thanks in advance,
Fujifilm X-E3
FTOG Senior Member • Posts: 1,359
Re: X-E3 Arca-Swiss compatible plate with battery access
It might not be just a plate, but the MHG-XE3 grip will have an Arca Swiss compatible base plate (no vertical plate).
According to Fuji Rumours , there are also L plates by Kenro and "First2savvv", although I cannot comment on either, not having owned them.
A google search for "Fuji X-E3 L Bracket" will yield a variety of results, many of which are third party chinese products. The cheapest I found cost a mere 20 USD. Again, no experience with the product, though.
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
AndyH44
AndyH44 Veteran Member • Posts: 3,106
Meike makes one that works fine ...... Google it.
"The world doesn't exist to satisfy your expectations."
OP k1ckdapro New Member • Posts: 9
Thanks for your advice ! I just purchased the Meike MK-XE3G Metal Hand Grip.
DustyBin
DustyBin Contributing Member • Posts: 745
Just resurrecting this thread... any plate recommendations... I do NOT want a grip.
thanks!
 DustyBin's gear list:DustyBin's gear list
Sony a9 Sony a7C Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-300mm F4.5-5.6 G OSS +6 more
XEddieX Contributing Member • Posts: 766
thanks!
https://www.hejnarphotostore.com/mobile/Product.aspx?ProductCode=D025....
I've bought a arca-swiss lens foot replacement for my 50-140mm and they are good quality.
2x X-T2/VPB | Zeiss 12 ƒ2.8 | 16 ƒ1.4 | 35 ƒ1.4 | OM 50 ƒ1.2 | OM 50 ƒ2 macro | 90 ƒ2 | 18-55 ƒ2.8-4 | XF 16-55mm ƒ2.8 | XF 50-140 ƒ2.8 | RRS |
DustyBin
XEddieX wrote:
thanks!
Thanks.. that looks interesting.  What are the dimensions?  I'm in the UK, so can't buy that one, but maybe able to find something similar.
DustyBin wrote:
XEddieX wrote:
thanks!
Check on eBay to see if they ship to the UK.  From what I know, dim's are 2" x 1.5" x .375".
