A fantastic affordable camera you can still buy new from eBay
Started Jan 11, 2019 | User reviews
OP David Contributing Member • Posts: 695
Re: A fantastic affordable camera you can still buy new from eBay
epozar wrote:
VF-4 is expensive
Luckily mine came with the camera as part of the clearance deal I got from a dealer who was getting out of the Olympus line.  So essentially, I got the lens and VF-4 for slightly more than a lone body.  But I know that right now, the VF-4 is really pricy.
 David's gear list:David's gear list
Nikon Coolpix AW110 Panasonic ZS100 Olympus PEN E-P5 Olympus E-M5 II Olympus OM-D E-M1X +17 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: IBIS and Sigma 30mm f/2.8 ART
paul613 wrote:
on my E-P5, when I use the LCD, IBIS blurs the 1/15th- to 1/60th second shots I take with my Sigma 30/2.8. when I shut it off, handheld results are decently sharp at 1/30th and tack-sharp from 1/60th. Is this a known problem with the 30? Or maybe it's using the "10mm" setting that I set for my fisheye.
If the Sigma has lens contacts it should be telling the IBIS to go to 30mm setting and that focal length should appear on the screen.
If it is only that lens that behaves like that in the 30mm range then I would suspect the lens of doing something strange.
With my muddle of Olympus and Panasonic lenses (from 9mm up to 300mm) and the Samyang fisheye (IBIS set at 8mm for that), the E-P5 (two bodies) IBIS works fine for always about something more than 4 stops of stabilisation and sometimes 5 stops.
Make sure that the firmware is up to date and that zero second anti-shock is enabled and used.
Regards..... Guy
Alan Kett
Alan Kett Regular Member • Posts: 332
Hi all. Just wanted to kick in my 2 cents/pennyworth. I have way to many cameras, but I did see a deal on new/old E-P5 on US Ebay last week. $259US for a new E-P5 body. Couldn't resist and I picked one up.
It arrived yesterday, factory sealed, and I unpacked it this morning to charge it and set it up, so I've no more than half a dozen quick snaps to make sure it's working. I did have to update the firmware from 1.2 to 1.8, so that's how long it's sat around on some dealer's shelf.
I've never held a camera in the E-P series before, but I have to say that I just love the heft and feel of it. It feels very solid in-hand and the control layout feels good too.
I know this is old hat to a lot of you, but I do think this camera will get a lot of use going forward.
Alan
 Alan Kett's gear list:Alan Kett's gear list
Fujifilm X10 Panasonic FZ1000 Fujifilm X30 Panasonic ZS100 Sony a6000 +31 more
paul613
paul613 Senior Member • Posts: 1,894
a black E-P5 deserved black lenses
Congratulations, Alan. If the E-P5 will be your main camera, resist the urge to buy silver lenses. You'll be happier, I think, with black lenses, even if you must order the lens from abroad...as I recently did to obtain an Olympus 17mm f/2.8 pancake lens in black (for my white E-P5). I also recently ordered a BCL-0908 body cap lens in white. Both had to be ordered from Japan...as did my white E-P5 itself.
Paul S. in Maryland
 paul613's gear list:paul613's gear list
Olympus PEN E-P5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Sigma 30mm F2.8 DN | A Rokinon 8mm F3.5 Aspherical Fisheye (HD) +10 more
Alan
Alan,
I love my E-P5 and it is my main system camera for my photography pursuit.  Made amazing prints out of it and if I want to make even bigger prints, I use both my Panasonic Leica 25mm and use the 45mm to stitch to make even bigger prints.  All in all, it's one heck of a value camera and my E-P5 continues to work forever.  If my E-P5 fails then I'll just buy another one to replace it.
Guy Parsons
E-P5
They typically arrived even after a few years at V1.0, it depends upon the production run.
Alan
Update the firmware, enable zero second anti-shock in the custom menus, and then use it via the diamond mode in the shooting menu. I've never seen shock in either of my two E-P5 by doing that.
I have tried to better explain the menus so between my page and the user manual you may find some help. http://homepages.ihug.com.au/~parsog/olyepl1/56-ep5-custom-menus.html
It's a good camera and very likely my last M4/3 camera, it does all that I need.
Regards..... Guy
jimrpdx
jimrpdx Veteran Member • Posts: 3,956
Re: E-P5
David wrote:
An American seller has at least 10 (probably 20) black E-P5s, new in their sealed boxes, for $260 U.S. , with free shipping ..
Just ordered one last night, so much for that new 20/25mm prime in the next few months.
JimR east of Cathlamet - https://granitix.blogspot.com
G85 & µ43 stuff | K·50 & PK stuff
 jimrpdx's gear list:jimrpdx's gear list
Olympus E-M1 Sony a7 II Pentax K-S2 Pentax 18-50mm F4.5-5.6 Panasonic 12-60mm F3.5-5.6 OIS +2 more
paul613
Re: E-P5
Yes, I've just revisited your page, where I discovered something I had overlooked for almost 2 years: Those diamonds that denote which modes use 0-second anti-shuttershock. All the times that I've used the 2-second or 10-second timer, I'll bet I was using the non-diamond mode. Thanks, Guy, for your setup page.
Paul S. in Maryland
