a Mamiya Super 23 experiment
Jan 9, 2019
10
On this episode of Why Did He Do That, I play with another swap meet find - an all-black Mamiya Super 23 w/100/3.5 lens - unfortunately it had no grip, focusing screen, or film back. I made a quick camera obscura with an oiled sheet of paper mounted to act as some 'ground glass' and took some shots through it using my A7 II -> MC-11 -> Canon EF 50/2.5 macro focused on the paper grain at f/8. With the Super 23 sporting a 9cm x 6cm film plane, using a 100/3.5 lens on the Mamiya is roughly equivalent to using a 40/1.4 on a full frame camera.
It was kinda fun! However, I wouldn't want to be seen in public with this setup:
I wrapped the cameras and my head in a dark jacket when taking the images to get the maximum contrast out of my oiled paper. I know for a fact that I looked very hip doing it.
Mamiya 23's lens set to f/3.5 on my infinity-ish test scene with some positive vignetting added to roughly match f/8 image below. Hello, paper grain!
Mamiya 23's lens set to f/8. 1.6s shutter speed in the middle of the day... I guess that makes sense given that the 50/2.5 is also stopped down to f/8.
f/3.5 bokeh test - I had to use the camera's built-in bellows (nifty, right? could be fun to do some tilt-shift effects with this) to focus this close.
The lens doesn't seem half bad, but then again, I'm essentially only shooting it on oiled paper - if only I could try it on a 9cm x 6cm sensor with the pixel density of a D850... Does anyone have any high-DPI film scans taken with the Mamiya to share to satiate my curiosity?
Canon EOS 550D
Sony Alpha NEX-3N
A3000
Sony a7 II
YI M1
+2 more
Comment & critique:
