50mm 1.4 ZA vs Zeiss 55mm 1.8. Same light transmission ?
Started Jan 6, 2019 | Discussions
gwexou Contributing Member • Posts: 867
Dear all,
I have the Zeiss 55mm f1.8 but i'm looking for something brighter at night. I was looking at the 50mm f1.4 as an option, until I read a review saying that the light transmission is actually exactly the same, despite the 1.4 being much heavier and bigger.
Can anyone concur or deny ?
Thanks !
 gwexou's gear list:gwexou's gear list
Sony RX100 VI Sony a7R III Sigma 8mm F3.5 EX DG Circular Fisheye Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 55mm F1.8 +5 more
Karafuru Regular Member • Posts: 353
Re: 50mm 1.4 ZA vs Zeiss 55mm 1.8. Same light transmission ?
It helps if you specify the equipment used. Below examples as measured by DXOmark
 Karafuru's gear list:Karafuru's gear list
Sony a7 II Sony a6500 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS +5 more
jonpais
jonpais Senior Member • Posts: 2,990
Yeah, so perhaps a one-third stop advantage - meaning that things like bokeh, fringing and coma, as well as size and price are more significant. Here’s DPR’s assessment:
https://m.dpreview.com/reviews/comparative-review-sony-fe-50mm-f1-4-za-vs-55mm-f1-8-za/2
voronspb
voronspb Senior Member • Posts: 1,995
As a rule of thumb, the more optical elements has the lens, the more light is lost while passing through them. Sigma 50/1.4 loses the most light due to complicated design and probably the lesser coatings than Zeiss T*.
Vladimir Gorbunov
 voronspb's gear list:voronspb's gear list
Sony a6500 Sony a7 III Tamron 17-28mm F2.8 Di III RXD Sony FE 35mm F1.8 Tamron 70-180mm F2.8 Di III VXD +7 more
jonpais
I think
I forgot to mention that AF is faster with the 55mm as well.
upgrader Regular Member • Posts: 383
I would choose again and again the 50mm ZA just because of that Pop and its magical rendering. The 55mm has no chance here except sharpness. For my taste it has a very clinical output.
jonpais
We hear that a lot around here, but in practice, I'm not finding that to be true at all.
In fact, the 50mm looks far more detailed and 'clinical' in my video than the 55mm. So it depends entirely on how you shoot with them.
My sample footage shot with the 55mm looks 'dreamier' than the 50mm. hehe
Both fantastic lenses!
https://youtu.be/7JKMDW0XE5k
https://youtu.be/RSEZ3R7dXAk
RE Alpha
RE Alpha Contributing Member • Posts: 785
gwenhael appere wrote:
Dear all,
Thanks !
There has been a thread about these two lenses:
https://www.dpreview.com/forums/thread/4351755
Not exactly the same question, but might be useful to read as well.
 RE Alpha's gear list:RE Alpha's gear list
Sony a9 Sony a7R III Sony FE 24-70mm F4 OSS Sony FE 90mm F2.8 macro Sony FE 24-70mm F2.8 GM +6 more
OP gwexou Contributing Member • Posts: 867
Thanks, i completely forgot to check their tests !
Thanks, that's exactly what i'm thinking. Other aspects become deciding factors if the light transmission is more or less the same....
HFLM Senior Member • Posts: 1,976
I found the 50/1.4 to be clearly superior, we have two of them for weddings.
Compared to our copy of the 55/1.8, when we still had it, our 50s were sharper. But more importantly, the FE50 shows almost no CAs, the 55 is very prone to CAs, however. AF is quite good for an f1.4 lens, I was never let down by it even in dim light.
 HFLM's gear list:HFLM's gear list
Sony a9 Sony a7R III Sony a7 III
AcerK Junior Member • Posts: 25
When you edit your RAW photos you can do any "POP" you want... so sharpness, barrel distortion control, and flaring control are more important qualities than a characteristic of lens.
 AcerK's gear list:AcerK's gear list
Sony a7 III
