NX300 shooting mode problems
Started Jan 4, 2019 | Discussions
robyfor Regular Member • Posts: 368
I have been using NX300 for a few years and I am very satisfied with the photographic quality. This aspect makes me undecided about what to buy as a future successor. In the meantime I use it enthusiastically. A few problems have been born for a few weeks now. When I want to choose a shooting mode of type P, A, S, M, etc., in the display I do not see this mode that I have chosen but another. Sometimes after a few seconds it is automatically set to the chosen mode while at other times I have to switch off and on again and this is not always enough. This problem is annoying and I would like to try to solve it. I have the latest firmware. Has anyone ever had such problems and solved them? I also have Samsung NX3000 and has the same problem. Thank you
Samsung NX1000 - NX3000 - NX300. Lens: NX 20-50mm - 30mm f2 -
16mm F/2.4 - 45MM F/1.8 2D/3D - 18-55mm - 16-50mm - 50-200mm.
Sony HX90-Sony P200 - Fuji F30.
https://www.flickr.com/photos/137263652@N05/
Stop time with photography!
Roberto
Samsung NX3000 Samsung NX300M
Re: NX300 shooting mode problems
Unfortunately, everybody is facing the same issue with almost all of the NX cameras
Some claim that "warming" the jog helps, others say comoressed air helped, some used contact spray (I would think twice about that).
I solved it by being in M all the time
hugovlennart Regular Member • Posts: 151
Thats the made in china part of the camera
Sakisf Regular Member • Posts: 413
You can remove the backplate (easy on all models) and push the canned air or contacts spray directly under the dial if you are afraid of spreading. Will fix it for some time, then you do it again.
 Sakisf's gear list:Sakisf's gear list
Konica Minolta Maxxum 5D Samsung NX1000 Nikon Z7 Sigma 35mm F1.4 DG HSM Art Nikon AP-F 70-300mm F4.5-5.6E +10 more
