Sl2 improved in low light high iso over sl1?
Started Jan 4, 2019 | Questions
Easy Rider
Easy Rider Veteran Member • Posts: 8,236
I'm a street photographer. My 100d is great in good light but atrocious in low light for city night street photography. Iso 6400 is literally appalling and focus in low light even with my 24mm f2.8 stm is very poor. Stunning daylight set up and has bagged me some great shots but come dusk let alone night it is just atrocious.
Is the 200d much better in poor light?
If not I'll likely go back to Fuji as I like a small compact apsc set up and was happy with my x-100T.
Had a Nikon d5300 which was stellar in low light but no primes wider than 35mm and I like 28mm and 35mm equivalent as I stopped using zooms.
So if the 200d or m50 are not much better In low light I'll need to go back to fujifilm. Worse battery life but astonishing iso 6400 and great low light focus.
Cheers
When we remember we are all mad, the mysteries disappear and life stands explained.
Mark Twain
 Easy Rider's gear list:Easy Rider's gear list
Canon EOS Rebel SL1 Canon EF-S 24mm F2.8 STM Adobe Photoshop CS6 extended Adobe Camera Raw 7
Digirame Forum Pro • Posts: 41,857
Re: Sl2 improved in low light high iso over sl1?
Yes, the SL2 (200D) camera should be much improved with high ISO levels.
My camera's Canon T7i (800D) capability to the SL2 (200D) camera is similar. Here's some at ISO8000.
https://www.dpreview.com/forums/post/62108590
https://www.dpreview.com/forums/post/62109987 (second picture)
It's better definitely than what I get from my Canon T2i/T3i (550D/600D) cameras (which are similar in that capability as the SL1 (100D) camera). What ISO level looks good also depends on the lighting.
A little edit to add one more sample:
Here's a photo at ISO10000.  Now if you look at a 100% crop, you will see a little loss of detail.   But I can say I'm happy with these results.  This was taken inside a building with indoor lighting.  There was some natural lighting coming through the windows but it was a cloudy day.
Here's a crop of the photo above.
Easy Rider
OP Easy Rider Veteran Member • Posts: 8,236
I mean really low light like in an art gallery or streets at night when its actually dark.
On dxomark the 200d is still only 1041 for low light.  The crop nikons are around 1500 and I know the Fuji 16mp sensors are at least as good as that.
Cheers
Mark Twain
RedFox88 Forum Pro • Posts: 30,738
On dxomark
lol, that website is still a thing? 🤣
The picture I showed you of the people on the steps was taken when it was pitch black dark outside. The only lighting was from the large lamp and other lamps in the vicinity. If you want even more improved image quality and better high ISO levels you might consider a full frame camera. When I see photos from the newer full frame cameras I'm amazed at the details. As far as DXOMark scores I'm skeptical of their numbers. I would rather see the images and compare them that way. That's why I presented to you some samples.
The people on the steps were taken during an outdoor Christmas tree lighting ceremony. Here's another picture of that area. You can see those steps on the right side. A street that was closed to traffic is on the left side. Food vendor tents can be seen on that street. My outdoor photos are always hand-held, although sometimes I'll brace the camera and the lens. I hope that helps.
R2D2 Forum Pro • Posts: 26,551
The 24 MP Dual Pixel sensor (200D) will give you an additional stop over the older 18 MP sensors (100D).  This applies no matter what the light level.
R2
jebo1 Regular Member • Posts: 457
According to Ken Rockwell:
High ISO Performance
Performance top
High ISO performance is superb; as good as much more expensive cameras. While the SL2 "only" goes up to ISO 51,200, it still looks quite usable at that crazy speed. While other APS-C cameras might go higher, they just look worse at those speeds. The differences are more marketing than actual performance differences.
https://kenrockwell.com/canon/sl2.htm
He also gives you photo's to compare.
I am on the other hand quiet happy with my sl 1 in lowlight. The limiting factor for me is not the sensor but more the ability to focus. Manual focus does not work that great and on autofocus it is sometimes difficult to focus.
But I get far better results than with the panasonic fz 1000. What also helps is if you underexpose your picture with one stop. This gives a more natural picture and allows you to use longer shutter times.
 jebo1's gear list:jebo1's gear list
Nikon D200 Nikon D700 Nikon D7200 Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR +2 more
and on the SL1
High ISO performance is as expected for this format of DSLR: more than good enough for any reasonable use.
At hyper it gets like film: softer and grainier, and a whole lot better than TRI-Xever will be!
https://kenrockwell.com/canon/rebel-sl1.htm
So there seems to be a major improvement.
Easy Rider
Rockwell....   every camera is the only one he ever needs.. .😉
I appreciate your enthusiasm but I have actual real world comparisons.  My d5300 I sold due to lack of 24mm pancake had iso 6400 that was better and cleaner than iso 3200 with the sl1.  The Fuji Fuji x100t was better than that.
Over 1200 I find the sl1 to have unacceptable IQ in even dusk let alone night and bear in mind I'm a street photographer so best IQ is not my main concern.
Mark Twain
Your camera may be exactly what you need! That’s an excellent position to be in.
OTOH the OP is looking to get better noise performance than what his SL1 is delivering. These new sensors do just that. And the newer Digic processors can handle the noise better too (if the OP is shooting jpegs). I do however recommend shooting RAW, as you have a lot more leeway in adjusting all of the image variables in Post.
I’m guessing too that the OP is looking to keep the overall size of his/her rig down (being a street shooter), so that likely precludes going with some of the larger bodies (ie. full frame), and perhaps may rule out mounting any larger faster lenses, which themselves may help with letting in more light.
I don’t know what your current AF technique is, but in general I recommend always going with a single AF point. If I’m shooting people (or animals) I’m usually focusing on the near eye. Sometimes when the AF is sketchy I’ll resort to focusing on a nearby high contrast AF target (like a shirt pattern, or the numbers on a uniform), I’ll lock the AF, then lean forward or backwards with my camera to compensate for the difference in distance to my subject.
Personally I love the flexibility that Back Button AF brings to the table. It makes it much easier to lock the focus (you just lift your thumb off the BBAF button). You can then keep shooting for as long as you want (without any change in focus point, or having any re-focusing delay), for as long as the distance to the subject remains the same. This makes subsequent follow-up shots very very quick. I can often even extend this period of locked-on AF if the subject does move a little bit, by swaying to and fro with the camera the same amount that the subject has moved. Just re-focus whenever necessary. It helps too, to always keep in mind what your depth of field is!
When shooting in low light I like to shoot bursts. Not only does your chance of catching a decisive moment improve, but this also helps to stabilize the lens (one of the images is invariably sharper than the others). I gain about a stop in handhold-ability (I call this “Poor Man’s Image Stabilization). Some folks may prefer not to shoot bursts though, so YMMV.
My philosophy is actually just the opposite. Noise response improves the More light you collect (likewise does detail). To maximize this benefit, I adhere to the ETTR principle (Expose To The Right). Which is to increase exposure until just before clipping the (important) highlights, then applying the appropriate adjustments afterward in Post. It really helps to shoot in RAW too.
Underexposing may have been a viable technique back in the days of color-positive slide film (which I in fact used to employ in order to increase film density), but in this digital age just the opposite would be true. Again, I do understand that YMMV.
Hmmm. Actually intentional underexposure would allow one to use shorter shutter speeds. This being a last-ditch technique sometimes employed when freezing action is of paramount concern, and you’ve run out of all other options. This does increase noise however. Perhaps a little moreso than even raising the ISO.
I do agree that there are instances when less exposure might indeed be preferable, such as when not wanting to blow out a sky. Do this at base ISO though to keep noise to a minimum. Your other areas will still be subject to that increase in noise however, so one must remain aware of that, and you may not want your main subject to suffer this.
Ahhh, this is what makes photography so fascinating! Easy to learn, difficult to master.
Happy shooting all!
R2
As you might have guessed, I am from the film era. So I am really satisfied with but there is always room for improvement. For low light, I also have a 50mm 1.8. Upgrading to sl2 was something I thought about too. But then where to stop? You could also buy a df or . Some phones might take better pictures in low light. My biggest barriers are now time and talent. I would compare the sl1 (sl2?) to a Nikon EM from the film era. Thank you for your suggestions!
I get these results at 6400
https://www.flickr.com/photos/148981344@N02/32348939162/in/dateposted-public/
Have you compared your other cameras to the Canon SL2 (200D) camera?
The Canon SL1 (100D) camera is old technology. The high ISO performance of that old technology is similar to my Canon T2i (550D) camera which was introduced almost nine years ago. The Canon SL1 (100D) camera was first introduced on March 21, 2013 per Wikipedia. That's almost six years ago.
The answer is clear. The Canon SL2 (200D) has many improvements. I would hope that someone would show ISO8000 and ISO10000 samples from a Canon SL2 (200D) camera as I have done with my Canon T7i (800D) camera. With my Canon T2i/T3i (550D/600D) cameras I didn't like to use above ISO1600...sometimes I would use ISO3200...ISO6400 was very noisy.
shenlonco Regular Member • Posts: 336
Just want to jump in here real quick... I owned the SL1 and got the SL2 when it first came out and there is no comparison the SL2 beats it in every way it's a way better camera than my older SL1 was and in low light it kills the SL1.
MikeJ9116 Veteran Member • Posts: 6,958
AF is probably much better in low light. I don't have much issue in this regard.
IMO, the SL2 is better than the SL1 overall in low light performance. How much better depends on why you are using it. If it is to increase shutter speed (where decent light is available) more than deal with exposure (light is minimal) it works much better. If it is mostly to obtain an acceptable exposure then the improvements are somewhat less noticeable. Hopefully I explained this in a way that is understandable.
Also, I am not too sure the grass is much greener with other APS-C brands. I have a 6D and it is a beast for low light shooting. FF might be a better choice if shooting in low light conditions is very important to you.
Easy Rider
Cheers.  As r2d2 guessed I want to keep the size down.  Also I like pancake lenses.
I'll likely go back to Fuji as I want to do some 28mm shooting after two years at 35mm eqvt.  No 18mm prime for canon apsc.
I'll likely keep the sl1 for summer as I prefer a DSLR when I can use one.
Tried kit lens at 18mm but focus too slow and close focus distance too long.
I'll get the Fuji x100t with the WCL for a while... I like changing cameras every now and then anyway...  ha ha
Cheers all
Mark Twain
Easy Rider
Not as good as my old d5300
https://www.dpreview.com/reviews/canon-eos-sl2-eos-200d-review/6
Think I'll skip it
Mark Twain
I don't know if that is a good tool to evaluate photos in terms of high ISO performance.  I stopped using that a long time ago.  I'd rather look at my own photos taken in a variety of lighting conditions.  Look at the Nikon D5300, Canon SL1 (100D) and Canon SL2 (200D) at ISO12800 for a JPEG.  Look at the eyes on one of the faces.  What's strange is that the Canon SL1 (100D) seems to be the best or nearly the same, depending on what is seen.
rmexpress22 Senior Member • Posts: 2,304
If budget is not an issue, you'd be better-server with the m50 and 22mm EF-m. Light, compact, and good AF.
DPR and DXO typically rate a potato better than a 5D4 and 1Dx2. If you look at the raw samles in DPR, the noise on the SL2 looks similar to other current-gen crop bodies. What looks worse is the sharpness, which I honestly don't understand since under a controller environment with a half-decent lens you'll typically get better results.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Think I'll skip it
You get much more than low light ISO improvements going from the SL1 to the SL2.  In fact, low light ISO performance is the least reason to upgrade to any APS-C camera from the SL1.  If you are splitting hair this fine then go FF and really get what you want.  Otherwise, Canon, Fuji, Nikon, Sony etc. are all likely to disappoint you in this regard.  Photographers don't choose APS-C when low light ISO performance is important.  The differences between any APS-C cameras you consider regarding high ISO performance will be minimal.
Easy Rider
False colour noise and sharpness are much worse on sl2 vs Nikon d5500 and Sony a6000 at above iso 1600.  It's about the same as current m43 bodies.
As I said I'll skip it.
Fuji will not disappoint as I previously stated.
Not to you but another poster who suggested I compare photos.  I have done.
I have owned and used a d5300 and fujifilm x100t and they had stellar iso 6400.
I find dpr IQ comparison and dxo to be quite reliable.
I also need a prime 18mm.  Hence fujifilm makes most sense.
Cheers all.
Mark Twain
