Dead AF on DFA* 1.4
Started Jan 4, 2019 | Discussions
Alex Sarbu Forum Pro • Posts: 11,584
Re: Dead AF on DFA* 1.4. FIXED
Adam007 wrote:
So, I tried cleaning the contacts again. I noticed one of the two gold contacts on the lens was bent in the wrong direction (outward). I pressed it back into place, and voila! It looks like this:
Look closely at the contact on the left (just above the screw).
Oh, the power zoom contacts - introduced a few decades ago, cvasi-abandoned and then reused to provide power for the in-lens AF motors, and now the KAF4 aperture mechanism.
They do occasionally break, unfortunately - not often, but I've heard about a case or two.
Two things: I assume this got bent while changing the lens, but I’ve changed lenses a zillion times, and this seems a bit unlucky. Also, I’m a little surprised there is no redundancy here; this contact is sill sticking out a bit from the lens body, and if it gets jostled again, it might not be such a quick fix.
At least it should be an easy repair ( very little disassembly is required).
Thanks to everyone, particularly those who insisted this sounded like a lens-body communication problem. And if anyone has suggestions about that stray contact (I think it’s best to leave well enough alone, but I don’t know), I’d love to hear from you.
No suggestion I'm afraid, other than the obvious make sure it won't break and fall into the lens/camera.
Alex
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +8 more
MightyMike Forum Pro • Posts: 40,578
Alex Sarbu wrote:
MightyMike wrote:
Sounds like a communication problem, you might consider checking of the screws on the mount plate are tight, if that does nothing for you it will have to be serviced
Yeah, lens and camera side.
But don't you need a JIS screwdriver for that? AFAIK using Philips ones can damage the screws.
Alex
It probably can, but so long as you don't overdo it and are careful I'm sure you can get away with it.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Great to see this fixed, however what a problem, I hope this isn't a sign of cost cutting but rather just a one off fluke.
Mike from Canada
OP Adam007 Contributing Member • Posts: 611
On more follow-up:  the pin bent itself back out of position. “Fixed” yet again, but I can’t take the chance of it failing permanently outside of warranty. Back it goes.
Thanks again!
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +5 more
Roland Karlsson Forum Pro • Posts: 28,984
It looks kind of strange with those contacts bent like that. I have now looked at my lenses with internal AF. The contacts have no tendency at all at being bent.
You guys that have a DFA* 50/1.4, can you take a look at your contacts? And maybe take a picture how they should look?
/Roland
Kalpanika X3F tools:
https://github.com/kalpanika/x3f
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
Alex
I recommend a JIS. I have destroyed screws on at least one old lens before I got myself a JIS screw driver. If the screw is sitting hard you are going to destroy it.
/Roland
Of course, the contacts are not normally bent nor raised from their support - here's my sample:
Alex
James O'Neill wrote:
And a huge proportion of failures seem to result in a post here.
That is always so. I assume a very high percentage of those active in a forum will tell about their misfortunes.
/Roland
TBLF Senior Member • Posts: 1,038
I'm so happy for you! And, for the community that it is not an internal motor or circuit issue. I'm not 100% sure what I would do in your shoe's, but I think I'd be keeping a sharp eye on it, and find out the EXACT expiration date of your warranty, so as to know when you have to decide by, as to weather you want to send in to have that contact looked at.  Good job.
EricV
 TBLF's gear list:TBLF's gear list
Pentax K-1 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 77mm 1.8 Limited Pentax smc D-FA 100mm F2.8 Macro WR Pentax FA 150-450mm F4.5-5.6 +7 more
egk4260 Contributing Member • Posts: 774
9
I would disagree with just watching it closely and calling at end of warranty. With issues like this there is always the potential that the servicing agent will deem the damage related to misuse rather than design related or an isolated QA miss. I think the longer he waits the more likely this would be the case, further decreasing his chances of warranty repair or replacement. User repairs involving bending contacts and using screwdrivers could be considered repairs done outside the authorized network.
Send it in, push hard for warranty coverage, but get it corrected. They may well consider it not a warranty issue, but he paid for top tier optics, he may as well have a reliable top tier lens.
Thanks, All.  It goes back at the end of the trip, under the retailer’s warranty.  Contact broke off completely.
i can’t say there was anything unusual in my handling  of this lens - except that I was always extra careful because it’s so new and expensive.  While I can’t identify exactly what went wrong here, I think the contact was unable to withstand normal use.  I’ll press that point as strongly as needed with the retailer.
Thanks again for all the advice and support.
(unknown member) Veteran Member • Posts: 6,680
People who are happy with their gear just use the stuff. People who are having problems seek out forums such as this for advice. Human nature skews forums such as this into inflating one off problems into epidemics.
People have to ignore this basic fact when trying to score cheap hit points on a brand.
Adam007 wrote:
"Contact broke off completely."
Ouch! Yeah, sometimes it is easy to forget how fragile certain parts of our equipment are, and it's a miracle things like this don't happen more often, with all the lens on/off the camera mounting. The clearances are tight, and all it takes is a bur or slight misalignment to catch at the wrong moment and pull that contact away.  Sorry it didn't make it through your trip, but returning it sooner than later sounds like it would have been the best course anyway. Let us know how it goes.
EricV
johnami
johnami Senior Member • Posts: 1,203
Funny how someone's misfortune can lead to oneself taking a good hard look his own camera equipment.
The contacts we are talking about only exist on certain lenses like the DFA 50 and DA 300 mm. I have never really taken much notice of them. But as you have mentioned, these are expensive pieces of equipment and we try to take special care. In my case it means leaving the lens on the body as much as possible. It's such a big heavy unit anyway that when it's on I know I will use it 😇. If it was off, maybe not...
Difficult to understand how the contacts were bent out of position😳...We all know that when removing a lens you push a button and turn anticlockwise and turn clockwise when attaching a lens. Physically it isn't possible do it back to front. So I don't believe the contacts were damage when changing lenses. So how? I can't see Pentax sending out lenses with bent contacts, certainly with the new star range....Mystery...What about the little screws on each side...could they become loose? Have to get to the bottom of this Watson..
Perhaps you'll get some info from Pentax once the lens is repaired. They are certainly already reading this post..
Nice lens the DFA 50mm, but when I compare it to my FA 85mm star, I wonder how big a new 85 mm could be...Cheese..
 johnami's gear list:johnami's gear list
Sigma DP2 Ricoh GR II Pentax K10D Pentax K-5 Pentax K-1 +16 more
These power contacts exist on:
- the old power zoom lenses
- the D FA and DA lenses with in-lens autofocus motors (about 20 lenses and counting)
Alex
Florida Suse
Florida Suse Regular Member • Posts: 487
Been reading this thread but, haven't commented because I've been thinking about this mystery and I think. . .
that it will be very important to keep that plastic cap that goes on the back part of the lens on every time the lens is not attached to the camera.  Not saying the OP did not do this or this is what could have caused contacts to bend out but, I'm thinking that it could easily snag on a piece of fabric or another piece of gear in a camera bag or any place when not covered or protected with the cap. Seems like an easy piece to get caught on anything because it sticks up and catches easily. Will have to be conscious of never having this lens capless on the back end, even in camera bag or pouch.
johnami
Alex
Thanks Alex...Just proves how many lenses I don't have..😉
I am a little surprised.
I always thought those contacts were solid metal ones. At least that is how the look at my lenses having them. But, now it seems they are only thin metal ones bent over a plastic base. And looking closer, that might be the same on my lenses, but I am not sure.
/Roland
johnami
They are the same....
All the lenses I've seen (and paid attention to those contacts) are the same. I call those contacts "Canon-style", to differentiate them from the typical Pentax contacts introduced with the KA mount.
Alex
