Please participate in a research project
Started Jan 1, 2019 | Discussions
LNygren New Member • Posts: 1
Re: Please participate in a research project
YRC slight 3D effect
QRC  strong 3D effect
(I viewed them parallel and made note of my findings before reading the comments.)
It is interesting to me that some individuals saw a difference in whether depth was perceptable in the first example depending on which viewing method was used (cross or parallel). I am unable to crossview  so am unable to make a comparison.
It is not clear to me exactly what you are researching here....
uuglypher
OP uuglypher Regular Member • Posts: 250
Hi, LNygren, I do appreciate your time and participation in the survey!
The survey involves a study of the ability of subtle to subliminal image disparities to elicit a 3D effect with stereopsis. so far results from our forum here as well as from a few 3D viewers from other forums reveal slightly more than half of the respondents detect a 3D effect in set YRC, and all detect 3D eff3ct in QRC.
There will likely be a follow-up survey to test response to an even more subtle/ subliminal disparity  with the hope of establishing means for more finely quantitating sensitivity of stereopsis capacity in the highest ranges of stereopsis capacity (the right end of the Gaussian bell-shaped curve of parametric data distribution.)
Thanks, again, for your input!
Dave Graham
The data collected from our forum here, as well as some other particants fron other forums
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
BTW...
What are your observations??
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
uuglypher
Turbguy1 wrote:
BTW...
Hi, Wayne,
My observations are:
YRC: slight 3D effect
ORC:  strong 3D effect
uuglypher
Wayne Gretzky
Tom Frerichs Regular Member • Posts: 298
YRC - slight to no effect..mainly no 3d effect.
QRC - mild to strong 3d effect -- almost like the lens separation wasn't big enough.
Tom Frerichs
 Tom Frerichs's gear list:Tom Frerichs's gear list
Nikon D4 Panasonic Lumix DMC-GX7 Nikon D4S Nikon D7200 Nikon D500 +18 more
crunchy_3d Regular Member • Posts: 149
YRC: slight effect
QRC: medium to strong effect
uuglypher
Thank you, Crunchy,
Sorry to be late with thanks.
Dave
uuglypher
Wayne Gretzky
Brisn5757 Veteran Member • Posts: 4,540
The QCR was very effective with lines of text at different positions
The other text showed a 3D effect but the text appeared to be at the same distance.
It was difficult to get a cross eyed 3D effect as the images were close together.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
uuglypher
Brian,
I appreciate your taking the time to contribute your input to this project.
Many thanks,
Dave Graham
uuglypher
Wayne Gretzky
