How do you take advantage of Lens stabilisation ?
Started Dec 30, 2018 | Questions
Michel Gomez Forum Member • Posts: 91
Hi DP fellows, here is a question for lens experts...
I eventually found out that I can take advantage of lens stabilisation with my EF 16-35 F/4 IS USM. I can easily increase exposure time to 1/10s and still avoid movement blur. Benefit is obviously a much lower ISO.
My question is: how do I know (with this lens or any other stabilised lens) the maximum exposure time I can reach by using stabilisation ? Of course, I will eventuellu find out by trial and error, but is there a rational number-based method to use this great feature ?
Thank you very much in advance for any advice.--
Michel
https://www.flickr.com/photos/gomezmi2013/
 Michel Gomez's gear list:Michel Gomez's gear list
Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Canon EF 24-70mm F2.8L II USM Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) +2 more
fishy wishy
fishy wishy Veteran Member • Posts: 9,358
Re: How do you take advantage of Lens stabilisation ?
You won't get a guaranteed shutter speed so long as you are holding it with your hands.
If you want to guarantee stability, you need to use a tripod.
If you just want to use optical stabilisation to shoot at a smaller aperture or lower iso, you just have to try the shutter speed you want and check the photo afterwards. If it's not sharp enough, try again.
On your lens I find shooting at under 1/15s risky at all focal lengths. Sometimes I can go down to 1/5s, but only if I'm very composed and have the time.
OP Michel Gomez Forum Member • Posts: 91
Hi Fishy, many thanks for your response...
So I am back to trial & error...
photonius Veteran Member • Posts: 6,895
Michel
Well, you know probably that one can hand-hold a shutter speed of about 1 / focal length.  I.e. a 100mm lens can yield good images with 1/100 shutter speed.   A 50mm lens with 1/50, etc. However, it also depends on your technique. Sometimes you get more sometimes less. Now, with IS, each lens is rated for a certain improvement, modern lenses usually around 3-4 stops. What you actually can achieve again depends on your technique.
You can also look at the lens tests here on dpreview.  Some have IS tests. From this you will see it's not an all or nothing at a particular shutter speed. Some shots will be bad, some decent, some good. As shutter speed gets slower, the ratio of good shots will drop, but you still might get some good ones. Hence, in critical situations it's good to take multiple shots and select the best. For example in burst mode, the first few images may still have blur due to your pressing the shutter, but later ones may be better. Also using a 2 sec delay timer can help. Good stance, breathing technique etc. can help.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
fishy wishy
You're one of the few that are willing to accept this fact. Most go with the simple statements from the manufacturer or salesmen, because that's what they want to believe. Which is weird. Usually people would be more cynical. There's a lot of wilful delusion going on.
Dale Garman Senior Member • Posts: 1,025
I think this is good advice, and likewise I would add taking several shots at the same setting as well as try different settings.  I often find in low light when I'm stretching with hand held, one out of 3-4 at same setting might be significantly better focused than the others as there are a lot of variables when trying to do this.
 Dale Garman's gear list:Dale Garman's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
Thank you Sir.
I did not think of looking at the DRP reviews, thanks for the detailed response !
Have a nice day.
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the best ways are to move around a lot
or have the subject move around a lot
if you are both still then you cannot take advantage of that feature.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Daniel A Smith New Member • Posts: 2
Not trial and error, but careful testing.
Set up a solid tripod and compare the same basic composition at various shutter speeds hand held and on the Tripod. When on the tripod be sure to turn off the Image Stabilization feature.
Many never seem to test their gear so they know how to get the best performance. Digital makes it so much easier than film. Near instant feedback and the ease of testing really help. You don't have to wait a week or so for the Kodachrome to come back in the mail.
One thing I have found that helps me is actually writing down the results I expect and when checking the results writing down what I am seeing. Too easy to mis-remember and change/mis-interpret reality later as a result.
BAK Forum Pro • Posts: 26,020
Look for lens reviews. Sometimes reviewers run tests.
These tests reveal that different systems provide different results.
Remember that subject movement is not helped.
And remember that permissible shutter speeds vary with focal length.
BAK
Andy01 Veteran Member • Posts: 5,191
Michel
In general I use the stated "specs" as a guide. Start with the old i/FL rule of thumb, and starting counting stops.
For example, if your lens is "rated" for 4 stops of IS, and you are shooting at 30mm (on a FF), your rule of thumb would be 1/30th. At 1/30th you should get a very high % of keepers (maybe 98%). Drop 1 stop to 1/15th (relying on IS), and you should get a reasonably high % of keepers (maybe 80-85%), drop another 1 stop to 1/8th, and your % of keepers drops as well (maybe 70%), and so on.
I find that if I am pushing things a bit, I often shoot a high speed burst of 4-6 shots, and then pick the best of those. This does two things, gets you past a potential loss of stability with the initial shutter press, and increases your chances of getting 1 shot out of several that is sharp (working on the % keeper numbers).
I have found that it is easier to push the "rated" number of stops more on a longer lens (like 100-400L ii) than an wide angle where the 1/FL starts with a slow speed anyway.
I would say that 3 stops on a 100-400L ii is relatively easy with the rated 4 stops being achievable a lot of the time. But on a 16mm, 4 stops would take you down to 1 second shutter speed, which is a lot more optimistic.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
CameraCarl Veteran Member • Posts: 9,204
"Trial and error?" No, it is called testing. Everyone is different. I may be able to hand hold to 1/15 sec and my much younger neighbor may be able to hand hold to 1/5 sec. Why not test it yourself? Find a typical subject with lots of detail and which can't move (so this leaves out trees and cats). The take a series of two or three photos at 1/100, 1/50, 1/25, 1/15, etc. and look at the images on your computer at 1:1.  When you see softness or lack of sharpness that is not acceptable to you, this ought to be your limit for image stabilization.
ed rader Veteran Member • Posts: 9,068
Michel
if you are using a hard a fast rule which I think is a good starting point you also have to include crop factor, if there is one.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Graham Meale
Graham Meale Veteran Member • Posts: 3,865
I'd have thought the answer would depend on the user. Someone with a steady hand would be able to use longer shutters than someone with Parkinsons, for instance.
 Graham Meale's gear list:Graham Meale's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 50mm F1.8 II Canon EF 100mm f/2.8 Macro USM +7 more
Michel Gomez wrote:
Thank you Sir.
Have a nice day.
unfortunately not that many tests, and not many have the full IS test.
Here is one:
https://www.dpreview.com/reviews/sigma-17-70mm-f2-8-4-os-hsm/3
But it illustrates the variabilities/limitations of the system. And it also depends on your personal ability to keep your hands still....
Thank you Andy for your valuable advices.
Great advice, Thanks !
Old Greenlander Veteran Member • Posts: 4,402
MG
you do that by experimenting
Hence,  the data is variable, for each combo and your fitness
below is a 500F4 with IS ON and handheld at 1/200
At other times I cannot take a sharp picture with the same combo, at 1/1000
Old Greenlander
"I show the world the way I see it"
40 years of photography and still learning
https://www.juzaphoto.com/me.php?l=en&p=88256
 Old Greenlander's gear list:Old Greenlander's gear list
Nikon Coolpix P900 Canon EOS 5D Mark III Nikon D810 Nikon D500 Nikon D850 +18 more
Thanks for your response
Excellent handheld catch btw !
Dave
Dave Veteran Member • Posts: 6,231
Sometimes there's nothing to lose, so you just say "what the heck" and push it.
This was shot in almost total darkness. While I can't call it "good" objectively, I can attest that camera and lens "saw" the vessel far better than my eyes could. I doubt my 135 f/2 would have done a better job. Did stabilization save the day? Maybe. High ISO certainly helped.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
