Re: Can Lumix G7 "downscale" 4K to 1080 video in the camera ?
red sled wrote:
...3) At current prices here, the G7 with kit lens is $498 and the GH4 without lens is $698. I am new to 4K and I've never done video editing. Would you recommend starting with the G7 and kit lens rather than investing in the GH4 and having to buy a lens ?
I got my G7 with the 14-140 kit lens. It costs a bit more than the standard 14-42 kit lens, but it's the closest you can get to a zoom lens that goes from wide to mid-telephoto.
Panasonic cameras are great for video (I have 3) but the auto focus for video is pretty much useless. It has no problem focusing, but then it keeps verifying the focus by drifting in and out of focus - called hunting.
On the other hand, video pros rely on manual focus a lot of the time because they can't afford to allow a shot to be ruined by unreliable AF. Canon's "dual pixel auto focus" is the most reliable, but it's only available on their upper end cameras. (The Canon M50 has DPAF, but only when shooting in 1080p, not in 4k.) Sony's AF is pretty good, but some models are better than others.
What's nice about the G7 is the focus peaking feature. In manual focus mode, focus peaking puts a neon-blue "halo" around a subject when it's in focus, which makes manual focus easy. You can also use touch focus, and/or use the lock button on the back of the camera to tell the camera to focus on whatever's in the focus box, which you can move around. Check out Caleb Pike's G7 tutorial on Youtube. It's not free, but it gives you everything you need to know about the G7, and it touches on a few general video topics like lighting and conducting an interview.
The downside to the G7 is the file structure. It has a 4 gig limit, which means a long continuous video - say 20 minutes - might create 3 files, which you stack end to end in your video editor. The problem arises if you're using the G7's audio. At the break between files, the G7 will sometimes drop a frame, which means you may need to do an audio crossfade at that break point, or if you're in a multi-camera shoot, or using an external audio recorder, you may have to check sync after every break to make sure it's not drifting. The G7 also has a 29 minute limit for continuous video shooting (meaning, you have to stop recording and then restart video recording to get past the 29 minute limit.) The G85 and GX85 do not have that limit.
If you're considering skipping the G7 and going to one of the 85s, you'll get IBIS (image stabilization) but the kit lens selection will likely be different. The G85 comes with a 12-60 lens. The GX85 comes with a 12-32 lens (with no focus ring) or the bundle with the 12-32 plus the 45-150, but the viewfinder on the GX85 is useless for left-eyed shooters.
If you could get the 14-140 lens with either of the 85s, or if you need extended recording times, that might be a good way to go. If not, the G7 with the 14-140 lens is an awesome package. Plus, the 14-140 lens has OIS - optical image stabilization - which is not as effective as IBIS, but better than nothing.
