Reviews of the 35/1.8 Macro RF?
Started Dec 29, 2018 | Discussions
travelinbri_74
travelinbri_74 Veteran Member • Posts: 4,998
Trouble finding reviews of this, does anyone have experience or good links? Thoughts?
 travelinbri_74's gear list:travelinbri_74's gear list
Ricoh GR III Sony a7R III Sony a7R V Sony FE 16-35mm F2.8 Sony FE 20mm F1.8G +9 more
cshrpminor New Member • Posts: 4
Re: Reviews of the 35/1.8 Macro RF?
Here is a nice review of the lens:
https://youtu.be/hdldTtRIt5E
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
Its a great little all-rounder!. Cheap, compact while f/1.8, quick focus, ideal walk around focal length, 1:2 macro, very nice built.  The optical quality is only slightly behind my sigma art at the same stops .... Clear recommendation!
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS R5 Canon EOS Ra +30 more
nokinonacynos Regular Member • Posts: 113
5
For me, it's a must have lens for the R. Compact and light, perfect for walkabout. True all rounder, able to do macro, portraits with nice bokeh, low light work with 5 stop IS, wide enough for landscapes, great for street photography or hiking, function ring, very sharp, low CA. Unfortunately AF is gear type STM which is noisier. However, it becomes quieter in video mode. It's the lens that is always on my R.
travelinbri_74
OP travelinbri_74 Veteran Member • Posts: 4,998
Thanks, I agree this looks like a great all around, and compliments the larger - albeit stellar - lenses that have defined the system so far (the 28-70 and 50/1.2 are what tempt me, but the 35 would be my walk around). Not buying the current Canon R, but very interested in the system.
Rawpaul
Rawpaul Senior Member • Posts: 2,567
Well said !!! nothing to ad here
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF 70-300mm f/4-5.6L IS USM Canon EF-S 17-55mm f/2.8 IS USM +6 more
Rawpaul
Also very well said !!!
gimp_dad Senior Member • Posts: 2,692
This guy does good technical reviews and has a review for the RF35/1.8IS Macro. I have the lens and find it to be better than my EF35/2IS. It's a great all around lens and has excellent IQ for its size. It doesn't focus quite as fast as the RF24-105/4L or the RF50/1.2L but it's very accurate and the IS feels very solid.
https://www.the-digital-picture.com/Reviews/Canon-RF-35mm-f-1.8-IS-STM-Macro-Lens.aspx
J A C S
J A C S Forum Pro • Posts: 20,521
From that review alone, one can say that the IS is amazing but the lens is soft overall and vignettes a lot (as much as the 35/2 IS).
Yea. Pretty similar to the 35/2IS which feels like it was just upgraded all around without any major breakthrough.  It's lighter, with better IS and slightly less distortion. Plus a one third stop increase in aperture along with the Macro capability.
But mounted on a tripod, manually focused on a flat test image it's pretty similar.
I honestly hardly use it because of how great the other three new RF lenses are but it seems like an excellent all around budget lens much like the 35/2IS was for its time. It's just an evolution from that one (which was also an excellent all around lens).
Ricardo O Forum Member • Posts: 78
check out these pics,
https://www.canonrumors.com/forum/index.php?threads/canon-rf-35mm-f-1-8-is-macro-the-ugly-bokeh-king.36469/
and also the youtube videos on page 2
what do you guys think?
Martin Muehlemann
Martin Muehlemann Senior Member • Posts: 1,463
I have it
Very useful and lightweight. I'ld wish that Canon had a RF 20 F1.8 and RF 85 F1.8 already in the same size. Inside my house on x-mas i had to switch a few times to the EF24-70 to go wider.
It is not sealed. Thats likely the only drawback i could tell
 Martin Muehlemann's gear list:Martin Muehlemann's gear list
Olympus E-M1 III Olympus TG-5 OM-1 OM System 12-40mm F2.8 Pro II Olympus 40-150mm F2.8 Pro +9 more
No surprises here. This is very consistent with what I have said above about being an evolutionary enhancement of the EF35/2IS. This is not a low cost RF50/1.2L or EF35/1.4LII.  There's a reason the RF50/1.2L weighs and costs so much more.  Even without IS it has 15 elements with several aspherical and/or UD elements along with special coatings compared to the RF35/1.8IS Macro which has 11 elements including IS.
  1. No one should think they are getting a newly designed L prime for $500,
  2. the user review looks like it was taken using EFCS which can affect bokeh quality (see the chopped off bokeh balls),
  3. getting close helps with the bokeh much like with the 35/2IS but this creates it's own challenges since getting too close will induce perspective warping you don't want; using a wide angle lens for bokeh is not easy,
  4. this lens makes very interesting compromises for its size and cost which many people will enjoy as long as they pay attention to the above.
  5. Not mentioned in the review is the fact that it will not have the level of contrast or saturation delivered by other L lenses either (even though it is a little improved over the EF35/2IS in this regard).
This lens outperforms the Sony/Zeiss 35/2.8 ZA I used to have back when I had an A7R2 and outperforms my RX1R2 which has the Zeiss designed 35/2. All three of these solutions are fine for travel and general use and will take excellent shots. If stopped down, you can create a 3 foot by 2 foot image printed on metal that you would mount on your wall. But, while I may take this lens with me on a trip to save weight, I will usually reach for the RF50/1.2L when people are involved in the shot.
J A C S
gimp_dad wrote:
  1. the user review looks like it was taken using EFCS which can affect bokeh quality (see the chopped off bokeh balls),
He says that this was not the case on p.2. Also, EFCS creates a very different effect of gradually dimmed bokeh balls in the direction of movement of the shutter. What we see here is the effect of mechanical vignetting.
With all this talk about the benefits of the new mount and this lens used as a poster child vs. the 35/2 IS, it is interesting to see that this lens preforms more of less the same as the latter with a better IS maybe.
Ok. Didn't see that. Thanks for the clarification.
That said, I never expected this to be a 35/1.4LII replacement. I am happy with the incremental benefits over the 35/2IS and will use it similarly for non-critical uses where size and weight are the priority.
J A C S
BTW, can you confirm the improved IS? I was never able to get good shots with my 16-35/4 IS at, say 1/8 sec. or so and Bryan at TDP says that he can get to 1 sec.?
I haven't run any comparison tests but can feel a major difference between most of my Canon lenses and the three newer ones I own with "5-stop" IS: the RF35/1.8IS, RF24-105/4LIS and EF70-200/4LII.  These all have this substantially more solid feel when the IS kicks in. I don't get the same feel from my new 85/1.4LIS but I'm not bothered by that since I only use it for people and would't go below 1/60 (or preferably 1/100) for people anyway.
One of the reasons I'm not being more definitive than that is that I have had a pretty big drop off in hand steadiness which has progressed over the last two years.  I'm not that old (mid fifties) but years of using computers all day has finally caused me to pay a toll in steadiness (especially my right hand). Also, my steadiness is not super consistent.  Sometimes I am almost as good as I used to be and sometimes I feel like 5-stops of IS gets me about 1 stop better than the 1/FL rule (meaning I'd probably need 1/(FL * 3) or so without IS).
So overall, I feel that the RF35/1.8IS has much better IS than my EF35/2IS but I think I had shots a couple of years ago with my 35/2IS around 1/6s that I couldn't do now.  And, I have also achieved in that range or even better (like 1/4s) with my 16-35/4LIS at 16mm but using the best of 5 attempts. Again this was 2 or 3 years ago.
Honestly, I feel like the RF35/1.8IS is a jack of all trades but master of none.  I don't expect to use it very often but it will take over the role that was previously reserved for my RX1R2 (i.e. the minimum weight while still bringing a FF camera).  For that role, I think it will be just fine. Photographing things (buildings, landmarks, etc.) usually makes me want IS and not need a super wide aperture, but the penalty for that F1.8 is not high so it can offer me the opportunity to take a street shot in a pinch.
handheld example
Here's my attempt.  Not quite perfect at 0.4s but much better than I could do with the 35/2IS even in my steadier days.
Focus was on the "r" in Birds. Handheld while seated but arms not supported, by a relatively unsteady person (me).
Only thing I did in DPP4 was crop out superfluous parts of the frame.
Franz Kerschbaum
Re: handheld example
I just made my simple unscientific handheld test.  Free standing I made always 10 pics at different exposure times. The numbers of sharp pics at 10x out of the 10 shoots are given. 1/30: 10, 1/15: 8, 1/8: 7, 1/4: 6, 1/2: 5, 1s: 2.  For me that means that to shoot a short sequence at 1/8s gives you a very good chance to have critically sharp pics. Even at 1/4s or 1/2s a 50% chance for an individual pic... Great! No need for a tripod in must of the walkaround cases ...
Back2M Regular Member • Posts: 367
https://www.popco.net/zboard/view.php?id=dica_review&page=1&category=22&no=1086
Google translate or Chrome are your friend for translating it. A lot of the text is actually pictures thus the translation is only somewhat effective. The samples however are really nice.
 Back2M's gear list:Back2M's gear list
Canon G1 X III Canon EOS R Canon RF 35mm F1.8 IS STM Macro Canon 70-300 F4-5.6 IS II Canon EF 16-35mm F4L IS USM
