K-7 worth buying?
Started Dec 26, 2018 | Discussions
teletripper Junior Member • Posts: 45
K-7 worth buying?
My K-50 died a while back and don't really want to fix it for now, being that I use my trusty Oly E-3 I'm not afraid to use a older camera is the K-7 worth buying so I can use my fine Pentax lenses until I can afford a K-3 in the late spring?
 teletripper's gear list:teletripper's gear list
Olympus E-3 Olympus E-420 Pentax K-7 Pentax K-50 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +8 more
Olympus E-3 Pentax K-3 Pentax K-50 Pentax K-7
bkpix
bkpix Senior Member • Posts: 1,013
Re: K-7 worth buying?
I'd go for a K-5 in your position. The K-7 has much lower high-ISO image quality, and the autofocus isn't nearly as good.
 bkpix's gear list:bkpix's gear list
Pentax KP Canon 6D Mark II Canon EOS R5 Canon EF 135mm F2L USM Canon EF 28-135mm F3.5-5.6 IS USM +12 more
Rahto Senior Member • Posts: 1,605
I still have my K7 and it is ok at the low ISO’s but noise is a problem with even moderate ISO’s. I personally don’t shoot mine above ISO 200. It is a good camera for macro if you use a flash. It is living proof that Pentax has made advances in autofocus, as already stated go for a K5, K5II or K3.
Bob
 Rahto's gear list:Rahto's gear list
Canon EOS D60 Pentax *ist DS Pentax K-7 Pentax K-3 Pentax K-3 II +72 more
Holger Bargen Veteran Member • Posts: 4,911
If I am correct K7 was one generation before K50. Thus, it may be a little downgrade in especially in terms of high ISO capability.
But if you can live with it K7 is a great camera.
I just opened a thread where I show photos I took with K10D (the gradpa of your K7) 8 years ago. I did some post-processing on them with the latest version of ON1.
https://www.dpreview.com/forums/post/62093054
I opened the thread as I was surprised what's in these photos if you open them in a modern program for post-processing. That days I used DxO which was a great programm (and still is) - but the RAW quality of K10D was simply great.
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
(unknown member) Veteran Member • Posts: 6,680
I liked the K7. It wasn't much good above base iso but the colour was gorgeous and it wasn't as beset by problems as the K5 that came after.
Either go for the K7 or look for a K5II. I'd avoid the K5 like the plague.
Emmanuel Diver Contributing Member • Posts: 620
I'd agree about the noise. Been shooting mine for near ten years at the moment. I do love it to bits though at the moment I'm hoping to grab a k5ii or a k3 at some point in the future. I regularly put photos up on the forum so a quick scroll through that or my Flickr should give you an idea of the shots I have taken with my K7.
www.flickr.com/mannydee
www.pentaxphotogallery.com/emmanuelmdiver
 Emmanuel Diver's gear list:Emmanuel Diver's gear list
Pentax K-7 Pentax K-3 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Sigma 105mm F2.8 EX DG Macro Sigma 24-70mm F2.8 EX DG HSM +2 more
Plakanina
Plakanina Senior Member • Posts: 1,664
I think you should stay with your E3 for now. A great camera and that great 14-54 lens. That's when OLYMPUS had it all together. I am still selling 24X32 prints from that combo.
If you must get a K5 ll with low mileage. I'm in no hurry to replace mine.
 Plakanina's gear list:Plakanina's gear list
Ricoh GR IIIx Pentax K-5 II HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR
zakaria
zakaria Veteran Member • Posts: 6,556
In fact k7 is the the body new design for k5 series.
It is also the beautiful color SOOC.
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
xmeda
xmeda Senior Member • Posts: 1,899
Sure K7 is usable. I have K20D as backup for example. But yes, if you can, rather get K5 or better K5mkII
 xmeda's gear list:xmeda's gear list
Casio QV-R40 Casio Exilim EX-Z110 Olympus XZ-1 Pentax X-5 Olympus XZ-2 iHS +42 more
Fogel70
Fogel70 Senior Member • Posts: 1,885
K7 was the first DSLR where Pentax got the body design right IMO. It does not feel as dated as K20D and earlier cameras. There is still a lot to like about K7 today.
If you can get K7 for cheap go for it, and it can be a good introduction of Pentax flagship APS-C until you get K3.
But as others have said the high ISO performance is the "Achilles heel" of the K7, probably not much better than Olympus E3.
 Fogel70's gear list:Fogel70's gear list
Samsung GX-10 Pentax K-7 Sony Alpha NEX-7 Sony a7 Pentax K-3 II +28 more
