New X3F plug-in for Photoshop
Ceistinne Senior Member • Posts: 1,736
Re: JPG about 1/2 size from Photoshop
Roland_d wrote:
I installed it on CS6 without problem
slow but works fine
JPG are much smaller vs SPP. I suppose there's a quality loss
rd
Roland,
Can you spell out clearly how you did it please. I have tried but cannot get it to work.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD15 Sigma SD14 Sigma SD10 +3 more
Re: New X3F plug-in for Photoshop
Johan Borg wrote:
Ceistinne wrote:
Martin JC wrote:
Johan Borg wrote:
https://m.dpreview.com/news/4126891677/sigma-releases-sigma-x3f-plug-in-for-photoshop-raw-conversion-plugin-for-photoshop
Does this work with stand alone LR or PS? Don't seem to be able to get it to work....
Martin JC,
Wondering if some way could be found to make it work with standalone CS6 or CS5. It should be simple enough for someone to amend the code to suit those earlier CSs. It seems to be just a very basic plugin.
There's an interesting comment from fotorabe here:
https://www.dpreview.com/news/4126891677/sigma-releases-sigma-x3f-plug-in-for-photoshop-raw-conversion-plugin-for-photoshop?comment=0481767329
I just now successfully installed X3F-Plug-in for PS CS6. Only redirected the installation to a new sub-folder "Sigma" in the CS6-Plug-in-folder. While opening X3F-Files you have to "import" files using the "Sigma X3F plug-in for Photoshop".
Johan,
Thanks for the info.  I have tried it but cannot get it to work. Can you spell out how you did it please. Obviously I am doing something incorrectly.
S
Roland_d Regular Member • Posts: 310
Ceistinne wrote:
slow but works fine
rd
Roland,
S
during the Install process,
- it stops before installing the plug-in in a CC folder,
- just over this folder is a CS6 folder
- you chose this CS6 folder  and that's it !
the path:
C:\Programs\Common files\Adobe\Plug-ins\CS6 (instead of CC)
X3F are opened under      Files -- Import -- Sigma…
(since my computer is in French, not abolutely sure of the spelling of folders but it about that)
rd
Sergey_Green
Sergey_Green Forum Pro • Posts: 11,919
Long overdue.
- sergey
Roland_d wrote:
Ceistinne wrote:
slow but works fine
rd
Roland,
S
the path:
rd
Roland,
Thank you. I will try that later.
S
adegroot Senior Member • Posts: 2,953
Does it work with Photoshop Elements?
For me the joy of photography is in the prints I make myself.
 adegroot's gear list:adegroot's gear list
Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma DP1 Merrill Sigma SD15 +14 more
LasseS
LasseS Contributing Member • Posts: 622
Yes, Merrill don't do DNG
 LasseS's gear list:LasseS's gear list
Sigma DP3 Merrill Sigma SD14 Canon EOS-1Ds Mark II Samsung NX20 Samsung NX mini +1 more
dellaaa
dellaaa Contributing Member • Posts: 938
I'm missing the point
Sorry but I'm missing the point of this.  It doesn't look like there are any RAW controls other than fill light available, Why would I use this?  To me it looks like it defeats the purpose of shooting RAW.  What am I missing?
 dellaaa's gear list:dellaaa's gear list
Canon PowerShot G10 Nikon D800 Fujifilm X-Pro1 Sony Alpha NEX-7 Sigma sd Quattro +6 more
D Cox Forum Pro • Posts: 22,651
Re: I'm missing the point
It's probably just proof-of-concept, ready to be developed later into something useful.
larryj Forum Pro • Posts: 10,545
SPP Jpeg vs Imported PS Jpeg
Here is a quick look at the new import to PS add-in and the same file processed to jpeg in SPP. The Jpegs are about the same size, 24 MP for the SPP file versus 25 mp for the PS file. You need another browser program to search and select the files to import because e the add-in can not display the files until imported. Once you get the file imported it is nice to process In PS. You can only import 1 file a a time, a bit of a bummer.
I can not wait for an upgrade to this add-in with more functionality
sd Quattro file processed to jpeg in SPP
sd Quattro file imported to PS and processed to jpeg.
Enjoy
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
Johan & Roland,
Thanks to each of you for your help.
I have it working now in CS6 using "Import" to bring files into Photoshop one at a time only. It is not much faster than working with SPP but I note that the files open into PS as 16 Bits, Colour Space sRGB and at 300 PPI compared to SPPs native 180 PPI. The only control in the Plug In is "Fill Light" which is ok because all the rest can be done in PS.
It is a good innovation and will probably lead on to better, maybe, with the launch of the upcoming  L Mount camera.
S
Re: SPP Jpeg vs Imported PS Jpeg - on size
So I did something wrong but dont know what
I tried it onDP2Q file of DPReview (SDIM0089.x3f (SD!M..?) - 55 697Ko, SPP=18245Ko, via Photoshop: standard 13 610Ko, optimized 12626)
may be different on CC
rd
Johan & Roland,
Ignore my earlier post headed "Re: JPG about 1/2 size from Photoshop" I think the size is dependent on whether the file is left at 16Bit or changed to 8Bit, users choice.
S
idillic Regular Member • Posts: 165
How it works is that the plug-in has the XF3 Fill Light command only before it is available to edit in Photoshop (CC).  Once in - you then use the Filter>Camera Raw Filter which gives you all the raw processing commands found in Lightroom.
It works very well in my opinion.  And long overdue too.
 idillic's gear list:idillic's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma SD1 Merrill Pentax 645D Sigma 8-16mm F4.5-5.6 DC HSM +8 more
Thanks idillic: the camera raw filter note really makes this add-in to PS very useful. I complete most of my Sigma images in Lightroom. Via tiff files out of spp. Now I can work with xF3 Raw files in camera raw and when needed use PS for special processing.😎 Thanks again!!!
larryj
Scottelly
Scottelly Forum Pro • Posts: 11,890
Thank you for those samples Larry. It's interesting that the SPP version shows the clouds so much better, but the PS version seems to have way more micro-contrast (over the top, in my opinion). There appears to be much more detail visible in the PS version, which is quite a surprise. Is that from sharpening that you applied in PS, or from something else?
Scott Barton Kennelly
http://www.bigprintphotos.com
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Sigma SD1 Merrill Sigma sd Quattro H Nikon D810 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +21 more
Scottelly
Most-likely they just added the Fill Light tool for now, because it is a proof of concept plug-in. Having the Fill Light tool means that highlights won't be blown and shadows won't be blocked, if the Fill Light tool is used. Then adjustments can be made in PS after the initial raw processing. It's probably better than using DNG, though I'd like to see a comparison. I don't have PS and refuse to use it, so I can't help there.
xpatUSA
xpatUSA Forum Pro • Posts: 14,253
Enjoy
Thanks for posting this most clear comparison, Larry.
I pixel-peeped and found a considerable different betwixt the two:
To me the images look equally sharp but SPP produced considerably less microcontrast (which some here might prefer, subjectively speakin').
It remains a pity that the cross-hatching effectively halves the Quattro linearresolution, IMHO. In other words, no need to shoot in low res - the high res is already that low.
Nothing like a quick Quattro-bash as the New Year approaches ...
Ted
Sigma DP2 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GH1 Sigma SD15 Sigma 8-16mm F4.5-5.6 DC HSM +14 more
dellaaa
Thank you very much.  I have only been using Photoshop my whole life, I admit I have a huge mental block with PS.
I am an IT guy and find PS repugnant to work with, IMHO it was not designed for photo editing, the newer sw packages like Topaz, RT, ON1 etc. look like pictures and photographers were what they were designed for.
Seems like a roundabout way to do this, PS should have updated ACR directly.
PS I find SPP incredibly unstable on Win 7 and Win 10.  It crashes and requires restart routinely
Scottelly
Interesting. I haven't heard that sort of thing for a few years. Are you using a new version of SPP or an old version? SPP 6.6.0 and 6.6.1 are extremely stable on the Mac Mini that I use them on, which is running with OSX El Capitan. I've used a few older versions on Windows 7, and it seems stable on that computer, though it's a workstation computer with ECC memory, so it might be a much more stable platform than what your using. I haven't used the Windows 7 machine much, so I can't say how stable SPP is on that machine. I've only used it a few times to run tests and stuff. It's not much faster than the Mac, and since it doesn't have a big hard drive attached and doesn't have USB 3 ports, I don't use it as my main processing machine. If you're using SPP 5.5.3, I'd be interested to know that. A lot of people seem to suggest that as the best version of SPP for processing Merrill raw files, but it it isn't stable, I won't suggest people use that.
