Test shots from Vuze XR
Started Dec 21, 2018 | Discussions
fs9019 Junior Member • Posts: 29
Here're some test shots from the Vuze XR. Can anybody here tell me how they compare to the Fuji W3?
Thanks in advance.
Brab New Member • Posts: 1
Re: Test shots from Vuze XR
The w3 has narrower field of vision, so less distortion - but it won't give you a 180 degree perspective.
I don't think the image below has been reduced in size.  Its a jpg from the w3 without the corresponding .MPO file (which I assume has more of the 3d data).
relaxman Forum Member • Posts: 50
Yeah, 180 is for Virtual reality, while W3 has a narrow FOV. In fact, very narrow.
Can you share MPO too? I ilike to see right eye sharpness.
thanks
threed123
threed123 Senior Member • Posts: 1,490
Re: Test shots from Vuze XR vs. W3 examples
Your shots are nice and sharp and of course, very wide field of view.
The W3 has a much narrower field of view as others have said, but also has a zoom feature, which allows you to get much closer and still maintain some depth perception. Here are some examples from my Tanzania, Africa trip in 2016. I took a lot of 3D gopro video and also 3D W3 stills. I was glad I brought it along. I had to juggle 4 cameras all together, though.
These are cross-eyed SBS created from MPO files straight out of the camera. The camera has wide lens spacing for added depth.
W3-African Elephant- Tarangire Park, Tanzania -- SOOC
W3-Impala Harem-Serengeti, Tanzania -- SOOC
W3-Cheetah-Serengeti, Tanzania -- full zoom, SOOC
W3-Lion feeding cubs, Ngorongoro Crater Park, Tanzania -- full zoom, SOOC. Overlooking a culvert. I tried to keep some of the concrete in view to give it depth.
OP fs9019 Junior Member • Posts: 29
thanks
Let me figure out how to export mpo.
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
thanks
A MPO file is just a pair of left and right JPG images saved in a single file.
Here is the L-R JPG version saved using StereoPhoto Maker to extract the two images and place them side by side in a viewable JPG file.
Balloon seller at Bangkok local street market.
Here is the cross eyed version saved using StereoPhoto Maker.
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
thanks
There's no MPO right out of the camera. I'm using a Mac, how should I export the MPO? And why do I need to export MPO?
watchfull Senior Member • Posts: 1,006
What kind of glasses I need to watch the Cross Ryed Images ..??  I  am new to 3D photos ..??
 watchfull's gear list:watchfull's gear list
Sony RX1R II Sony a7R II Nikon AF Nikkor 180mm f/2.8D ED-IF Sony FE 70-200 F4 Sony FE 85mm F1.8
threed123
You don't need glasses, just stare at the two L/R images and make yours slightly crossed until you see a stereo image.
🥴 Doesn’t work for me.....
