Panasonic 42.5 - 1.7 lens makes me look fat !
Started Dec 20, 2018 | Discussions
Badger Girl New Member • Posts: 1
hi
i bought the Panasonic 42.5 - 1.7 lens a couple of months ago and I just can’t seem to get the shots I want. I am a complete beginner. I use my camera for short videos in nature with me as the subject playing musical Instruments... etc
my question is why does the lens zoom in so much ? I also use a canon g7x for vlogging and this frames the shot just fine I have also noticed that the Panasonic seems too fatten me up along with other subjects - where I look thinner on the g7x. Without stating the obvious of me loosing weight can someone explain why this lens does that so I know what to not buy next.
i have to stand several steps away to get the same shot with the Panasonic as it zooms In so much which I think is adding to the fattening of subjects
any advice would be great thanks !
Canon PowerShot G7 X Panasonic Lumix DMC-G7 Panasonic Lumix G 42.5mm F1.7
Adielle
Adielle Senior Member • Posts: 1,754
Re: Panasonic 42.5 - 1.7 lens makes me look fat !
It can't make you look fat. 42.5mm focal length in Micro Four Thirds is equivalent to 85mm in Full Frame. It's a good focal length for portrait pictures (head and shoulders) as well as full body pictures or many other things. This is a longer focal length than that of a more "standard" lens, like 25mm or 30mm. I find 30mm (equivalent to 60mm in full frame) to be the best for general purposes, and the 30mm f/2.8 lens is fantastic.
Tom Axford Forum Pro • Posts: 10,100
That lens has a focal length of 42.5mm, which is nearly twice as much as a standard lens of 25mm focal length.
The 42.5mm lens takes only half as wide a view as the 25mm lens and so to get a person to just fill the frame, you need to stand nearly twice as far away.  That changes the perspective.
Have a look at this tutorial which gives some examples of using lenses with different focal lengths.  Just bear in mind that all her examples are on a full frame camera which needs double the focal length of your Micro Four Thirds camera to get the same picture.  So when she uses a 16mm lens, that would be much the same as an 8mm lens on your camera.  When she uses a 150mm lens, that would be much the same as a 75mm lens on your camera.
Anyway, her examples will give you an idea of the different perspective you get from different focal length lenses  (although she is primarily talking about getting a blurred background, but the examples show perspective differences as well).
jaeae Regular Member • Posts: 284
Tom's link is good advice!
To achieve "undistorted" classic portrait view you should use perhaps 45 - 90 mm equivalent lenses.
I wonder how much of this "makes you look fat" is because people have accustomed to wideangle views that tend to make one look thinner. Cell phones generally have wideangle lenses, something between 24 .. 30 mm equivalent.
(unknown member) Veteran Member • Posts: 7,274
Perspective - Pose - Lighting
Withing same format, same F-stop value will generate same DOF when subject is framed same size (same magnification).
But, shorter focal length will include more background and it will look sharper, while longer focal length will include less background and it is blurrier.
As you change the camera distance to subject, you change perspective and that changes how roundish or thin does ie. Person face look.
Shorter focal length typically makes face look thinner but nose gets larger and eyes move to edges
Longer focal length typically makes face look rounder but nose gets smaller and eyes get moved to center.
The most flattering perspective is subjectional. As every person face is different, it is required that camera distance and angle is customized to each person.
The focal length does nothing, perspective does.
There is one common thing, about 4.5 meters is the distance that humans recognize and remember the face. So when someone is recalled, the face is memorized from that distance, what makes one of the best if not the best distance.
To get a person look good, camera angle in height needs to be found good and then the person side that is more fitting for theme. A good trick for some subjects is to take two chairs, photographer stands on one and photographs downward on subject, that's about 4-5m from the camera, standing on ground while places other leg on the second chair and leans forward by placing hands on the leg that is on the chair. This will slim cheek and chin, make body look smaller and thinner while head gets tilted little sideways and up. To find a better perspective, chairs distance is changed to closer or person side is changed.
And that doesn't yet include lighting, what is second part from a model pose and camera perspective.
For a m4/3 system a great starting point is 100mm and f/4 for a half-portait or headshots.
WT21 Veteran Member • Posts: 5,473
Badger Girl wrote:
hi
Just to clarify, this lens does not "zoom" It is what is called a "prime" or "fixed" lens. It only has one focal length. The G7X does have "zoom" where you can change the focal length, getting closer or further.
The 42.5mm focal length is referred to as "moderate telephoto" or "classic portrait length" in m43 and frankly is one of the more ACCURATE focal lengths you can use for a subject. Sorry.
The rest of the posts are helpful to read through.
You should perhaps consider a Panasonic 20mm 1.7 or 15mm 1.7 if you want something a bit wider angle.
 WT21's gear list:WT21's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 100-300mm F4-5.6 II Olympus E-PL7 Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 +6 more
I do not understand what you mean by 'ACCURATE' in this context.  Could you clarify, please?
Rmark
Rmark Senior Member • Posts: 1,188
I thought that the Panasonic G7 uses a crop of the sensor for video which would create the appearance of a "zoom" effect.
 Rmark's gear list:Rmark's gear list
Panasonic LX100 Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 1.4x Teleconverter EC-14 +5 more
AminF Contributing Member • Posts: 655
I think that's exactly what it is.
The position and lens focal length of the average "selfie" gives a totally distorted view of what we actually look like.
Get someone to take your phone 15 feet away from you and take a photo and your face will look fatter than when you take it yourself.
That's the reason I've just ordered an ultrawide angle lens - for my own selfies!!
jaeae wrote:
Tom Axford wrote:
Have a look at this tutorial which gives some examples of using lenses with different ...
G1Houston Veteran Member • Posts: 3,188
You were probably too close to the subject. (nt)
No text.
 G1Houston's gear list:G1Houston's gear list
Nikon D7100 Panasonic Lumix DC-GX9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Nikon 85mm F1.8G +6 more
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
Badger Girl wrote:
hi
You're used to recording yourself from up-close with a wide angle (short focal length) lens, which, if the camera is close to your head, will make whatever is farther away (i.e. your body) look smaller. It's a simple matter of perspective distortion. If you want the same look that you get from your Canon, choose a shorter-focal-length lens for your Panasonic. IOW, your Canon is lying and your Panasonic is telling the truth about the actual proportions of your head and body.
"No matter where you go, there you are." - Buckaroo Banzai
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
windmillgolfer
For M43 you need to multiply the 42.5mm by 2. So, you are shooting with a classic portrait lens at 85mm equivalent - that is for capturing shoulders upwards - the face. It's a great lens https://www.flickr.com/photos/dieselgolfer/albums/72157690660973971
Cafe Racer Senior Member • Posts: 2,137
Look at this
Badger Girl wrote:
hi
You have the right lens for portraits. It gives a natural perspective.
 Cafe Racer's gear list:Cafe Racer's gear list
Olympus PEN E-P1 Olympus PEN E-P5 Panasonic G85 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital 45mm F1.8 +4 more
windmillgolfer wrote:
Probably meant appropriate, not accurate.
OK, I was thrown by your use of all caps!
hindesite Veteran Member • Posts: 4,893
Yeah, but the OP never mentioned the G7, or what camera they were using.
lol. Windmillgolfer didn't write that.
What I meant is better shown here, and probably the right word is "natural" but the original OP of the thread claimed that the 42.5 made them look heavier. Unfortunately, the 42.5 is going to provide a far more accurate (or natural) portrait than a wide angle (which invites perspective distortion if you are doing e.g. a headshot) or a long telephoto (which can overly flatten an image).
https://www.dpreview.com/forums/post/62071210
Pixel Pooper Veteran Member • Posts: 3,978
Some of the other replies seem unaware that perspective distortion goes both ways. The 42.5mm is a good focal length for a head and shoulders portrait because the distance gives a pleasing perspective, but for a full body shot you will be too far away and the more flattened perspective makes people look fat or stocky.
You definitely need a wider lens, but if you go wide you will be too close to the lens and the perspective distortion will make your guitar look enormous. You probably need a 17.5mm for the type of shot you describe, but your best bet will be to get a kit zoom lens so you can see which focal length you prefer.
