Linear vs circular polarisers
Started Dec 19, 2018 | Discussions
Tom Board New Member • Posts: 1
In this article it discusses the reason linear polarisers don't work with many modern cameras that use TTL metering and autofocus:
In the article, the author Michael Reichmann states:
"The reason for this is that both of these systems use semi-silvered mirrors to siphon off some of the light coming through the lens. If that light is linearly polarised it renders either the metering or the autofocus ineffective. This means that you're going to have to buy circular polarisers unless you're shooting with a pre-1970s camera, or a view camera."
Can anyone here confirm that this applies to mirrorless cameras? I'm assuming it does, but not knowing the technical aspects of how the metering works in my GH4, I just want to make sure. Since I am using mostly manual focus lenses, as long as the metering works a linear filter would be a good choice for me.
Thanks.
Panasonic Lumix DMC-GH4
Skeeterbytes Forum Pro • Posts: 23,182
Re: Linear vs circular polarisers
Mirrorless do not require CP polas, any linear pola will do. Linears are generally less expensive and have a lower filter factor than circular, but coated linears seem rare and are much more expensive than uncoated ones.
Rick
Martin Meier Contributing Member • Posts: 640
All my CPL filters are priced $4.99 to $5.99, some people think
price must be $80 to $160 (or higher)  .... hahaha
 Martin Meier's gear list:Martin Meier's gear list
YI M1 Panasonic Lumix DC-GX9 Fujifilm X-T30 Fujifilm XF 16-80mm F4 +1 more
BBbuilder467 Veteran Member • Posts: 7,057
Thanks.
I've had no problem at all using both new or 30 year old linear polarisers with my Panasonic system. I can't tell the difference between the PL and CPL if I didn't know which was which.
The last I got was from Adorama because they had Hoya at bargain prices in 46mm.
Michael Benveniste
Michael Benveniste Veteran Member • Posts: 6,378
According to Panasonic UK, you should use a circular polarizer, but I admit I don’t understand why:
https://www.lumixgexperience.panasonic.co.uk/lumix-academy/using-lens-filters-and-converters/#.XBrtIqROmEc
New linear polarizers are fairly scarce — there are only a couple of odd corner cases where a linear polarizer is preferred.  With a more expensive polarizer, what you are paying for is the name, coatings, sometimes high transmission polarizering film, sometimes “encasing” (Kaesemann), sometimes brass hardware, and general fit and finish.
A multicoated filter will transmit about 7-8% more light than an uncoated filter.  Uncoated filters are also more likely to cause flare.  I own polarizers in a lot of sizes, and most are multicoated.
Light travels at 2.13085531 × 10^14 smoots per fortnight. Catch some today!
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D800 Nikon 1 V2 Nikon D7200 Panasonic Lumix DMC-GX85 +46 more
s_grins
s_grins Forum Pro • Posts: 14,011
Mirrorless cameras can use both types
Importance of polarisers is grossly exaggerated - today software does better job in eliminating haze and improving contrast.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
tt321
tt321 Forum Pro • Posts: 13,854
The reason is very simple. All Panasonic-branded PL's are CPL's :), which is partly due to the below.
CPL's have become the commodity items because of years of AF SLR market domination. Now that mirrorless no longer requires C, it may take an equally large number of years for linears to come back, if at all.
So price-wise, there is no reason to buy a new linear, but there is equally no need to buy a CPL if you already have an old linear around.
Metering in mFT does not use a mirror to divert light. It uses the imaging sensor. So there is no need for C.
epozar
epozar Senior Member • Posts: 1,969
no
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
dwkyre Regular Member • Posts: 212
Can't do it in software if the data isn't in the file. You can do a lot of great, basic haze removal and contrast improvement in post, but a skilled photographer taking the time to use a filter will still produce some photos that are beyond what can be done in software.
Same goes for gradual NDs. You can do a regional post processing job, but you will never get the same total dynamic range in the photo as using a grad. I guess multi-shot HDR can get you there, but then you really want a tripod for the best results, so more gear is more gear.
And you can't replicate the polarizer's effect on reflections.
 dwkyre's gear list:dwkyre's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic 20mm F1.7 II +6 more
Travis Butler
Travis Butler Senior Member • Posts: 1,984
From what I'd heard (and which seems to be confirmed by the other messages in the thread), Linear vs circular isn't relevant for cameras using contrast-detect autofocus.
The question I haven't seen answered is whether it works with mirrorless cameras that have phase-detect systems as well? The E-M1 I and II are the only ones I currently know of on the M4/3 roster, so it's more of an academic issue for me now - but if there is a Pen-F successor that includes phase-detect...
Flickr at https://www.flickr.com/photos/the_prof67/ Warning: Heavy Learning in progress.
 Travis Butler's gear list:Travis Butler's gear list
Fujifilm X20 Nikon Coolpix A Pentax Q Pentax K-50 Panasonic Lumix DMC-GM5 +21 more
