Is my Canon 24-105 IS STM damaged?
Started Dec 18, 2018 | Questions
HarkoBro New Member • Posts: 4
Please help me. Ten days ago my Canon 24-105 IS STM has very bad photos in which it is light. Whether it was damaged or something bad happened. How can I fix this? You can see the pictures.
I thank you very much!
I think the light is leaking, but this has not happened before.
Please help me.
BlueRay2 Forum Pro • Posts: 14,816
Re: Is my Canon 24-105 IS STM damaged?
Please help me.
why would you hold your camera directly to a light bulb...just amazing what some people do to their cameras! your camera/lens could have an issue but these 2 shots you have posted don't say anything. if it was me, i'd go out and take a shot of something that is available (a tree or a hose or something) and see how your camera behaves! i am sure no one has answered your post because it looks like a troll post!!!!!
we are all one consciousness experiencing itself subjectively.
OP HarkoBro New Member • Posts: 4
There were no leaks on the previous photos on the left and right sides of the light. However, now it happens that when I photograph the light, there is always a leak on one side. I'll insert pictures before and after.
Before
After
I'm not kidding, I'm very worried ...
I'll add more pictures before I've damaged it.
In these pictures, the light does not leak like the one on top. And I do not know why this is happening and whether the damage is huge or not?
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
It is amazing how some people will respond to a genuine question
I suspect that you have some grease or a scratch on an outer surface. Did you inspect the lens surfaces to see if this is the case? Or try to take image OF the lens, so we can see how the surfaces look like.
Rgds/Kjeld
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
lighthunter80
lighthunter80 Contributing Member • Posts: 990
  1. Are the front and back elements of the lens perfectly clean, free of fingerprints and oils?
  2. Did you use any type of filters like UV protection etc?
  3. Did you go to e.g. Flickr and research this lens for pictures taken into bright light sources and do they eventually exhibit rth same phenomena?
  4. Is your sensor clean which I don't think is the issue but better ask?
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
Lemming51
Lemming51 Forum Pro • Posts: 15,278
The odd flare also appears to be related to the aperture being stopped down.  Maybe the aperture blades are sticking or damaged.  Inspect by setting small aperture f/8-16, press/hold DOF Preview button and look in the front of the lens.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
You were right! There was a bit of fat on the part of the lens that was attached to the sensor. And it did such a bad picture. THANK YOU VERY MUCH!!!!!
You were right! There was a bit of fat on the part of the lens that was attached to the sensor. And it did such a bad picture. I was scared a lot, because I thought the repair would be very expensive. And I'm a beginner in photography. THANK YOU VERY MUCH!!!!!
lighthunter80
Glad you found the root cause and were able to fix it!
I am always super careful never to touch the back side of my lenses when changing them. Finger prints are most typical to cause flare issues and more so on the back element than in the front.
