Canon EOS M50 With Sigma Lens Using EF-EOS M Adapter
Started Dec 18, 2018 | Questions
matthewpark New Member • Posts: 4
Hi , Im new to photography. My first camera is Canon EOS M50 with double kit lens (15-45 and 55-200)
Two days ago my friend gave me EF-EOS M adapter. Then Im starting thinking about buying EF lenses.
My friend suggested me to buy Sigma art lens 50mm or 85mm. Which one do you think should i purchase? I'm mostly shots portrait.
Canon EOS M50 (EOS Kiss M)
Jura S Senior Member • Posts: 1,980
Re: Canon EOS M50 With Sigma Lens Using EF-EOS M Adapter
Why not Sigma 50-100/1.8A?
It's on the BIG side though.
OP matthewpark New Member • Posts: 4
I saw the review on youtube, from Tony Nortup if I'm not mistaken?
He said it has great optical quality that can match full frame....but seemed to have problem with the focus
It doesn't. I've tried this lens on 7D, 80D, 6D, eos M and M50.
There's no inconsistency.
thunder storm Forum Pro • Posts: 10,139
If you work with models or other people who are posing 85mm will work. It will magnify the background more, and therefor the blur in the background will be more apparent. The 85mm is reported to be a little bit sharper. You will need shorter shutterspeeds to avoid blur caused by camera shake.
If you do "candid portraits" 50mm is more flexible. If you want another angle with the 85mm you have to walk longer so the moment could be gone once you are there. With the 50mm you walk a shorter distance to do this, so you're faster. It is also easier to have enough distance indoors.
For me 85mm is nice in a zoom, but in a prime it is not flexible enough, as all my portraits are non-posed.
If your facts are different we could save the peace just by calling it copy to copy variation.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
For me 85mm is nice in a zoom, but in a prime it is not flexible enough, as all my portraits are non-posed. Having 85mm in a zoom i will end up with a view shots at 85mm though, which are often keepers.
Buy 50/1.8 STM. Just to have a feeling what a prime is. It's a bargain endeavour.
Thanks Thunder Storm, I really apreciate your reply
That's awesome! I think I'll try to rent lens first before buy it. It's between Sigma 50mm f1.4 or 50-100 f1.8 .
By the way, do you think viltrox speed booster will improve the image quality noticeable?
It is always good to rent before you buy. I did rent the sigma 50-100mm, and i can confirm with the M50 there are no AF problems.  I took a view shots with my 70D, and i am not sure if this works quite as well. I took not enough shots to say more about it.
As long as you want to shoot it on a M50 i would not hesitate to buy it, as the AF problems reviewers are reporting are DSLR-related problems.
If you rent a lens, make sure it has the latest firmware!!!  I have a sigma dock so i updated the lens myself. If you don't, make sure the company you will rent from will have the lens updated for you.
With these kind of lenses - especially the zoom - i would just spend a view extra bucks and go with the OEM adapter. It would be silly to have lenses without compromises, and an adapter eventually occasionally screwing up your IQ, right?
I have both the Viltrox and the Canon adapter, but not the lenses at hand you want to buy. I am also not sure if i can manage to create all kind of situations that could possibly cause problems.
tocar Veteran Member • Posts: 4,533
For portraits 85mm would be better.  I once read that the eyes can see in 100mm equivalent.  But make sure the lens itself is sharp.  Renting a lens and buying one can be like night and day as far as sharpness.
 tocar's gear list:tocar's gear list
Canon PowerShot S5 IS Canon PowerShot SX50 HS Nikon Coolpix P900 Canon EOS 5D Mark II Canon EOS M +1 more
It will change the angle of view, DOF and project more light. It will also produce more vignetting and probably decrease corner sharpness.
This one is taken with 6D. It's an approximation of what could be a look on M50 with speedbooster.
Lost99999 Regular Member • Posts: 336
Hi Matthew, a lot of advise you got came from the real pro’s.
If this is your first camera - you should first check what you want to photograph?
If you are gonna be taking snaps of your kids playing, perhaps sports, perhaps wildlife, perhaps street photography, landscapes, video, night photography, etc.
each focus area has a range of lenses available, and each lens in a segment has pro’s and con’s.
For the moment i would enjoy shooting .. and take a look in 4 -6 month on what kind of pics you take and what settings you used ( i discoverd i took a lot of landscape always at the 24 mm of my 24-105 mm zook range .. so my next purchase was a more wideangle lens, for landscapes, still compact and not too expensive or bulky. )
 Lost99999's gear list:Lost99999's gear list
Canon EOS RP Canon EF 200mm f/2.8L II USM Canon RF 24-105mm F4L IS USM Canon RF 50mm F1.8 STM Canon RF 16mm F2.8 STM
Samseed666 New Member • Posts: 3
That must be something that only works with that lens ?! Currently i brought a Sigma UC Zoom MC AF Lens (70-210MM) and after a little homework im told a EF-EOSR adapter is needed ?! i have FD-EOSM, MD-EOSM, EF-EOS M2 0.71x Speed Booster (Canon 50mm). and NONE OF these seems likely to connect my New Lens to my Camera ! Also this is a vintage lens which im a collecter of ! So when i saw the Pic of the spoken lens i was a bit confused. Wishing the guy luck that needs this ! Beleive me i was looking forward to playing with my new toy ! But as a kid cant open unitl Christmas ?! 😂 😂 😂 Good Luck...
jackwelch Senior Member • Posts: 1,087
There's a few I would try:
EF-S 55-250mm
EF 70-300mm IS ii (there's many versions of this so better check which is the sharpest one)
Sigma 150-600mm contemporary
Also if you are into portraits might want to check out the Viltrox Speed booster (I see people keep saying it'll turn your eos M into a full frame.
Did some Homework on this and also awaiting a reply ?! 1. This Sigma Lens is a " A" Type 2. While well hidden FOTODIX may have the answer for this. (FOTODIX PRO LENS MOUNT ADAPTER FOR SONY "A" LENS TO CANON EF MOUNT CAMERAS) 3. Prices vary where you get it from ?! Go to FOTODIX Site and cut out all #MiddleMen ! #Theive$.. Never had any problem with any of my vintage lens ?! Yet this stuff about to place me on A Vintage Lens Diet Geez ?! Good Luck All !!!
