Panasonic make smart features - "AF SCP"
Started Dec 17, 2018 | Discussions
Max Iso
Max Iso Veteran Member • Posts: 8,652
I owned a GX8 and GX7, neither had this, they have been working on new things (is it on others besides the G9?). It's called AF point scope (SCP), it's basically a FN button feature that triggers a PINPOINT AF PIP square as long as you hold down the FN button.
I have loved PPAF ever since i used it on the GX7, it's great for maneuvering to the exact spot you want in focus. The smallest AF square is already pretty small, SCP lets you get your zoom square to about 1/3 of that size, which is a very tiny overall focus point.
It might not be as easy on every body since you have to hold down a FN button to engage it (not sure if it can be set to toggle), luckily the G9 has several buttons to choose from. But it's an improvement on an already slick design, i really like where Panasonic are going with their features.
"You taught me hate, I'll teach you fear..." -
 Max Iso's gear list:Max Iso's gear list
Nikon D300 Olympus E-M1 II Canon EOS M50 Canon EF 100mm f/2.0 USM Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
Panasonic Lumix DC-G9 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
alcelc
alcelc Forum Pro • Posts: 19,003
Re: Panasonic make smart features - "AF SCP"
GX7 and GX85 has to select PPAF by entering the AF mode and select it, a 2 steps operation.
However when we lock focus, keep shutter half pressed, turn the Focus ring of native M43 lens will switch into MF mode, the PIP magnified focusing screen prompt up, as well as FP (GX85 only) for manual focus fine tuning. It can call up a similar operation like PPAF in 1 step. Could it serve your purpose?
Albert
Max Iso
OP Max Iso Veteran Member • Posts: 8,652
The problem with manual focusing is it's not as fast and the only issue with pinpoint auto focus is the Box will eventually disappear and I don't have control over that. This new SCP mode gives me more control over it without giving up the automation that I like.
Perhaps I was unclear in my original post but this new version on the Panasonic G9 is perfect. I was just curious if anybody else had found it very useful and if it's on any other cameras.
Ranlee Senior Member • Posts: 2,258
Max, there is a menu item that allows this function to be toggled.  Find it in the focus menus under AF Point Scope Setting - "Keep Enlarged Display" should be turned on then its push to turn on and push again to turn off.
Randy
 Ranlee's gear list:Ranlee's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DC-S5II Canon EF 200mm f/2.8L II USM +10 more
Max Iso
Awesome thanks you just saved me the time going back through the menus.
