Guide to create DCP Colour Profiles for DXO PhotoLab, Lightroom and Photoshop
Started Dec 17, 2018 | Discussions
DenImage Veteran Member • Posts: 3,685
Note: I have posted this in other DPReview sub-forums, but thought others in this forum may benefit.
I know others have probably posted similar, but I wrote this guide for anyone that needed further info:
Download Adobe DNG Converter here:
https://helpx.adobe.com/au/photoshop/using/adobe-dng-converter.html
Install DNGConverter_11_1.exe
Download ColorChecker Camera Calibration software here:
https://www.xrite.com/service-support/downloads/c/colorchecker_camera_calibration_v1_1_1
Install ColorCheckerPassportSetup, and select Desktop ColorChecker Passport when prompted.
Goto the DPReview Studio shot comparison page:
https://www.dpreview.com/reviews/image-comparison
Select the Required Camera from the drop down list.
Select RAW and the lowest ISO.
Rightclick the blue RAW link, then Leftclick "Save target as" and save the RAW image.
Run Adobe DNG Converter, then convert the downloaded RAW image to DNG.
Run ColorChecker Passport, then Drag&Drop the DNG file into the window.
Click Create Profile, then save the DCP file to the default directory.
Note: the default directory is usually \AppData\Roaming\Adobe\CameraRaw\CameraProfiles
Run Lightroom or Photoshop, and select the DCP profile in the Color Profile Browser.
If you are using DXO PhotoLab, copy the DCP file to the following directory:
C:\Windows\System32\spool\drivers\color
Then in DXO PhotoLab, select the images you wish to process, then goto the Customize Window.
Select Color Rendering, choose Catagory - DCP profile, Rendering - the required camera DCP, Intensity = 100
Export as required.
Den
 DenImage's gear list:DenImage's gear list
Sony a7R II Sony a7 III Sigma 8mm F3.5 EX DG Circular Fisheye Sony FE 55mm F1.8 Sony FE 100mm F2.8 GM +7 more
