Soccer with E-M1 Mark II + 75-300mm II , I'm impressed
Started Dec 16, 2018 | Discussions
JohnGR
JohnGR Forum Member • Posts: 96
14
I recently tried to photograph a football game of my nephew. Because the point I was standing was far enough I decided to use the 75-300. The settings i put on was Shutter Priority, 10 fps, Auto Iso, C-AF +2. The result was impressive for this combo and the truth is I did not expect it. The C-AFf system worked extremely well and almost all the photos were focused properly. All photos are SOOC jpeg's, resized for posting.
Τhe first batch was under cloudy weather.
Ιn the second batch the sun just appeared.
 JohnGR's gear list:JohnGR's gear list
Pentax K-3 II Olympus E-M1 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro Pentax 16-85mm F3.5-5.6 WR +2 more
Skeeterbytes Forum Pro • Posts: 23,182
Re: Soccer with E-M1 Mark II + 75-300mm II , I'm impressed
The combination is working well for you.
Rick
JaKing
JaKing Veteran Member • Posts: 6,300
John, these look good, specially considering that this is a (relatively) cheap lens. Well done.
I bought one recently on a bit of a sale (AUD$399, about US$290, normally AUD$499 MSRP).
Sitting in a chair with arms tucked in, I can get sharp shots at 300mm @ 1/15th with subject distance of 3.5-4.0m. Sharp enough to read the fine print on a dress making pattern, and the print is very cleanly defined.
With my E-M1 MkII, I find that standing up without any support, I need to keep the shutter speed well up to have any hope of getting sharp results at 300mm with a subject distance of around 12-15-25m. The lens itself is quite sharp enough when used supported, just that I am wobbly ...
From your EXIF, I see that you have kept the ISO up with resultant high SS. I think that this is the secret of getting sharp images with this lens, and other similar lenses. Either that, or have the simply superb technique that some here routinely exhibit. I'm not as good as that ... .
Maybe there is sample variation with this lens, but I suspect that many do not realise just how good your technique has to be, and how steady the lens must be, to get sharp results from these long FL lenses at any distance. The slightest movement, and the results are very soft.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
JohnGR
OP JohnGR Forum Member • Posts: 96
Rick
Indeed,
Thank you Rick.
macsesso Regular Member • Posts: 272
Great shot of the player in white committing those fouls
 macsesso's gear list:macsesso's gear list
Panasonic Lumix DMC-FZ300 Panasonic ZS100 Panasonic Lumix DMC-ZS60 Olympus E-M5 II Panasonic G85 +6 more
JohnGR
Hi John,
All the shots was handheld and for sure the technique helps but as you say high shutter speed are the factor. Apart from these all photos from this lens are very sharp even at 300mm,i am very happy owner.
greetings
Bassam Guy Veteran Member • Posts: 4,885
Impressive but the light shirted guy in the first few shots should have been penalized
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
JohnGR
JohnGR
the referee did not even give a foul
Greetings
rsmithgi Senior Member • Posts: 2,939
Very nice shots. One suggestion is to get lower, especially with the young kids. I purchased a very small, sturdy, foldable stool to sit on.
https://www.amazon.com/gp/product/B073RZTXSQ/ref=od_aui_detailpages00?ie=UTF8&psc=1
It is very small and light weight. Too short for normal use but for photos, I find that my elbows rest right on my knees when I use it.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
JohnGR
Thanks for the suggestion. I will consider next time.
John
JohnGR
Another game
5
Another game today. Both teams played for the victory, but the yellow team was superior and they had an very good girl goalkeeper.
The success rate also in the C-AF was very good. Few photos were blurry and probably due to my own mistakes.
John
One of the sequences to test the AF.
P5190101
P5190102
P5190103
P5190104
P5190105
acfo Senior Member • Posts: 1,500
Re: Another game
John
I especially like this one. As if standing right next to them. Look at the determination on their faces...
 acfo's gear list:acfo's gear list
Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
JohnGR
Re: Another game
Three years later, the same setup in very difficult lighting condition. My nephew also three year older.
Re: Another game
They get fast, quickly, don't they? Plus the field grows as the years pass, adding to the challenge. Have fun!
Rick
