Viltrox Speedbooster - Compatibility with my Lenses
Dec 16, 2018
7
Hi Folks, Just thought I'd share the results of my trying some of my lenses with the Viltrox EF-EOS M2 Speedbooster...
I tested these lenses on a Canon EOS M2 camera (I also have the original EOS M, but have not tried the Viltrox on this camera yet.
This "test" is strictly regarding whether the lens autofocus worked and whether the 1-stop speed increase was achieved. The following lenses achieved both working autofocus and the 1-stop speed boost:
Canon EF 200mm 2.8L
Canon EF 70-200mm 4.0L
Canon EF 35mm 2.0 (the old screw drive 35mm 2.0)
Canon EF 40mm 2.8
Canon EF 100mm 2.0
Canon EF 28-105mm 3.5-4.5 USM
Sigma 50mm 1.4 DG HSM
The Canon EF 50mm 1.8 Mark II (nifty fifty) partially worked - it autofocuses but the max aperture is still F1.8 (no "speed boost").
The Canon EF 85mm 1.2 L Mark II did not work - perhaps because of it's focus by wire system. It reports a max aperture of F1.0, but when trying to focus, the view screen goes very dark and it hunts for focus badly. If you hold down the shutter button, the viewfinder (rear screen on the EOS M2) is a normal brightness - and you can manually focus the lens.
The Sigma 50mm 1.4 DG HSM was a pleasant surprise. You get F1.0 and autofocus works. I find that using the zoom in feature to focus allows the autofocus to work much better with the Viltrox. This Sigma lens did NOT work at all until I upgraded the Viltrox to the latest v1.4 firmware. After the firmware update, both autofocus and speedboost were working! My Sigma 50mm is one of the later models of this lens - older "versions" of this same lens had a crinkle paint finish, mine has the smooth, flat paint finish.
The EF 28-105 USM is a nice surprise. Its an older lens from my film camera days, but has a ring type USM motor. It speed boosts to F2.5-3.2 and stays F2.8 until just under 70mm. The ring type USM lenses seem to work nicely with the Viltrox.
The EF 35mm 2.0 is also really nice for another reason - it has an incredibly short (25cm) minimum focus distance. Mine is a very sharp lens in the center, even at F2.0 (F1.4 speedboosted). So you can achieve nice subject isolation, with a sharp subject, against a relatively wide blurred background for context.
The EF 70-200 4.0L - the stabilization also worked as expected.
The EF40mm 2.8 - with the Viltrox and this lens, it is actually shorter (more compact) than the EF-M 18-55 kit lens! So, you can walk around with essentially a nice small "F2.0" 50mm on your M series camera...
I picked up my Viltrox using Ali Express from their Viltrox store. Delivery took about 2 weeks to the states. Paid about $100. What a great gadget!! This type of stuff helps make photography fun.
I hope this post helps some folks decide on whether the Viltox will work with their lenses.
