Small sensor Powershot for macro photography
Started Dec 14, 2018 | Discussions
Geenine Contributing Member • Posts: 990
I have been hired to shoot jewellry. Employer wants more DOF than a DSLR can give. I want to know what is the best Powershot for macro photography. A hotshoe is needed to trigger studioflashes. Raw files are not needed. They can be new or old. I can get a G11 for a low price, how is that for macro?
I'm grateful for any advice you can give me
 Geenine's gear list:Geenine's gear list
Canon PowerShot G1 X Canon EOS-1Ds Mark II Canon EOS 5D Canon EOS M Canon EOS Rebel SL1
Canon PowerShot G11
Chaplain Mark
Chaplain Mark Veteran Member • Posts: 6,539
Re: Small sensor Powershot for macro photography
Not sure what you mean by more depth of field "than a DSLR can give?"
That statement for me does not make sense; could you please clarify?
Thank You,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
In pursuit of photographic excellence.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III Sony a7C Sony FE 135mm F1.8 GM +3 more
OzarkAggie Senior Member • Posts: 2,153
Possibly a SX50 which can focus very close to the lens would work. You might need an add-on close up lens but maybe not.
You should also consider the EF-M 28mm macro mounted on an M2 or better.
Increasing DOF can also be achieved by stacking images.
 OzarkAggie's gear list:OzarkAggie's gear list
Canon PowerShot A590 IS Canon PowerShot G1 Canon PowerShot Pro1 Canon EOS 10D Canon EOS M +11 more
I2K4
I2K4 Senior Member • Posts: 1,441
Given a) no interest in RAW, and b) money is a consideration: the older G and SX and even my old S5IS take fine macros and have a hotshoe. It takes some practice getting focus, especially with the regular Macro setting, and my (limited) experience coincided with some sophisticated results on the old camera-dedicated forums that SuperMacro gets it better:
https://www.flickr.com/photos/34451390@N02/36992498684/in/pool-powershots5is_macro/
or
https://www.flickr.com/photos/52636605@N05/27577064582/in/pool-powershots5is_macro/
Canon renders JPEG output, especially out of camera color, better than most competing brands, and the CCD sensors of the day were quite good.
I'll just throw in, there's a working assumption that shooting tiny things is best done with macro, and often so - but for some set ups and arrangements of multiple objects there's a lot to be said for shooting zoomed-in telephoto (especially where DOF is a consideration.)
Update:  to the accurate comment below about chromatic aberration / color fringing - I'm not necessarily recommending S5IS over the G series of the day.  It does offer 432mm EFL telephoto, and one assumes some post-processing for a professional shoot.  CA removal is a snap in software.
GeraldW Veteran Member • Posts: 8,872
It's a matter of the actual focal length and the aperture being used.  Every sensor smaller than FF will have a smaller actual focal length than the equivalent.  Small sensor cameras have much shorter actual focal lengths.  A 28 mm equivalent lens used with a 1/2.33" sensor will have an actual 5 mm focal length and at a given F# will have more depth of field because the actual aperture is much smaller.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
Probably a small sensor camera with a fast lens, as that gives you more latitude for adjustments.  Does the camera need to be a Canon?
One of the best set ups for small objects I have found is a Panasonic FZ200.  The lens is f/2,8, 25-600 mm equivalent, and the lens is threaded for 52 mm filters.  It does well by itself; but I also used mine with a close up lens to get greater magnification.  The FZ200 also has provision for an LA7 adapter to screw into the body to hold close up lenses, which can be quite heavy.
Adding a close up lens to the SX50HS is not as easy, as you need a filter adapter that bayonets onto the lens, and then the thread size is quite large (67 mm) and you can't use a hood at the same time.
Canon G series cameras have good sharp lenses.  To add a close up lens, you'll need a Canon lens adapter made of plastic, which attaches to the body and accepts 58 mm filters.  Kiwi also makes a similar adapter out of aluminum.
Someone in this thread mentioned the Canon S5IS.  Sharp lens; but the camera is prone to chromatic aberrations (colored fringes at high contrast edges).  Later cameras have automatic in-camera removal of such fringes beginning with the SX40HS.  G11 & G12 and later are good about CA.  Canon was late in including automatic CA removal.  I can easily see jewelry, brightly lit and sitting against a dark non-reflective background having bright, colored fringes around the edges.
Jerry
DrHook59
DrHook59 Contributing Member • Posts: 852
Many of the S series do good macro, some are better than others. I have used an S120 for four years now, with and without achromats, and it works well (see my gallery for some examples). They can be picked up on eBay for not a lot of money, especially the S90, S100 and S110 (forget the S200).
Alternatively, some of the older SX series such as the SX30 and SX40 are also capable of great results with the 58mm plastic bayonet holder and an achromat. Photo below is from an SX40 and a Raynox 150, for example. These older SX series can also can be found for a great price on eBay. A Raynox (either the 150 or the 250 would be suitable) will be about €50-70 depending on where you buy them.
Some of the coolest things in life are really, really small.
 DrHook59's gear list:DrHook59's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
saaber1 Senior Member • Posts: 2,164
Agree with Chaplain Mark.  The statement on it's own does not make sense.  Just assuming a smaller sensor camera will give better pictures due to increased DOF does not make sense on it's own. You may be better off changing your techniques with the DSLR to achieve greater depth of field vs. current techniques.
If you already have access to a DSLR, are you using a macro lens and have you shot at a small aperture?  Also, like someone said above, you may be looking at stacking images to get all of the object in focus.  You can use bellows or focusing rails for really precise shots for stacking.
If you are mainly going after ease of use, then a point and shoot with a good lens and short minimum focus may address that due to reduced complexity.  But keep in mind you still have to use the same techniques as a DSLR to get really good shots.
I have the S90 and the nearly identical S95.  They do not have auto correction of chromatic aberration; but the lens is so good there is very little CA.  Both are still favorites.
Jerry
Asla
Asla Senior Member • Posts: 1,100
Hi!
How small jewels? PS A700 and A710is I have used, not for jewels but ice. You can fit frame with subject sized 20x26mm.
You need to consider distortions, however, since this is achieved only, when lens is in its wide position (35mm equiv.)
Lighting can be bit challencing as distance between front element and subject is only 1cm.
Then there is, of course, lack of RAW option (unless CDHK)
A s l a
Old Deer; Detail In Ice
Asla
Hi!
Oh, sorry. I missed that hot shoe is needed.
You might get more power, more macro with adiitional close-up lenses...
A s l a
DrHook59
I have no hot-shoe on the S120, and have never used flash in any of my macro photography. Instead I use constant LED lighting, typically with home made diffusers over the lights. It's an effective workaround and I currently use a pair of Q8 's for static subjects (this means I always have a pair of really powerful flashlights around the house, too!). These lights have variable-output switches which makes for very interesting lighting possibilities. I mount them on mini Pixis from Manfrotto for table-top work. Other lights can be used similarly, obviously.
Asla wrote:
Hi!
A s l a
I don’t see why a hot shoe is needed personally. OP can use any flash that has an optical slave mode and use the built in flash to trigger it. Very inexpensive but good quality flashes are available such as yongnuo for $30 used to $75ish new. External flash gives way more options for the right angle of lighting, using multiple flashes, light modifiers etc. Hot shoe is only needed for ttl, which personally I would never use for macro work.  Studio flashes can be triggered with optical slave which are cheap and reliable.
tkbslc Forum Pro • Posts: 17,522
bellows/tilt
You probably want a macro bellows or something allows tilt.  Then you can control the angle of the plane of focus to solve your issues rather than the depth of field.
panamforeman
panamforeman Senior Member • Posts: 1,296
The G15/16 will do quite nicely with an attached close-up lens on an adapter. It will do all you that you have said you want.
 panamforeman's gear list:panamforeman's gear list
Canon PowerShot S120 Panasonic ZS100 Canon Pixma Pro9000
